DIY: Upgrade your ugly FOB to a nicer Infiniti Smartkey
Old Feb 11, 2009 | 11:54 AM
  #121
osbidianhorse's Avatar
Exclamation only the trunk and the panic button works
Hanguk, i realized that we have two different circuit boards in our original fob, i have the one just like in your pic, (K702068...) as seen on the top left part of the board. i tried to follow the original DIY and soldered it accordingly but, i cant get my lock and unlock buttons to work. i tried 3 different times, dont have any physical damage to the board.....now my question to you is, did you follow the original DIY or, you had to do anything different as far as the soldering/circuit goes. help me out, i am stuck.
comeon' somebody please reply why only the trunk and the panic button works for some of us??...( agian, i tried several different times. the wiring is pretty similar to the ones in the original post, the only difference is that i happen to have a little bit differnent circuit board in my original fob.)
Old Feb 27, 2009 | 01:48 AM
  #122
UltraBlue600RR's Avatar
I finally got mine working~! I got my new remotes in a couple days after my last post but I have been busy... I finally got the time to do mine and it works perfectly. I had to dremel out some of the casing to make it close all the way but it works great now.. If anyone wants this done I can test it to make sure it works before shipping it out. I figured out a way to test it before shipping it to you so let me know if anyone wants tis done. If you send me the remotes it will be cheaper or I can buy them and do the mod then ship it out. Not sure how much to charge yet though........
Old Mar 9, 2009 | 10:22 PM
  #123
tanko11 just sent me his remote to do the upgrade on, I finished it tonight and am waiting for payment, then i will ship the remotes back to him. I tested the remote to make sure it was working and it works like a charm. I'm sure he will chime in when he receives his remote back and tell you guys how good it works. Anybody else need this done please let me know.
Aaron
Old Mar 14, 2009 | 09:09 PM
  #124
tanko11's Avatar
Finally got my remote fully working, thanks to UltraBlue600RR. I sent him my remote and he did the mod for me. So if anybody wants their remote done PM UltraBlue600RR.
Old Apr 21, 2009 | 11:07 PM
  #125
all pm's replied for this mod.
Old Apr 22, 2009 | 04:15 PM
  #126
mnrg35's Avatar
dude can you pm me to i want this mod for my key.. thanks
Old Apr 26, 2009 | 01:39 AM
  #127
pm sent...... shipping out another remote on Monday.......
Old Jul 28, 2009 | 01:17 AM
  #128
DRE's Avatar
DRE
is it possible to cut smarts key sliding key and program it to be compatible with a 2005 coupe ingition????
Old Aug 10, 2009 | 12:29 AM
  #129
SemperFlyG35's Avatar
hey everyone,
i did all the soldering and the buttons function normally when i use only the circuit board by itself. when i try to mount the board in the intellikey housing, none of the buttons work, but sometimes the "lock" function opens up the trunk. i know the circuitry all works, and it seems to be simply a matter of getting the buttons to contact the circuit board, but ive tried and tried, and i'm stuck. can anybody help me? thanks alot!
Old Aug 17, 2009 | 11:04 PM
  #130
drifts500's Avatar
Is 2006 M35 keyless remote (looks same as g35s remotes) also works? It is new though.
Old Aug 28, 2009 | 01:15 PM
  #131
Flavius's Avatar
I want it done,, let me know
Old Nov 20, 2009 | 08:55 PM
  #132
Demontrae's Avatar
hello, Ultrablue are you still doing the key fob mod? If so I would like to know how much and when can you do it. Thank you!
Old Nov 26, 2009 | 02:40 PM
  #133
stinkytofu89's Avatar
anyone local so. cal want to help me with this mod? will pay
Old Dec 1, 2009 | 03:53 AM
  #134
jibberjabbers's Avatar
Correct me if I am wrong, but wouldn't it be a lot easier if we just switched the buttons on the remote around to match the our circuit board instead of the other way around.
The buttons looks like it'll just pop out with a little force.
Old Dec 6, 2009 | 12:11 AM
  #135
paymon's Avatar
I don't fully understand the procedure. Do we take the entire board first, then lay down the copper, solder, and then tape again on top of the soldered copper??
2nd question; do we have to poke the copper wire through holes in the board and solder it on the back side as well?
