Random Little Question Thread
Old Jun 3, 2011 | 10:19 PM
  #4081
kyemaul's Avatar
Need help i have Meagan Racing street coils. I just cant seem to get everything even. How is the correct way to do this front and rear?
Old Jun 4, 2011 | 01:33 AM
  #4082
4DGS's Avatar
^ all guessing, left to right is tought as the cars tend to sag on one side. You can use a caliper to measure distance between collars or your can count threads.
Other than that, just keep adjusting.
Old Jun 4, 2011 | 01:38 AM
  #4083
SN00P's Avatar
CLUB MODERATOR
it took me a few hours to get everything perfect .. adjust put wheel on measure take wheel off and do it all over to its perfect :-)
Old Jun 4, 2011 | 01:44 AM
  #4084
4DGS's Avatar
Or if they're megans or BCs, just max em out.
Old Jun 4, 2011 | 02:03 AM
  #4085
VincenzG35's Avatar
Can some one post a pic of an installed lower control arm
Old Jun 4, 2011 | 02:12 AM
  #4086
4DGS's Avatar
what? Front or rear?
Do you just need to figure out which part IS the LCA?
Old Jun 4, 2011 | 02:27 AM
  #4087
VincenzG35's Avatar
Yea I need to I'd it if u show me a pic I can name it out of a pile of metal but installed is driving me crazy so I'd really appreciate it
Old Jun 4, 2011 | 02:29 AM
  #4088
4DGS's Avatar
Front or rear?
Old Jun 4, 2011 | 02:32 AM
  #4089
VincenzG35's Avatar
Front my bad thought I said it
Old Jun 4, 2011 | 02:41 AM
  #4090
4DGS's Avatar
The portion that the strut mounts to at the bottom is the LCA.
You can see here
Old Jun 4, 2011 | 02:45 AM
  #4091
VincenzG35's Avatar
Any other underneath pics the part I'm needing to I'd comes down like a strut/shock looks the a metal bar like the LCA and had a bushing that's long gone
Old Jun 4, 2011 | 02:52 AM
  #4092
4DGS's Avatar
Sorry it's not my picture.
What you're taking about sounds like a compression rod....
Look like this?
Old Jun 4, 2011 | 03:01 AM
  #4093
VincenzG35's Avatar
I only seen the car on a lift that why I was asking for installed pics but I'm guessing its the CR because of the way the LCA sits
Old Jun 4, 2011 | 03:24 AM
  #4094
4DGS's Avatar
Is it making a clunking sound? If so it's the Compression rod. The bushings are very well known to fail. Some guys have replaced them 5 or 6 times.
Old Jun 4, 2011 | 10:34 AM
  #4095
robbiedigital's Avatar
Originally Posted by G35Papa
One way, depending on how bad the bearing is worn, you can jack your car up on one side, leaving the wheel bolted on, grab the top and bottom of the tire and attempt to wiggle the wheel/tire. If there is play, there is a bad bearing. This is more noticeable on the rear than the front. My fronts got loud, humming at higher speeds before I replaced them.
The front is only sold as a complete assembly, hub and bearing. The rear you can purchase the bearing only and hub seperately. If you purchase the bearing alone, you need to have the old one pressed off and the new one pressed back in by your mechanic.
Thanks man. I'm hoping someone can confirm that this is actually the right part before I order it. In Toronto, I'm being quoted $240 for the hub/bearing assembly. but a place like Rock Auto is selling it for half price.
TIMKEN Part # HA590027
example:
Amazon Amazon
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
