Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Rating: Thread Rating: 31 votes, 5.00 average.
Old Jan 9, 2024 | 06:05 PM
  #2311
josephcl's Avatar
06 g35 base coupe
Originally Posted by romansan2008
I had this happen to me before and it ended up being my clock spring.
after I replaced my clock spring everything was working ok.
my car is a 2006 g35.
let me see if there’s a difference between 06 and 07 SWC wires
all the buttons worked prior to the DD install. I got all buttons working except mute. Mute worked prior so now idk which wire goes to the two aswc wires lol
Old Jan 9, 2024 | 06:14 PM
  #2312
romansan2008's Avatar
I used iDatalink SW for my steering wheel controls. It has way more options on what buttons do.
For mute in my car I press and hold volume down for 2 sec and let go to mute the radio.
i have short press and long press setup so each button can do 2 things.
i do not remember the wire colors on the wire but if you look at the pic connect to the correct pin in the connector and you will be good.
ASWC may not support mute feature in some cars. I never tried it in my car so I can’t compare.
i went with iDatalink maestro from the door because of the extra options and easier installation but it’s more expensive then aswc.
Old Feb 24, 2026 | 12:07 AM
  #2313
G35__Matt's Avatar
5 Year Member
White Manual Sport Package, Rays 19in OEM Wheels
I have a question about bypassing the bluetooth module for steering wheel controls in my 2006 coupe with Bose system. According to the instructions for my Maestro SW the bluetooth module harness should be left disconnected, but I'm suspecting it supplies the reference voltage for the steering wheel controls. I've tested the resistances of signal A and B to ground and they correspond with the specs in the FSM but with the key on there is no voltage at either of those pins. Should the bluetooth module be reconnected after the bypass or left unplugged?
Old Feb 24, 2026 | 07:49 AM
  #2314
the steering wheel controls wires go through the Bluetooth module, if you just unplug it you loose steering wheel controls.
steering wheel controls are ground signals through a resister so you will not see any voltage on it.
after you disconnect the Bluetooth module you need to connnect a couple wires in that plug.
and leave the Bluetooth module unplugged.
im sure I posted that picture here in the past.
steering wheel controls consist of 3 wires.
ground input and 2 outputs.
if you need that diagram to see what 3 jumpers you need to do in the Bluetooth plug let me know and I’ll look it up for you.
in aswc and mistro ws instructions for the car it will be on the last page if I remember right.
Old Mar 1, 2026 | 10:04 AM
  #2315
Wrathernaut's Avatar
Gentle Manne of Leisure
Steering wheel controls go through the module and intercept some of them, passing the others through. You just wire around it.
The first post has a link in it if you just search for bluetooth in it - How to keep steering wheel controls when you had factory bluetooth
The image is broken in that though. I'll see if I've still got the source image. edit - image isn't on this computer, I may have to dig up an old one to find the image.
Old Mar 1, 2026 | 10:11 AM
  #2316
here’s the answer.
this is for the maestro SW but will also help with ASWC for the Bluetooth module.
ChinkyChoy
Oct 24, 2011 01:00 PM
kenchan
Aug 16, 2010 12:25 PM
DP15X
Jan 29, 2009 08:10 PM
LSSG35
Dec 22, 2008 01:22 AM
mEsOaZn
Northern California
Feb 20, 2008 02:08 PM
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
