Random Little Question Thread
Old Apr 10, 2011 | 01:56 PM
  #3541
NjMatteSedan's Avatar
Originally Posted by NFSP G35
If I understand correctly, it's just a fault condition. That could me too much air, not enough, or that it's not getting signal from one or more sensors
I'm not an expert on the subject though, as my car does not have TPMS (one of the very few IMO advantages of the 03.0)
Oh ok. The only things I really envy about her car are the smart key, the gauges and the clock
Old Apr 10, 2011 | 06:05 PM
  #3542
D.Reaper's Avatar
my ichiba camber arms and toe bolt kit didnt come with the template for the toe bolt...i had a friend make it for me using measurements i found online...does anyone have the real template to compare the lengths with the one i have now? here is mine for comparison thanks
Old Apr 10, 2011 | 06:42 PM
  #3543
Blue Dream's Avatar
I drove ttrank's car solo
See post #11 in this thread for a PDF you can print out. http://my350z.com/forum/brakes-and-s...-template.html
Old Apr 10, 2011 | 06:55 PM
  #3544
D.Reaper's Avatar
that's exactly where i got it from, and i got my friend to sharpen all the edges and print it out on a vinyl for me
Old Apr 10, 2011 | 09:04 PM
  #3545
WILLIE BEANS's Avatar
Quick question
My front tires on my 03 sedan are wearing on the inside .
What should I be looking for to fix this issue ?
Old Apr 10, 2011 | 09:10 PM
  #3546
VincenzG35's Avatar
A shop that does tire rotation and alignment
Old Apr 10, 2011 | 10:18 PM
  #3547
davidxu's Avatar
^ and get an alignment asap
Old Apr 10, 2011 | 10:25 PM
  #3548
CG4DR's Avatar
anyone happen to be selling HFCs?
Old Apr 11, 2011 | 08:54 AM
  #3549
Thanx guys il be getting an alignment today
Old Apr 11, 2011 | 09:00 AM
  #3550
VincenzG35's Avatar
No problem....anyone wonder what an OEM grill would look like with a flush illest badge
Old Apr 11, 2011 | 09:42 AM
  #3551
^ would look ugly
Old Apr 11, 2011 | 01:52 PM
  #3552
4DGS's Avatar
A what?
Old Apr 11, 2011 | 06:18 PM
  #3553
so i found out i have a broken rear end link , ughhh
so i picked up a set of rear beffy ones from the stealership .. 36 bucks not bad ,,
going to install them tomorrow and rotate my tires ,..,
and im going to get my lower control arm inner bushings replaced on wednesday with
whitelines.. yayy
plan on getting alignment after that .
hope nothing else needs replacing ...
Old Apr 11, 2011 | 10:26 PM
  #3554
silver9's Avatar
I have a lot of tread wear on the inside of my front tires. I was thinking that I needed a camber kit on the front but maybe I don't because of the inner wear? Also, I found a replacement drivers side fender. Does anyone have any experience with these. They all seem to be in the $150-$200 range. Thanks
Old Apr 12, 2011 | 03:34 AM
  #3555
deuce818's Avatar
19x8.5/10 +30+38
hows the fitment on these specs for a sedan? sorta aggressive? Will they fit easily? Would 9.5 be a better choice for the rear?
Thanks guys!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
