Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old Jul 10, 2011 | 09:33 AM
  #406
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by Night
I just purchased everything i need to hook up my double din radio but the actual setup is so confusing is there a video showing you exactly how to wire up the aftermarket HU using the wire harnesses showing you what to conect to what??? BTW my car is a 2003 coupe with the Bose setup
No, there is no video of showing you how to wire red to red, blue to blue, yellow to yellow...
Old Jul 10, 2011 | 09:59 AM
  #407
Revision Notes, 10 July, 2011:
Added information on the Metra Aluminum Kit 95-7605A (Thanks AreSicks!).
Old Jul 10, 2011 | 05:03 PM
  #408
AreSicks's Avatar
No problem man. One thing to note: It's still plastic, just aluminum "look".
Old Jul 10, 2011 | 08:17 PM
  #409
Night's Avatar
so you dont need to rewire the speakers and amps you can use the stock? adn why is there an extra plug from the stock harness that doesnt hook up toanything?
Old Jul 10, 2011 | 10:23 PM
  #410
Ah, I'll be sure to edit the FAQ section.
Old Jul 11, 2011 | 09:55 AM
  #411
Mystikal's Avatar
so for the pioneer x930bt...i cannot use the PAC SWI-PS??? Cause i just bought one...
Old Jul 11, 2011 | 04:56 PM
  #412
It works fine, but since the x930 has very limited voice commands, the axxess makes for an easier install with little or no loss of functionality.
Old Jul 11, 2011 | 10:35 PM
  #413
Night's Avatar
alpine w407 was installed but videos and setup cant be displayed because i need to hook it up to my brake and ebrake wires. i just bought this bypass "Peripheral PTR7 Universal Timer/Trigger Module" will this work for bypassing it?
Old Jul 12, 2011 | 12:19 AM
  #414
Trickstyle's Avatar
are u using an aftermarket amp? if you are, it can be a PITA to find the wires, i can take pics of mine tho, i cut into my harness to bypass tht POS bose amp. if not then just hook it all up the wires from the harness should have front/rear, left/right, +/- in small print on them FL+ FL-, FR+ FR-, RL+ RL-, RR+ RR-. and then your head unit should also have which of its wires are for which speaker. pretty easy.
and there will most likely be 2 extra harnesses, one from your steering wheel controls for the stock HU, and one from your Navi(voice and mute signals to the stock HU)
umm... idk how urs is but the wires that you would connect to your ebrake(mine was pink) you should be able to tie in with your ground wire(black wire) and it should work. AFAIK the ebrake point you would wire it to becomes grounded when the ebrake is applies(also completes the circut for the ebrake light on your dash, making it light up)
Old Jul 12, 2011 | 01:37 AM
  #415
Mystikal's Avatar
I just installed the avicx930bt, but forgot to hook up the speed sensor wire (pink) where would I hook that up too?
Old Jul 12, 2011 | 08:03 AM
  #416
AreSicks's Avatar
Yes it will work. There should be specific wiring instructions for bypassing the video with the module. I bought the PAC version of what you had and it works perfectly.
Old Jul 12, 2011 | 10:50 AM
  #417
KnowScott's Avatar
This thread is epic!
I recently started ordering parts for my 06 6MT (with nav)... Unfortunately the JDM AC/Controller Trim piece is back-ordered for about 2 months now, and from what I understand, it's gonna be at least another month.
Here is my list of items purchased:
JDM AC Controller/Trim Piece
Alpine INA-W910
Dynamat Extreme 35 sq foot
Diamond Audio H600S components
Metra 70-7550 Radio Wiring Harness
Metra Axxess ASWC Universal Steering Wheel Control
Metra 40-NI10 Nissan Antnna Adapter
PAC TR7 Universal. Trigger Module
Sirius-Xm SVX100V1 Xm In-Car Tuner and Antenna
Power cable, battery terminals, fuses, speaker wire, rca's, etc.
Already owned:
(2) JL Audio 12W3V2
JL 500/1 Slash amp
JL 300/4 Slash amp
I'm still debating whether or not I want to build a box for both 12's or buy a new beastlier sub. If I buy a beastlier sub, I will most likely need another amp as 500 isn't going to cut it.
I plan on dynamating the entire truck and both doors. I may dynamat more depending on rattles and overall SQ. Anyone have issues with the rear view mirror rattling?
Can anyone think of anything I may be missing or suggestions for my setup?
My car is XM equipped with the factory equipment... Is it possible to use the factory installed XM Antenna or will I have to rerun the one included in the Sirius-Xm SVX100V1 Xm In-Car Tuner and Antenna package?
Clicky Clicky
Old Jul 12, 2011 | 07:40 PM
  #418
Night's Avatar
i also followed wrathernauts bose wiring setup with the 70551 and grounded all 3 grounds but for the blue wire (amp turn on) there is no wire coming out of my alpine w407 to hook that up. are the bose amps powered even if this isnt hooked up. my speakers go kinda loud as is but even with the bassnturn all the way up there is slight/no bass..
Old Jul 12, 2011 | 07:51 PM
  #419
According to the manual (page 68) - it's a blue/white wire.
Old Jul 13, 2011 | 07:58 AM
  #420
AreSicks's Avatar
I hooked it up on mine to be safe. Not sure if the Bose amp power is triggered by the radio remote wire or the ignition. Anyone know?
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
