Diy: Sticky For Window Motor Repairs/door Panel Removal
Old Nov 4, 2011 | 06:07 PM
  #331
blAk mAx's Avatar
Wouldnt go up today. Worked after a few slams. Cleaned it up a little just in case.
Old Nov 24, 2011 | 01:34 PM
  #332
bor99's Avatar
How much is the motor at oreillys?
Old Nov 24, 2011 | 01:58 PM
  #333
blAk mAx's Avatar
Old Nov 24, 2011 | 02:10 PM
  #334
saywat?'s Avatar
^its about $150ish with lifetime warranty
Old Jan 23, 2012 | 02:54 PM
  #335
Z 2 G's Avatar
where is the best place to order these?
I just tried fixing my passenger side and this time it doesnt work and the copper piece wont fit back in for some reason and it shows to sign of power
Old Jan 23, 2012 | 03:16 PM
  #336
g35man04's Avatar
CLUB MODERATOR
the copper part will always go back in..that means you dont have it set right for it to slide back into place. You can order from autozone, advance auto parts, and so forth and they charge you a core....you take your bad one back and they give you the core charge back.
Old Jan 24, 2012 | 01:29 PM
  #337
Z 2 G's Avatar
HELP!!!!!
My passenger side window is completely dead!
I just bought a new window motor and it doesnt show any sign of life..
I tried using the passengeer and drive side window button and and still does nothing.
The passenger side unlock button still works if that means anything.
I also unplugged and cleaned all electrical parts..
WTF is going on!:ico n07icon25:
Old Jan 24, 2012 | 01:30 PM
  #338
saywat?'s Avatar
^i believe both switches need to be plugged in in order for either one to work
Old Jan 24, 2012 | 01:33 PM
  #339
Z 2 G's Avatar
Both are plugged in, I just tried pressing the button from the driver side for the passenger and it does nothing. Also, the passenger side window button does nothing. No sign of the motor moving even after a brand new motor
Old Jan 24, 2012 | 01:34 PM
  #340
saywat?'s Avatar
check fuses?
Old Jan 24, 2012 | 01:35 PM
  #341
Z 2 G's Avatar
good idea. where are they located?
Old Jan 24, 2012 | 09:09 PM
  #342
Z 2 G's Avatar
I cant put the copper piece back into the motor. is there a certain way to put it back in? im so close to it fitting snug but i have literally been trying to do this for 4+ hours
Old Feb 1, 2012 | 05:22 PM
  #343
Tri-GunSlingEr's Avatar
Originally Posted by Tri-GunSlingEr
The reset procedure has you do part of it with the door open, then has you close the door and do it with the door closed. I did it just like that and several times and the up/down little notch works fine... sometimes but as I mentioned in one of my previous posts, this issue has the door actually losing power "sometimes" when closed past the interior light switch being tripped although not always. I can turn the car off, then on again and the passenger window will work fine only to stop the next day or the next time I turn it off and on. I am almost 100% positive that this is a relay/switch issue and the only reason I'm still dealing with it is because I don't know which one to replace since several threads show that it could be the driver side relay controlling the passenger side relay. One day I'm just going to break down and buy both of them.
I finally figured out why my windows weren't working after replacing the motor and switch and wanted to share my experience in case it happens to anyone else. - So when I installed my front door speakers I ran some serious 12gauge stinger pro double coated wire to the door components. Following the DIY thread from here I was able to cut out the harness sections and run the wire. Because the wire was so big I had to cut out a decent portion of the plastic harness and I was super careful not to mess up any other wires. HOWEVER, one thing I didn't think of was the impact having all that extra wire inside the loom that goes from the chassis to the door would have on the other wires inside. What was happening is whenever I opened/closed my door past a certain point it was breaking connection on one of the power wires going to my window switch which is why the switch would only have power when the door was all the way open. So in case this happens to anyone else check your door loom.
Old Feb 2, 2012 | 11:21 AM
  #344
g35sleeper123's Avatar
So I had my door panel off to do my actuators, and when I put it back on the passenger window won't go up and down with the switches. It will go up and down when I open the door but the switch does nothing. I haven't had any problems with it not working before or being slow. It makes no noise and the door tapping doesn't work as well as the window reset. What switch is broken? All the connections looked fine.
Old Feb 4, 2012 | 02:12 PM
  #345
So while i was doing my door lock actuators I decided to clean my window motor. Last time I had the panel off the window stopped working except for going up and down a little when I open the door but it would not go up or down with the switches. But now that I cleaned the motor it won't even go up or down a little when i open the door. Help!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
