DIY Cam Position Sensor Easy Version
Old Jul 8, 2012 | 10:29 AM
  #181
vette87's Avatar
20 Year Member
Q40
I just wanted to say thank you to the OP. I had the P0345 code and sure enough it was the sensor.
vette87
Old Jul 10, 2012 | 03:22 PM
  #182
G35-31's Avatar
did anyone have a problem witht he bank 2 clip not clicking in? mine isnt clicking to secure it its just pushed on
Old Jul 10, 2012 | 03:29 PM
  #183
saywat?'s Avatar
^does it secure tho? as long is it doesnt come apart when u pull it i wouldnt worry about it
Old Jul 10, 2012 | 04:46 PM
  #184
G35-31's Avatar
I can pull it off just by pulling the wires
Old Jul 10, 2012 | 04:49 PM
  #185
saywat?'s Avatar
oh double check make sure theres not some small debri in the plugs blocking it from going in all the way. check the plugs for deformaty too
Old Jul 10, 2012 | 06:13 PM
  #186
cvipgo's Avatar
Here's how the connector should lock-
The green tab in center of the connector should be forward when unmated, when you mate the connector the green tab should pop back which locks the connector. see second photo on no. 1 of this thread.
Old Jul 11, 2012 | 05:25 PM
  #187
G35-31's Avatar
ok just changed both sides and now i got p0014 code
Old Jul 11, 2012 | 05:33 PM
  #188
G35-31's Avatar
anyone know the location of this ?
Old Jul 11, 2012 | 07:26 PM
  #189
cvipgo's Avatar
P0014 INFINITI - Exhaust Valve Timing Control Performance Bank 1
Since the exhaust valve timing control solenoid valve uses oil flow to control timing, dirty oil can cause the valve to stuck open or close. Before replacing the valve, change engine oil and filter and reset engine code.
Old Jul 12, 2012 | 09:12 AM
  #190
one2nite's Avatar
i have an extra connector for bank 2. i had the same problem and ordered 2. I used 1 still have the other. pm me if you want it
Old Jul 16, 2012 | 02:45 AM
  #191
G35-31's Avatar
changed oil and reset code its back now , down low the car has no power cant even break tires loose and there bald lol . but hats next? do i just replace the sensor?
Old Aug 22, 2012 | 07:43 PM
  #192
IVAN S.'s Avatar
How do i chceck if any of the sensors are Bad im in California and any mecanic shop would charge you up to 50dls to scan your veihcle. any suggestions finding the bad sensor?
Old Aug 22, 2012 | 07:48 PM
  #193
cvipgo's Avatar
GO to Auto zone or any auto part (Firestone, Pep Boys) etc they will do it for free.
Old Aug 23, 2012 | 02:09 PM
  #194
Silver tiburon's Avatar
People are obviously not even reading anything that's been written here. Why would you even go out of your way or deal with any parts store when you can check codes yourself in your driveway? Page 1, post #4...
https://g35driver.com/forums/5765264-post4.html
Old Aug 31, 2012 | 06:12 PM
  #195
miketyler's Avatar
Any other comments on the aftermarket sensors? I know one person said theirs didn't last two days. Just curious.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
