Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jul 12, 2010 | 03:33 PM
  #1021
angelo350z's Avatar
19" lmgt4 +20, 23, +25
Hey guys, I believe this is my first post . To all the 19" LMGT4 owners, what's the most agressive offset that will work with the 19x9.5 rear wheels? +25, +23, or +20? Fender rolling is NOT an option. I posted this on another site, but just wanted to get more feedback. Thanks in advance.
Old Jul 12, 2010 | 06:19 PM
  #1022
JBF's Avatar
JBF
how low are you?
Old Jul 12, 2010 | 11:09 PM
  #1023
angelo350z's Avatar
Originally Posted by FinallyGotaG
how low are you?
Lowered on Eibach Pro Kit, so 1".
Old Jul 12, 2010 | 11:59 PM
  #1024
JBF's Avatar
JBF
+20 will be fine
Old Jul 14, 2010 | 03:36 AM
  #1025
sick04cpe's Avatar
I have a 06 6mt RAS coupe and I am wondering can I run Work vs-xx front 20x9.5 r disk +17 and rear 20x11 O disk +19. My main concern is how much of a drop I would need to make this look aggressive. I don't mind rolling my fenders flat if neccessary. I'm just wondering if I have the correct disk type and offsets for it to work. Also what size tires would be best for this setup? How mch Camber will I need to run? An finally will any if this affect my RAS? I guess basically I'm after the same stance as robzone when he had vs-xx on his g. I know his offsets were pretty crazy but are mine a good starting point? I can always get spacers if necessary right.
Old Jul 14, 2010 | 06:08 AM
  #1026
SinCityFD's Avatar
Will these fit a 04 coupe no brembo
18x9.5 +35 front
18x10.5 +12 rear
If not what will it take to make them fit
Old Jul 14, 2010 | 06:15 AM
  #1027
Dranom's Avatar
18x9.5 +35 front
18x10.5 +12 rear
its depends on the DISK not offsets
also +35 is SO weak on a coupe
Old Jul 14, 2010 | 08:02 AM
  #1028
JBF's Avatar
JBF
^ not totally since there are only a few wheel manufacturers that follow disc specs. But even then the disc only means how much 'pad' is on the hub of the wheel for BBK clearance IIRC
Either way, no matter what disc the wheel is, the offsets will remain the same.
Old Jul 14, 2010 | 10:43 PM
  #1029
jaketuff's Avatar
Pondering this wheel -
'Drag' Brand... any idea if these are POS or decent quality lighter weight wheels? Thanks.
OUT
Old Jul 14, 2010 | 10:44 PM
  #1030
JBF's Avatar
JBF
I've never even heard of drag...
Old Jul 14, 2010 | 10:53 PM
  #1031
sick04cpe's Avatar
Can anyone help me on the post 6 above this?
Old Jul 14, 2010 | 10:56 PM
  #1032
JBF's Avatar
JBF
I'd say run 15mm spacers all around with 225/35 and 245/35 tires. low enough to hide the tread and 2.7-3.0 camber...
Old Jul 14, 2010 | 11:05 PM
  #1033
Dranom's Avatar
Why go with spacer if you gonna buy new?
If your not getting BBK get A disk up front and O disk rear. For max lip. Single digit offsets to negative.
Since you want a stance like robzones
Try maxing out your coils and adjust accordingly.
Camber wise your looking around -2.5 to -3/-4 depending on the drop since you get natural camber everytime you drop your car
Regarding RAS my friend didnt had issues when he was slammed before. But dont qoute me
On this
Old Jul 14, 2010 | 11:06 PM
  #1034
JBF's Avatar
JBF
^ I think he may be getting these wheels used?
Old Jul 14, 2010 | 11:20 PM
  #1035
sick04cpe's Avatar
am buying new. I don't know if you can get these with custom offsets. And I would like to be able to clear bbk for the future. Dranom whatare your offsets cuz I really like your stance as a matter of fact I think I have pm'ed you before. Really what would you and finallygotag suggest for those wheels offset wise and how much of a drop? I don't Mind a little rear poke or rolling fenders.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
