Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#5327
#5328
#5331
I have a 05x sedan and just picked up some 18x8.5 wheels with some 235/45/18 tires. Being that they're +50 I know I'll have to pick up at least 5mm spacers for the fronts to clear. My question is what spacers will get me pretty close to flush? I do plan on lowering, but only to maybe 1-2 finger gap between tire and fender. Would I be okay with 15mm spacers all around? I'm not looking to have them stick out past the fenders. Also my fenders aren't rolled/pulled if it matters.
#5332
BuzzLightYear (03-11-2013)
#5333
I have an 05 G35 coupe 6mt with the stock 19's. I'm looking to get VMR V710's and was looking at 19x8.5 ET 35 in the front and 19x9.5 ET 22 in the rear. Would this settup fit with coilovers, without the use of wheel spacers and without having to roll my fenders? Also I'm not sure about tire specs to fit these wheels. I was thinking 255 in the rear and 235 or 245 in the front. Would this work??? Also would these clear the brakes.
#5334
#5336
#5337
Fitment Help
I have an 05 G35 coupe 6mt with the stock 19's. I'm looking to get VMR V710's and was looking at 19x8.5 ET 35 in the front and 19x9.5 ET 22 in the rear. Would this settup fit with coilovers, without having to roll my fenders? Also I'm not sure about tire specs to fit these wheels. I was thinking 255 in the rear and 235 in the front. Would this work??? Also would these clear the brakes.
#5340
@LilLB88:
i don't have brembos on my 06 coupe, so i can't speak for brake clearing on your 05.
but for fender, the VMRs should fit fine. i have similar specs in the rear and i'm lowered as well.
the tire combos for those rims can be 245/35/19 and 275/35/19 for a wider look. Or 235/35/19 and 255/35/19. And even the OEM sizes 225/40/19 and 245/40/19 can be stretched to fit 8.5 and 9.5 width.
