Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jan 19, 2011 | 03:26 PM
  #2626
TurTLe*'s Avatar
Originally Posted by Wannabe6MT
Soooooo 2 nights ago, it was about -25degrees with wind. Yesterday morning I woke up and at about 10am, went tos tart my car to drive to class. It was probably -10 then.
Started the car, turned over very slowly and the whole car started shaking Lol kinda freaked me out. Then it idled really rough and low, then just died. I was like "wtf" started it back up and it seemed to run fine albeit idling high and being very frozen.
Gave it 3 minutes to warm up, then i drove very slowly and kept the revs under 2k until it fully warmed up. Everything felt frozen, it was brutal. Tranny shifted hard, steering was hard, everything was just frozen.
Everything else I understand, but my car idling weird then dieing, that freaked me out a bit. Anyone else experience that?
you have a lot of weird things happen with that car. I dont think a normal running car should do anything you stated there other then the slow turning over. Once it turns over it should be a little loud but thats all.
Yea, its a little colder in MN then chicago but we have the lake making things worst.
Old Jan 19, 2011 | 03:56 PM
  #2627
Wannabe6MT's Avatar
-MN G Crew-
A lot of weird things which is exactly the reason I am dumping this car hahaha It started fine later on which is what I don't get. It was like the car could barely get the cylinders moving.
It never does anything weird like this unless it is really cold, so I have no clue. I just feel like my car freezes itself. It sits in an open parking lot and gets nailed by wind all day long, so who knows..
Old Jan 19, 2011 | 04:19 PM
  #2628
OKStateG35's Avatar
I don't really see anything weird about what your car did considering how cold it was. In my experience, cars always act a little funny when it's that cold outside.
Just think about how you would feel if it was -25 degrees and somebody came and kicked you in the a** and gave you three minutes to get ready to go. I know I'd be pissed.
Old Jan 19, 2011 | 04:23 PM
  #2629
Wannabe6MT's Avatar
-MN G Crew-
^ahahaha true that.
I just went and cold started my car (hasn't been run since 1pm yesterday so 26 hours ago) and it spent the night outside when it was probably -13 and today it is reaching a high of about 5.
Car started fine with what sounded like a little timing chain clatter but that quickly went away. I just drove around until the car was warmed up then parked it. Nothing out of the ordinary except the random little squeaks and rattles and it makes.
Old Jan 19, 2011 | 04:29 PM
  #2630
OKStateG35's Avatar
Yeah, mine has some nasty suspension squeaks when it's cold outside. Luckily I keep it in the garage overnight so I don't have to deal with the long warm-ups in the morning.
Mine has made the loud valvetrain chatter during start-up one time. It worried me at first, but it's only done it once in two years and all the fluids were full when I checked. Not sure what causes it, but my Explorer used to do it on every single start-up.
Old Jan 19, 2011 | 05:34 PM
  #2631
WhipWhitaker's Avatar
Originally Posted by alexh521
Can anyone tell me if this sub will fit in our rear deck?
http://www.crutchfield.com/s_130SW84...1D.html?tp=111
Dimensions-wise it seems like it would fit
but IIRC the bose woofer has 4 screw holes instead of 6
so it's most likely not gonna be plug & play.
Old Jan 19, 2011 | 05:46 PM
  #2632
Originally Posted by geoffkiefs
Factory sub only put's out minimal bass even when turned up as high as it gose, All the speakers work but there is minimal bass? is it the AMP? I have a aftermarket AMP at my house that I do not use anymore can I switch the factory AMP with the aftermarket one to get some bass back without switching all the speakers and getting a head unit and aftermarket subwoofer?
long story short, no.
the wiring for the bose amp is much different than an aftermarket amp.
Also I believe I read somewhere that you might get an overall lower than normal volume from the head unit since the bose amp increases the volume after it comes out of the unit to "reduce interference/static".
Plus you would most likely need the wiring diagrams if you want to see this through because the average person won't get very far without them.
Old Jan 19, 2011 | 08:03 PM
  #2633
thescreensavers's Avatar
Mr.202?
Originally Posted by cremaster
has anyone use Slick 50 fuel treatment before? i just picked up a bottle but haven't poured it into the gas tank yet. see any difference in smoothness in the engine?
i've had my throttle body and fuel injection cleaned back about 30k miles ago.
Originally Posted by SwivelHips
No experience with Slick 50 but personally I wouldn't if your engine is running fine. Heard horror stories about Restore; different product I know, but it seems VQs don't like additives.
Restore yep is a different product and is a completely different application. I would never use an Oil Additive.
dammit! what to do, what to do... yeah, it's running fine but thought i'd give it a little cleaning, anyway. hmmm..
Since you had a fuel injetor cleaner 30k ago its not like you have huge build up, it does not hurt to put a "GOOD" fuel system additive in the fuel. Using crap might have some issues. Many people say to put 2 stroke oil like 400:1 ratio, as gas today is very dry. the 2 stroke oil is to lube the fuel pump and it does some cleaning as well as a Upper Cylinder lube.
Anything with PEA is really good at cleaning. I personally used Redline stuff, which contains a UCL, which lubes the fuel pump, they sell it at pepboys for 8 bucks. It does not hurt at all. And It burns cleanly.
But depending on strength you might need to change your oil after, with Redline you dont have to, as it works over time of the tank.
check at 1:14
Thats why its doing that lol, Castrol Edge 5W-30 is pretty thin and flows well at colder temps.
Old Jan 19, 2011 | 08:14 PM
  #2634
cremaster's Avatar
wow, thanks so much for your help. i just wanted to make sure that putting in the Slick 50 wasn't going to cause any problems, burn funny, etc., etc. and, i JUST got my oil changed w/ Castrol Edge so i don't want to have to change it out just bc i put in the additive. so, you think i should be fine putting the stuff in and not having to change the oil w/ it?
Old Jan 19, 2011 | 08:54 PM
  #2635
NFSP G35's Avatar
? = 2B || !2B
Lots of Fords have really noisy tappets, even when they're running right.
Old Jan 19, 2011 | 08:56 PM
  #2636
HolyLover's Avatar
SO will a 04' Sedan's spring fit on an 04' coupe? Trying to lift my car back up to stock lift.
Old Jan 19, 2011 | 08:57 PM
  #2637
NFSP G35's Avatar
? = 2B || !2B
^Yes, but you'll be even higher than stock, and it will look like a 4x4 jeep
Sedan springs are usually about 1/2 inch longer than the coupes.
Old Jan 19, 2011 | 09:19 PM
  #2638
The Stimulation's Avatar
I have 06 sedan springs if you're interested
Old Jan 19, 2011 | 09:26 PM
  #2639
SN00P's Avatar
CLUB MODERATOR
yea wouldnt it lift his car up .5'' more lolol ...
Old Jan 19, 2011 | 09:38 PM
  #2640
NFSP G35's Avatar
? = 2B || !2B
^Yeah. I mentioned that.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
