Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Mar 14, 2013 | 07:31 PM
  #5356
drozzy's Avatar
Hey guys, regardless of whether I'm going ahead with a drop this summer on my 06 X (still undecided, re-doing budget), what tire size will perform & look better on 19 X 8 (40mm) rims - 245/40 or 225/45? Thanks for the input!
Old Mar 14, 2013 | 07:33 PM
  #5357
OBsessed's Avatar
Originally Posted by TGMcCoy
Any thoughts of running stretched 40 series tires on 19" aggressive wheels? I know most run 35 and 30. Just curious. Would be for ground clearance
I'm running a 225/40 up front (19x10) and it matches pretty well with my rear 255/35 (19x11.5). Wasn't a setup I was looking to run but they were used tires and have worked out well for me. Can't say as the extra couple mm have given me noticeable ground clearance, but there's probably some in there.
Old Mar 16, 2013 | 01:11 PM
  #5358
Carrottop401's Avatar
Hi guys, Noobie to modding my wheels/ coilovers.. I have a 2004 g35x sedan, and im looking to purchase some wheels without too much modding needed.. Idk anything about offsets, camber, or basically anything lol... Im looking to purchase 19's or 20's and drop my car a little lower. what are some simple yet efficient combos of wheels n coilovers that could be used?
Old Mar 18, 2013 | 02:14 AM
  #5359
saason.Ez's Avatar
would this be a good setup for a slammed coupe
225/35/19
19x9.5
-20
245/35/19
19x11
-15
should i go with this or would it look better without a 15 mm spacer in the back... then just going with a 255 and 0 offset. which one would be more flush when I slam it in a couple weeks
Old Mar 18, 2013 | 12:06 PM
  #5360
albert3029's Avatar
Wheel offsets question
Sup fellas,
Wondering how 19x8.5 +27 & 19x9.5 +24 will fit on my first 1gen? Dropped on coils
Thanks!
Old Mar 18, 2013 | 12:43 PM
  #5361
dragonv's Avatar
What size ties should I get for 20x9 et13 and 20x11 et13 on 04 coupe lowered on stech springs. I daily drive my car so want some rubber for protection and ride comfort but also want a little stretch. Looking for something that won't cause me to rub and don't really want to have to roll my fenders. I'll be using Achilles atr sports. So what size should I be getting?
Old Mar 18, 2013 | 12:57 PM
  #5362
FlyingLumpia's Avatar
yes
Old Mar 18, 2013 | 01:04 PM
  #5363
albert3029's Avatar
^ Would I have to roll rear fenders? I'm AWD, so I'm running 245/40 all around. Thx.
Old Mar 18, 2013 | 01:14 PM
  #5364
rhampsterwha2's Avatar
bump, he needs to know, wheels are in and ready to order tires
Originally Posted by rhampsterwha2
asking for a friend....2005 Coupe with rolled rear fenders and very slight pull on front fenders
specs: 20x10.5 +30 all around
he has a 32mm spacer to run in the rear
if running -2 to -3 deg camber is any spacer needed in the front to match rear and will 245/35 on all 4 create any issues if so what tire size recommended
thanks guys!!!
Old Mar 19, 2013 | 01:24 AM
  #5365
DrewDrew's Avatar
245/35 is perfect all around. run a 5mm spacer up front to match.
Old Mar 19, 2013 | 03:10 AM
  #5366
Rjblayz's Avatar
So i picked up some Lmgt4's 19x8.5 / 19x9.5 and not sure what size tires I should run. I'm not going to dump my sedan and stretch my tires to the max (booo! i know) However, I was thinking about running 255/35 n 275/35. I'm still looking for coils b/c this G/Z setup is not cutting it. Guess I'm looking for a sortaflush type of look. Thanks for the input.
Old Mar 19, 2013 | 06:38 AM
  #5367
thanks DrewDrew ill let him know
Old Mar 19, 2013 | 08:46 AM
  #5368
HereKittyKitty's Avatar
Installled Pilot Super Sport by Michelin..........very quiet tires so far.........225/40ZR/19 with 255/40ZR/19 rear. Love the look and no need for spacers. Total cost a bit less than $1500.
Old Mar 19, 2013 | 02:31 PM
  #5369
double_jn_it's Avatar
So I can move my decent 245s to front and then get some new different 245s in the back? You said its good for betters stability?
Old Mar 19, 2013 | 04:19 PM
  #5370
Texasscout's Avatar
It's (usually) better to have narrower width tires in the front than the rear (unless all are the same) to help with stability. I remember having some super wide tires on the front of a car I had and that thing would hunt all over the road.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
