G35 & G37, Coupes & Sedans
Everyone: Check Your Oil!
Rating: Thread Rating: 5 votes, 4.80 average.
  #1336
Old 08-03-2009, 11:28 PM
SER-G35's Avatar
Originally Posted by EncoreCestMoi
You got ripped. All oil changes under the OC test are covered under warranty and the tsb. This is not a dealer gray area. they have to do it for free.
go back and rip the service manager a new one for thinking you are stupid, then call infiniti customer care and report what they did.
There are some really shady infiniti dealers out there. Kind of surprising. Luxury division dealers acting like private used car dealers.
MotherF***rs that's why I hate dealing with the stealership...and I had done my 60k service like a week ago at R&D Factory and the stupid dealer did an inspection and said I needed the 60k service..I laughed in my head when he said that...thanks for the heads up bro..
  #1337
Old 08-04-2009, 12:05 AM
PTownG's Avatar
it's only the beginning, Tsb says one oil change then measurement. Do not let car out of your sight when you go back. Insist it stays in the staging area and tests are done with you there. bring your own ruler. If they tried to charge you for the oil change to start the test they are looking to deny you.
Read the tsb and don't let them deviate. Verify their readings in front of them, don't let them put anything other than what you saw on the work order as far as readings go and definately watch out for the dump a quart in top off and not say anything on the test about it.
They get to measure, they don't get to add oil unless it is a case where you are approved for a new engine and they are just adding until the new long block gets there.
  #1338
Old 08-04-2009, 12:27 AM
SER-G35's Avatar
So should I print out the tsb and take it with me to show???
  #1339
Old 08-04-2009, 12:48 AM
V35 Skyline GT's Avatar
6MT Coupe
^I always had my copy with me in case they started getting stupid in the head.
  #1340
Old 08-04-2009, 03:07 AM
NVM's Avatar
NVM
NVM is offline
My friend and I were in stop-n-go traffic today on the way from firsco, so i saw this infiniti dealership off the freeway, and told my buddy to stop over.
I walked around for a bit and brought up the OC problem with the MT's and they flat out denied it; said they heard nothing of the sort... never replaced any engines...nothing.
I was hoping to speak to these openly, and truthfully about my circumstances regarding how this would go about being fixed since it's a used vehicle, but I'm guessing these guys are full of ****...
  #1341
Old 08-04-2009, 12:49 PM
Jederino's Avatar
Shady Dealers?
I still don't get why the dealers would be all shady or dense about this? Should we ask to see the measurement after the oil change, and then at the conclusion of the test? I wouldn't have expected games from them!
  #1342
Old 08-04-2009, 07:12 PM
Gr8speed68's Avatar
Cause there not going to get there full rate for switching the motor thats why....not as much money unlees u wood pay....
  #1343
Old 08-16-2009, 04:05 PM
stoofpilot's Avatar
What's Engine Difference Between M/T and A/T engines
Is the oil consumption issue only with the M/T engines? Why should there be a difference in engines due to different transmissions??
Thanks
  #1344
Old 08-16-2009, 07:41 PM
Gr8speed68's Avatar
REV uP MORTORS..
  #1345
Old 08-16-2009, 09:09 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
It's only SOME of the Rev-up motors. Mine has 82K on it and I use a 1/2 quart in 7500 miles.
  #1346
Old 09-12-2009, 08:44 PM
Parasite.13's Avatar
thanks for the sticky. i really freaked out when i first read this (right after i bought my G ) and i checked oil every 400 miles so far (drove 2200 miles since last oil change) and its still on high. guess my engine is fine. its a 04 g35x
  #1347
Old 09-12-2009, 10:58 PM
timgiffin's Avatar
Originally Posted by V35 Skyline GT
Part number I had is still valid. Part number 'tim' gave is valid too. Here's why.
# 10102-AM8M1 = 03-04 6MT's only.
# 10102-AC3M1 = 04-07 5AT's only.
What about part number for 03 5AT's? Bare long block not offered from my source.
OEM part number look-up:
http://www.infinitipartsusa.com/part...gOEM&siteid=55
V35 FYI:
The, # 10102-AC3M1 engine that was installed in my G was for a 6sp manual!(?)
Here is the end run: @ 2500mi on the new engine, and its breaking in strong. I added: Stillen exhaust, ACT SS clutch, AEM CAI, adjustable Cobb Tuning (for PCM). The Mods are cool. Stillen, AEM, Cobb: Awesome! ACT clutch has great performance, but noisy!
Buy the way V35, all that noise...was...coming from the ACT clutch.
  #1348
Old 09-14-2009, 02:55 AM
Aznteazer's Avatar
i went to Riverside Infiniti and whenever I went back to get my oil level checked, they ALWAYS top it off. This does NOT make sense since they are measuring by the millimeters, and a little more oil they put in can make the difference of whether I get a new engine. I'm almost at my 70k mark and they said my oil was only 19mm low or something so my engine is "fine".
  #1349
Old 09-14-2009, 10:14 PM
timgiffin's Avatar
Be Careful Here!
Legal help is available. I would suggest you make it known to Infiniti that you are prepared to take action if necessary. Review my past post and you will find the links. If you have any questions, let me know.
Tim
  #1350
Old 09-19-2009, 02:31 PM
6MT Coupe
Originally Posted by timgiffin
V35 FYI:
Not according to that oem part look-up link I gave. Don't know what else to say.
Good to hear breaking-in strong and liking your mods.
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
Quick Reply: Everyone: Check Your Oil!
