Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Yeah, blue wire on the HU side doesn't give enough power to run the antenna, so it isn't used for anything.
ie splice these and leave blue connected to nothing.
http://i1037.photobucket.com/albums/...ctar86/65.jpeg
and leave this side like this?
http://i1037.photobucket.com/albums/...actar86/78.jpg
Also just to clarify. I splice them all together into a 3 sided splice to 3 sided splice correct. Ie red, blue and blue/white from Roem all connect to red, blue and blue/white on harmes to car?
Blue and blue/whites on the radio side of the ROEM remain disconnected. The two reds, blue and blue/white on the vehicle side of the ROEM connect together.
If you do the modifications in the video linked in the FAQs portion, it'll fit fine, otherwise, return the metra kit and buy the JDM, it'll fit right with the screen, if you want to keep the screen. If you're wanting to get rid of the screen entirely, Grubb's Infiniti is probably the best source for the cubby.
Thanks for that! Ordered a pocket from the Infiniti garage.
Any experience with the Metra kit's AC controls?
It mostly works, can control rear and front defoggers, AC on/off speed of fan, but I cannot control the temperature??
Also found with the rim of the Metra kit, that you cannot use the metal frame around the back and have to use some flimsy plastic bit to hold it in place on the top...
^ What that guy said.
