All Stillen Supercharger Owners Report Here
Dec 6, 2006 | 07:45 PM
  #166
Quote: Safe is ~11.2-11.8 at WOT.
The stage 3 runs safe but is maxing the fuel pump and injector. There have been some blown engines with the stage 3. I would consider upgrading your pump now. If you are going to stick with the stage 3, go with a walbro 190 and if you may go to stage 4 go with a 255.
As for the boost, that is the first time I have ever seen a stage 3 run that high.
i agree with tim,i think the gauge is not reading right.i never sall 8 psi with my stage 3 and with stage 4 im seeing a max of 8.5 psi,but my a/f is between 10.8-11.5 at wot.
Reply 0
Dec 7, 2006 | 12:31 AM
  #167
Yeah I did some research and found out about my problem.... Im gonna give stillen a call tomorrow and see if i can get the red one. I had this for about 1500 miles and luckly no problems... Good thing i got those gauges installed
I havent been driving my car hard lately and dont plan to till I get this fixed. I'll report back if anythings up
Reply 0
Dec 12, 2006 | 12:40 PM
  #168
Hey guys....
I talked to Stillen and theyre now sending me the red pulley..... Gonna have it installed right when I get it and then get a dyno. I'll report back with some numbers as soon as I can
It seems that my air/fuel ratios are okay..... Its just I dont like the idea of over boosting when im not supposed to be.
Reply 0
Dec 14, 2006 | 12:52 AM
  #169
Got my numbers in!
1. 2004
2. Coupe
3. 5at
4. Stock 17's
5. 298hp
6. 268lb ft
7. Dynojet
8. Stage 3
9. Greddy Sp2 mufflers (don't know if this counts)
Would I get more power if I change my cat back with this supercharger?
Got the gold pulley switched out for the red one. Boosting at 7lbs now with perfect a/f ratio
Reply 0
Dec 14, 2006 | 03:15 PM
  #170
Yes an exhaust will help.
Those numbers seem a little low for a stage 3.
Reply 0
Dec 14, 2006 | 07:05 PM
  #171
Hmm I thought they were average since im an Auto with no big exhaust mods. If anything I think my tq numbers are low. Im still satisfied with the supercharger though
Edit.... tq = 268 lb ft
Reply 0
Dec 15, 2006 | 11:01 AM
  #172
Quote: Hmm I thought they were average since im an Auto with no big exhaust mods. If anything I think my tq numbers are low. Im still satisfied with the supercharger though
Oh, you are an auto. OK, those numbers are good then.
It sure is a fun ride.
Reply 0
Dec 15, 2006 | 02:34 PM
  #173
Has anyone gotten any squealing from the pulley that actually drives the supercharger? im talking about the one sitting on the nose, the top most one. mines making some noise and i dont know how to get rid of the noise because its not a loose belt, i already tried tightening it.
Reply 0
Dec 15, 2006 | 04:08 PM
  #174
Quote: Has anyone gotten any squealing from the pulley that actually drives the supercharger? im talking about the one sitting on the nose, the top most one. mines making some noise and i dont know how to get rid of the noise because its not a loose belt, i already tried tightening it.
mine has done that twice in 3 years,you have to replace the belt even if it dosent look worn.the belt is just to little for the s/c and it gets abused easily.
Reply 0
Dec 15, 2006 | 04:42 PM
  #175
i just replaced it 3 months ago. i actually sprayed some wd-40 on the pulley itself and not the belt and the sound went away for a bit.
Reply 0
Dec 16, 2006 | 07:42 PM
  #176
I have never had a problem with that one.
If it's not the belt it may be the bearing. If the belt has been too tight, it can cause the bearing to wear out prematurely.
Reply 0
Dec 16, 2006 | 09:34 PM
  #177
its happening every day now, i left a message for sam at stillen so hopefully he gets back to me
Reply 0
Dec 16, 2006 | 10:34 PM
  #178
so i tried taking off the pulley and its not even possible because then i try to take off the nut, the entire bolt rotates and so i cant get to the bearing to see if its worn
Reply 0
Dec 16, 2006 | 10:55 PM
  #179
I don't think the pulley on the snout comes off very easily. I'm sure Sam will get to yo on Monday.
Reply 0
Dec 17, 2006 | 01:26 AM
  #180
Are you 100% sure it is that pulley?
Reply 0
