Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Rating: Thread Rating: 31 votes, 5.00 average.
  #1141
Old 03-03-2013, 05:22 PM
malcocw's Avatar
Here are some pics of how the harness is installed (obviously black plugs go to the HU)
  #1142
Old 03-03-2013, 05:37 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Received 1,037 Likes on 610 Posts
Originally Posted by malcocw
So I am having some problems with my new install. I have a 05 g35 with Bose. I purchased a Jensen VM9225BT unit and a PAC ROEM NIS2 (no steering wheel hookup).
I followed the wiring diagram on the first page and hooked it up. The unit powers on but no sound. I hooked up the original to verify the speakers still worked and they did.
Not sure why the new HU doesnt produce sound (radio, cd or iphone)??
Any help appreciated!!!
Perhaps the Jensen isn't sending the amp turn-on signal or is just faulty. Check for a signal from the headunit - the amp power signal should be an easy check for +12v with a multimeter, the audio signal can be checked for similarly, but won't be a nice constant +12v signal to search for.
  #1143
Old 03-03-2013, 07:15 PM
malcocw's Avatar
Just tested my connections. I tested all 8 audio lines with positive lead inside of plastic connector and black grounded to metal of car and got ~6V on everyone of them on the HU side. On the car side (in between car and PAC) those same lines were a range of .15V to .8V. The yellow and red lines were 12V on both sides of pac
  #1144
Old 03-04-2013, 11:27 AM
But what about the blue amp turn-on signal?
  #1145
Old 03-04-2013, 11:48 AM
malcocw's Avatar
Here is the wire diagram for my HU. The solid blue line is connected to the red ACC line and reads 12V. I do not have the blue/white wire hooked up at all.
http://www.voxxintlcorp.com/docs/com...M9225BT_IM.pdf
  #1146
Old 03-04-2013, 12:19 PM
malcocw's Avatar
Which I now realize may be my problem. If not though, any other ideas?
  #1147
Old 03-04-2013, 03:22 PM
Can you snap a photo which very clearly shows how your wiring harnesses are connected?
  #1148
Old 03-04-2013, 03:25 PM
malcocw's Avatar
I will as soon as I get off work which will be around 5:15 CST.
  #1149
Old 03-04-2013, 07:13 PM
malcocw's Avatar
Sending photo in a few min. I hooked up the blue/white wire on the HU to the PAC. It is reading 0 then .038 repeating (0 for 1 sec then .038 for a sec etc). The yellow and red are still reading 12v I also turned the little screws in the PAC all the way to the right and now on the PAC to amp side the readings vary from .5 to 1.5 for the speakers.
  #1150
Old 03-04-2013, 07:17 PM
malcocw's Avatar
In this pic the multi colored plug spot I only hooked up the blue/white wire
This pic the bundle I am holding is the speaker wires. You can see the solid blue and red from HU hooked to red of PAC. And the wires hangin down next to seat are all wires from the multicolored plug mentioned above.
Btw no sound still obviously
  #1151
Old 03-04-2013, 08:41 PM
malcocw's Avatar
Here is a slightly more detailed pic of the pac wiring harness.
Greyhame (09-12-2021)
  #1152
Old 03-04-2013, 09:27 PM
Ok, here's one problem:
You've got the radio's blue wire connected to the combined red wires, instead of the ROEM's blue wire connected to the combined red wires. Review the wiring diagram, which shows the ROEM's blue wire connected to the red wires.
I'm going to try and find the manual to the radio to confirm some of the colors.
  #1153
Old 03-04-2013, 09:39 PM
malcocw's Avatar
I'm a little confused. Are you saying that the white plugs from the PAC (came with original package from PAC) don't plug into the car and that the ends that were unattached to anything on the PAC don't attach to the Head unit?
  #1154
Old 03-04-2013, 09:46 PM
malcocw's Avatar
Does that mean I will need to splice on the "car" side of the Roem? And leave the blue wire open on the HU side?
  #1155
Old 03-04-2013, 09:47 PM
If the blue/white isn't reading +12v, then the amp won't turn on. Looking through the manual for your radio, you may need to ensure the subwoofer output is ON (audio settings sub-menu).
If that doesn't cause a +12v signal to go out on the blue/white wire, just connect the blue/white wire on the vehicle side of the ROEM up to the red wire on the vehicle side of the ROEM.
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
Quick Reply: Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
