Easy Ecu Resetting
Old Apr 14, 2008 | 01:10 PM
  #421
RicoG35x's Avatar
resetting ECU...
I was initiated into the mystical "Service Engine Soon" indicator fraternity... I just wanted to mention that after fudging multiple attempts to get the resetting process down.. I figured out that in the beginning when you turn the ignition to the "on" position.. the procedure states to wait 3 seconds, then pump the accelerator 5 times within 5 seconds.
I found this "5 times" actually needs to be completed before the warning chime that comes on when you first turn the key, stops... it was only THEN that I was able to successfully get the ECU reset process to initiate properly.. I was able to reproduce this several times after that.
This seems to be the critical timing metric... if you are not through the 5 pumps of the pedal before the chime stops... nothing happens! So you can use this as your timing referance.
I just thought I would pass that along to those that can't get this to work... saves having to reset the clock and radio stations after having the battery disconnected overnight!
Old Apr 24, 2008 | 04:19 PM
  #422
WYTE-G's Avatar
what would be the point of resetting it? what do u get out of that?
Old Apr 24, 2008 | 07:26 PM
  #423
425skyline's Avatar
500 hp gain right off the bat
Old Apr 25, 2008 | 01:09 PM
  #424
ISMSOLUTIONS's Avatar
Pretend it's Windows - consider the once in a while Reboot!!!
Also - some 1st post advice - read a bit, you'll know why....
And oh yea - 500HP at the minimum...add about 600ft/lbs of torque too.
Old May 1, 2008 | 08:33 PM
  #425
officerdbag's Avatar
R.O.F.L
Do you guys think doing this ECU reset right before a 1/4 drag race would help? Like while you're waiting in the staging lanes?
Old May 2, 2008 | 09:05 AM
  #426
SixFive's Avatar
It won't hurt to do a reset - but you should test it with runs before and after a reset. I did it before driving 45 miles to the Atco NJ track and ran my best time of 14.2 @ 97.x. It seems to be about the transmission as much as anything. Also, I think you run a tad more rich after a reset so breathing mods may wake up for the time being.
Old May 11, 2008 | 06:29 PM
  #427
jrdemers's Avatar
All, I had been having trouble with the tranny lagging to shift into gear after a hard stop - this seems to have fixed it! The shifting is better than before - it always seemed to lag.
Old May 11, 2008 | 11:00 PM
  #428
Sagemark's Avatar
ya ok.. not going to spend hours sitting in my car flooring my gas pedal while the car is off.. lol... didnt work sorry
I didn't expect much but when I read this thread I went out and tried it. Worked first time! Not sure it did anything though. Seems a little better maybe but can't rule out placebo effect.
Old May 14, 2008 | 03:41 AM
  #429
KSWAY's Avatar
Wow this actually works.
Old May 15, 2008 | 02:59 PM
  #430
c4m's Avatar
c4m
Im about to go try this. how will I know if I was successful? Any indicator lights flash up or anything?
Old Jun 7, 2008 | 02:20 AM
  #431
mannys_g35's Avatar
HELP!!!! my car was working fine all day until i installed my stillen damper today, now i turn it on and on the first try it turns off. could this have anything to do with me disconnecting the battery????
i would really appreciate it if anyone can help me, thanx
Old Jun 20, 2008 | 03:10 AM
  #432
parklife's Avatar
I did the easy reset. I did it the 1st time with practice in my room before that . My car got 28k on it and i never reset the ECU, ooo boy i can feel the difference. The throtle feels much better.
Old Jun 20, 2008 | 10:42 AM
  #433
KSWAY's Avatar
The throttle response does feel a lot more aggressive. But it seems like it goes away after a couple days of driving Or maybe it's just because I've gotten use to it . But it does wok.
Old Jun 20, 2008 | 10:58 AM
  #434
en4cer's Avatar
I've been thinking about doing this reset. My question is, are you guys getting worse gas mileage afterwards? Anybody check that?
Old Jul 10, 2008 | 04:17 AM
  #435
fabcas311's Avatar
finally done this to my 06 Z....after trying 20X!lol......i actually got better gas milage after the reset...
