Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Sep 10, 2013 | 04:06 AM
  #6106
TGMcCoy's Avatar
Originally Posted by beaguilar
Ok so maybe separating and putting new barrels on in my garage isn't the best idea..
Call or shoot Vr wheels an email and see if they have any Meisters they can build for you/ or some ssr sp1's(look close to Meisters). I think is your best bet- I don't think you want to get into re- barreling wheels
Old Sep 10, 2013 | 08:24 AM
  #6107
Big Booty Trudy's Avatar
Thanks man!
Old Sep 10, 2013 | 04:31 PM
  #6108
Drew113's Avatar
Ban Hammer Expert
yeah unless you've done it yourself before i wouldn't try to do it now...getting everything correct to piece it back together and actually installing the pieces correctly isn't all that easy
Old Sep 10, 2013 | 04:42 PM
  #6109
Dang I thought it would be. Thanks for letting me know.
Old Sep 10, 2013 | 04:51 PM
  #6110
WhosUrBuddiee's Avatar
It is actually very simple to disassemble and reassemble 3 piece wheels.
Old Sep 10, 2013 | 05:04 PM
  #6111
Really? I'd really like an answer. There's a sweet, local deal I may jump on.
Old Sep 10, 2013 | 05:29 PM
  #6112
- Unbolt face.
- Clean silicon (razor then steel wool)
- Replace barrel
- Torque wheels in star pattern (specific torque will have to be researched, volks are usually 45 ft-lbs)
- Scuff mating surface of barrels
- Clean with alcohol
- Apply silicon
- Let dry for 24 hours
- Mount tire
Old Sep 10, 2013 | 05:32 PM
  #6113
TORETTO's Avatar
^ That's the process for 3 piece wheels where the seam between barrels has not been welded. Or has had the weld already broken.
Beaguilars question is about the 3 piece wheels that are welded, and I can say you'd be there forever trying to scrape a weld off with a razor and some steel wool.
Old Sep 10, 2013 | 05:33 PM
  #6114
Oh no Toretto I think they aren't welded! Forgot to tell you man. Vendor on here told me the 3 piece wheels don't come welded (thumbs up)!
Old Sep 10, 2013 | 05:34 PM
  #6115
TORETTO's Avatar
In that case, what WhosUrBuddiee said is pretty much it.
It's a very straightforward process
Old Sep 10, 2013 | 05:35 PM
  #6116
TORETTO's Avatar
Also, that depends which 3 piece wheel. That vendor can't just go out and say all 3 piece wheels aren't welded, because that article with the pictures direct from the Work factory show them welding 3 piece meisters.
Old Sep 10, 2013 | 05:38 PM
  #6117
So my question would be what size barrel I'd need and from where? Specs of wheels are 12 +29 with a 121 mm lip. Want it as close to 11+0 as possible.
Old Sep 10, 2013 | 05:39 PM
  #6118
I asked THMotorsports specifically about work meister s1 3p.
  #6119
Only the 2 piece meisters are welded. Per work website they are modular, so not welded. Many people have refinished 3 piece meisters.
Old Sep 10, 2013 | 05:44 PM
  #6120
TORETTO's Avatar
I'm not exactly new to wheels so I'm aware of this. But...
http://fatlace.com/2013/02/7-days-in...heels-factory/
"Work Wheel doesn’t put glue, they actually weld their 3 piece wheels together. When the wheel is damaged being it a 3 piece, they have machines to break the welds. This isnt the same type of weld they do on their 2 piece builds but its done to ensure a solid wheel."
Welding
Weld
Silicone over weld
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
