Pioneer AVH-P8400BH
Old Sep 28, 2012 | 03:06 PM
  #166
Dwalt024's Avatar
Has anyone done this before/are there pictures up for this? Also...I currently have an annoyance with my factory bluetooth set up - when I use it the soundcomes out of only ONE speaker - the front right one...with the new HU can this be fixed to come through all the speakers?
Old Sep 28, 2012 | 06:55 PM
  #167
blitzace137's Avatar
Originally Posted by Wrathernaut
Same as the identical post elsewhere.
Anything's better than the bose amp, but the amp you've got only will power two speakers.
Another quick question Wrathernaut I have the 06 coupe with Navi and voice control and I was reading somewhere that if you have the voice control you need the Pac Steering wheel controls not the Metra. Will the Metra still work or do I need to get the Pac-Swi-Ps for the Pioneer 8400bh.
Old Sep 29, 2012 | 02:01 AM
  #168
Wrathernaut's Avatar
Gentle Manne of Leisure
Where is this "somewhere" that has all this wrong information people are getting? The factory bluetooth adapter receives the steering wheel buttons before the headunit does, so long as it is bypassed, either will work. The Metra Axxess and PAC SWI-PS both work off the same signal, so it makes no difference which you use, but the Axxess requires less soldering and programming, so it's the way to go.
Old Sep 29, 2012 | 02:05 AM
  #169
Nah, nobody's ever posted up pictures of it. The factory mic sucks, so there's not really much reason to re-use it.
The factory bluetooth won't work with the new stereo.
Old Oct 1, 2012 | 08:15 PM
  #170
wanna power up my interior front and back speaker not a sub so I'm thinking about the 4 channel alpine amps. Am I better off with the 4 channel or should I still go with the 2 channel I have.. Sorry audio is not my field of knowledge.
This is the amp
http://www.amazon.com/Alpine-MRP-F300-4-Channel-Watts-Amplifier/dp/B0013TVALU/ http://www.amazon.com/Alpine-MRP-F300-4-Channel-Watts-Amplifier/dp/B0013TVALU/
Old Oct 2, 2012 | 10:04 PM
  #171
007JD's Avatar
i got some cool new tips and tricks that i ran across... to control everything on the iphone and any apps.. need to have the specail advance app plug .. lmk
Old Oct 4, 2012 | 11:11 AM
  #172
Dwalt024's Avatar
What aftermarket AMP and power is recommended to power all the speakers with the 8400. I ordered this AMP last year for my old car and never used it - it's still in the box I think ...
Amazon Amazon
Old Oct 4, 2012 | 02:06 PM
  #173
What aftermarket AMP and power is recommended to power all the speakers with the 8400. I ordered this AMP last year for my old car and never used it - it's still in the box I think ... http://www.amazon.com/gp/product/B00...ls_o03_s00_i00
The headunit really doesn't matter as to what amp you use, but that amp... doorstop. The 8400's built-in amp is probably just as powerful. If you're powering stock speakers, the built-in amp is fine. If you're doing aftermarket speakers, the power needed varies based on what speakers you put in.
Old Oct 4, 2012 | 02:10 PM
  #174
Dwalt024's Avatar
What amp would you recommend that would then be able to power the bluetooth phone reception to all the speakers as the stock system i only hear audio out of one speaker (front passenger side).
Old Oct 4, 2012 | 07:20 PM
  #175
The 8400's built-in bluetooth will go to all the speakers, the factory bluetooth adapter won't be used at all.
Old Oct 5, 2012 | 09:49 AM
  #176
horseshoecrabs's Avatar
Old Oct 5, 2012 | 11:15 PM
  #177
RA0523252's Avatar
I saw in a previous post that someone listed everything they will be buying with this headunit......
But could someone please list everything I would/should buy for this headunit for a 2007 Coupe? Thank you
Old Oct 5, 2012 | 11:49 PM
  #178
post number 133
This is everything you need for aftermarket radio conversion Wrathernaut's Double Din Shopping and Resource List
https://g35driver.com/forums/audio-v...urce-list.html.
Old Nov 2, 2012 | 10:27 AM
  #179
broke_as_ajoke's Avatar
My question is.. I just got this unit the other day (have not installed yet) and i'm trying to figure out.. the app feature.. I have an andriod (samsung galaxy s3).. will i be able to use the apps on my phone with this unit.. I read somewhere if you buy the cable for the unit.. it will allow you to play movies and music that is on your phone directly to this unit (8400bh). Is that true or false?
Old Nov 2, 2012 | 11:12 AM
  #180
Dwalt024's Avatar
@ Broke as a Joke
I ahve an SG3 too so I am hoping for a fast response as my radio comes in today as well...
