Random Little Question Thread
Old Apr 7, 2012 | 01:17 AM
  #6091
3truman's Avatar
so as we all know excessive weight is the killer of fast cars, or cars we think are fast(g35's) lol jk
i have already considered the lightweight drive shaft and i am looking into getting light weight front seats. not sure which ones, price and look are hard to find in the same set!
Are there any other mods you guys might suggest?
my exhaust set up sure did save some weight as well as the v1 track wheels, i have a few other mods that saved a couple of lbs but not anything significant enough to notice.
when i went to the track last time i took everything out of my trunk and didn't run any faster.
Old Apr 7, 2012 | 12:40 PM
  #6092
CG4DR's Avatar
take out back seats, flywheel, wheels, change final drive, lightweight crank, idler delete...
emptying your trunk isn't enough to feel or see a difference. you have to lighten the car by 100s of pounds
Old Apr 7, 2012 | 12:51 PM
  #6093
NFSP G35's Avatar
? = 2B || !2B
^The back seats weigh very little.
Ditching your spare, jack, extra carpet/mat/etc in the trunk, and running on 1/3 - 1/4 tank will help.
Old Apr 7, 2012 | 03:48 PM
  #6094
andyrooroo89's Avatar
Alright, HID question. Im on a deployment so i cant check it out for myself... I have an 04 coupe, Which HID set do i need? I checked out the bulb replacement guide and it said the low beam has HID bulbs, so that leads me to believe i need to get the one for the fogs/highs? And if so, do i need the fog relay harness? And if all that is correct, all i would need to do is buy replacement D2R bulbs to match the new set that im buying... Thanks for your input guys.
Old Apr 7, 2012 | 07:07 PM
  #6095
CG4DR's Avatar
if you want to change the FOG/HIGH beam the proper way to use both still you will need a special kit that will either tilt the bulb or try to hunt down a dual filament HID bulb.
  #6096
CG4DR's Avatar
For the one-piece drive shaft guys... Hows the fitment? did you buy aluminum or cf? and issues? and whats the best clutch/flywheel package for a N/A build?
Old Apr 7, 2012 | 07:51 PM
  #6097
So, just to clarify, im looking for the bixenon?
Old Apr 7, 2012 | 08:11 PM
  #6098
CG4DR's Avatar
yes, i believe thats what they are called.
Old Apr 7, 2012 | 10:18 PM
  #6099
NFSP G35's Avatar
? = 2B || !2B
^I believe the H4/HB2/9003 Hi/Lo kit from DDM tuning will work with OEM high/fog functionality.
Danny (thescreensavers) would know for sure.
Old Apr 7, 2012 | 11:50 PM
  #6100
thescreensavers's Avatar
Mr.202?
^ The hi/Lo bulbs do not work. IIRC DDM says all their kits are Bixenon but I am not sure about that
At the end of my OP in https://g35driver.com/forums/media-s...installed.html it shows what happend when someone tryed the hi/lo bulbs
Old Apr 7, 2012 | 11:53 PM
  #6101
NFSP G35's Avatar
? = 2B || !2B
^How are yours setup right now? Do you just have fogs only, no highbeams?
Old Apr 8, 2012 | 12:05 AM
  #6102
Mr.202?
^ Yep just fogs only
Old Apr 8, 2012 | 10:08 PM
  #6103
NjMatteSedan's Avatar
What happens if i install heated mirrors on a sedan that came with nonheated mirrors? Will the power functions still work?
Old Apr 8, 2012 | 10:34 PM
  #6104
Trickstyle's Avatar
ooh same with the coupe, my 03 coupe has non heated mirrors...
Old Apr 9, 2012 | 03:12 PM
  #6105
jgitt's Avatar
Originally Posted by mpugeda
jgitt, it's possible that the complaints you read about were due to user error... upon cleaning it/re-oiling it, some people don't read the directions and either put too much or don't allow enough drying time.
I use Apexi's "power intake" drop-in dry filter. Bought it off Concept Z Performance for 27 bucks, works for me.
Thanks for the info! Would you recommend a K&N or your Apexi drop in filter? I know everyone is going to cringe when they hear this but when i go home on weekends i drive about 1.5 miles on gravel road. I go SUPER SLOW though so it doesnt hurt anything but that may affect your advice on which air filter i should use.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
