Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Mar 28, 2013 | 03:55 PM
  #5386
TORETTO's Avatar
Around $250 each from VR.
is American Rim the same as that other place that sold the raw lips? if, so I calculated it and buying them there and having them polished would cost more.
Old Mar 28, 2013 | 04:04 PM
  #5387
TGMcCoy's Avatar
That was the same place. How much is it to high polish wheels normally from a raw state?
Old Mar 28, 2013 | 04:06 PM
  #5388
TORETTO's Avatar
$100+ per lip?
Old Mar 28, 2013 | 04:25 PM
  #5389
TGMcCoy's Avatar
No way... That's insane
Old Mar 28, 2013 | 05:25 PM
  #5390
TGMcCoy's Avatar
It wasnt American rim supply.. Amcrimhalves.com
Old Mar 28, 2013 | 05:26 PM
  #5391
TORETTO's Avatar
^ AMC Rim Halves?
Old Mar 28, 2013 | 05:36 PM
  #5392
TGMcCoy's Avatar
http://www.amcrimhalves.com/inventory.php. Yea
Old Mar 28, 2013 | 05:55 PM
  #5393
TORETTO's Avatar
My other question about those barrels is are they already pre-drilled for my wheels?
if not, then that's polishing and drilling on top of the cost of the actual barrel.
Old Mar 28, 2013 | 06:07 PM
  #5394
TGMcCoy's Avatar
Could be-- they are standard 40 hole, not sure equips sizing:
18" Diameter Reverse Lip / Rolled Flange Outer Halves:
Assembly Hole Pattern / Hole Sizing for M8 Bolts: 40 XØ8.5mm Equally Spaced.
1 Hole Slotted For Thru Center Valve.
Rim I.D. @ Bolt Flange: 17.675" / Bore: 15.915" /
Bolt Flange Thickness: 0.180" +0.010/-0"
Old Mar 29, 2013 | 08:03 PM
  #5395
Nany_Turbo's Avatar
Does anyone run 295/35r20 or bigger?
Old Mar 29, 2013 | 08:15 PM
  #5396
herrschaft's Avatar
Why would you want that tall of a tire?
Old Mar 30, 2013 | 12:55 AM
  #5397
Malcolm Rojas's Avatar
im in the market of getting new wheels so the fitment for the front is 19x8.5 5-114.3 [+15mm] and the rear is 19x11 5-114.3 [+15mm] will these fit in the wheels wells without fender roll and lowered 1.5'', and is 8.5'' in the front and 11'' to much of a gap, and do i need to be aware of anything with such a aggressive wheel im about to buy? need response asap sitting in my shopping cart.
Old Mar 31, 2013 | 12:48 PM
  #5398
Nany_Turbo's Avatar
That is the size of the wheel on the back of my coupe now that the previous owner had put on. But he bent 3 of the 4 rims so I have to get new ones. I like the look of it now I'm just wondering what kind of room there is too play with and what others have put.
Old Mar 31, 2013 | 10:41 PM
  #5399
rmacinni's Avatar
someone want to bless me some wheel knowledge?
Looking at a set of 18 Work VS XX 3 Piece wheels. The specs are:
Front
18x8.5 +35
Rear
18x10.5 +22
The front offset scares me for reason, is it possible to get that sitting right with spacers? Also is it possible to fit 305's on the rear?
Old Mar 31, 2013 | 11:13 PM
  #5400
ReStylin's Avatar
For 1. 18s are wayyyy to small.
2. Purple is so bad
3. I am buying them stay away
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
