Everyone: Check Your Oil!
Oil sucks...
Last week my G had a strange vibration/rattling noise at start up. My first thought was that my throw-out bearing finally went bad. However, I noticed my oil light flash while pulling into my garage. It turned out that I was 4 quarts low on oil. All my oil changes have been at the dealership and within the 3750 mile interval. The car does not drip or leak a drop of oil.
After a little research and a call to Pat Goss (automotive guru and host of Goss’s Garage on 106.7 JFK) I found out that a percentage of our cars have problems with their piston rings. He told me that Nissan refuses to admit the problem and that I should be looking for a new engine.
At least I have only 15,000 miles and the warranty should apply. Let’s hope that Infiniti owns up to this problem and does not give me any s$#* for the MREV. There may be some of you out there with the same problem who (like me) can’t get a good reading because of that damn dipstick. Make sure you get this problem on record before your warranty period runs out.
I would say to be that fly that never goes away! If you back down they will think it is not that important to you, STAND FAST! show them you are not going away till you get what you are entitled to, you bought a product and a warranty and you want satisfaction, except nothing less! you did not buy a piece of crap Hundai, you bought a high class Infiniti!
So after getting my new replacement i think i've got the OC again... The service rep assured me that Nissan fixed the valve seal issue in the new engines, but with all of the reports on here of multiple replacements, do we have any clue if this has ever been fully resolved?
My oil level was very close to full the week after getting the new engine, so they put enough in initially. About a month (1000 miles) later, the oil level was was at E, so I put a full quart in thinking maybe the initial break in would use up SOME oil. Now 2500 miles into the new engine I'm back down to E!
2 quarts used up in 2500 miles? That's ridiculous again! I haven't driven it hard and haven't even had time to neglect oil changes. Taking it back in this week to start another OC test. Infiniti of Charlotte has (so far) been great about everything, but I'm starting to get fed up with the shoddy reliability of these engines...
If I end up needing a 2nd replacement is there anything I can do to get a bumped up warranty or some sort of compensation for this?
what kind of oil are you using?
ALSO!! Never use synthetic or and additives during break in, and vary the speed of the engine, do not drive hard, be careful with quick take offs.
If you have problems with Infiniti, can't you contact the Zone office and get on point with having a high quality car live up to it's reputation! Be forceful but polite and do not let them patronize you!
6MT Coupe
Here's the consumption chart for revup VQ's only TSB: ITB08-002c
BUT there's talk of a letter from Corp to dealers changing the consumption rate per miles in qualifying from what you see above.
https://g35driver.com/forums/5388640-post1295.html
ALSO...recently Infiniti has revised the TSB. Nissan has too for the 350Z's. The chart above is not from the recent revised TSB. NHTSA indicates a revision was made back 7-30-10 on TSB ITB08-002c. Have yet to get my hands on that revised TSB short of paying $$ for it, which if possible rather not.
6MT Coupe
Still not quite sure what you mean by that, but powertrain warranty is 6yrs/70K mi. unless you bought an extended warranty like I did for 7yr/100K mi.
Oil consumption? I got no stinkin consumption,,lol I checked my oil and for three months and 2000 miles..no change! I did my own trick of Full syn. Royal purple and Lucas oil stabilizer, works great in all my cars! I plan on installing an oil cooler and tranny cooler as well.
Bought my 06 G coupe about a year and half ago. It currently has 50k on it and I saw how every 1k miles it ate almost 1.5qts of oil. Took it in to south bay infiniti and they said they would do the OC test on it and to come back in after 1k miles. After a month I took it back in they told me I needed to replace my engine, they told me good thing I was under warranty and that I bought extended warranty. I was all happy to know I was getting it fix... They guy comes back out and tells me that their records doesn't show that the previous owner did any maintenance with them, so the warranty wouldn't cover since this could of happen from bad maintenance.
So I'm wondering if this happen to any else?
I am kinda disappointed since the car runs good and everything but the only thing is that I have to buy 3 extra qts of oil before every oil change...
oh yeah I also got in contact with infiniti help line and gave them my vin # and they told me they were going to search all the records of maintenance for this car, they called a week after saying that the only maintenance done to the car was the ones I did to it, including the one oil change I did at ez-lube...
HELP!!!
HELP!!!
