Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old May 1, 2012 | 07:29 PM
  #6256
TunerMax's Avatar
G35
The reason it could be the emergency brake shoes:
The shoes are cable activated. They don't actually brake, the only time these do anything is if you try and move the car without releasing the ebrake (we've all done it), or if your cable is sticking, which is very common as these car's get older.
Personally, I have a sticking right rear that I just found. It only sticks after sitting for a while (overnight). Though it's most prominant in the first movement, under 10 miles/hr, it still sticks ever so slightly after that, and that wears the shoe down.
Over time, this effect will cause the shoes to wear to the rivets, this can happen super fast actually, as the amount of pad on the e-brake shoes is next to nothing when they're brand new.
This isn't to say this is your issue, at all. Just something to consider.
It IS a rotational (speed dependant) noise, right? It gets more frequent the faster you drive?
Old May 1, 2012 | 08:18 PM
  #6257
4DGS's Avatar
Anybody have any idea what happened to the OEM from lip for Nismos? Did they make it or what? I really want one.
Old May 1, 2012 | 08:34 PM
  #6258
thescreensavers's Avatar
Mr.202?
FYI: If anyone was looking the Pin/Clip that holds the 5AT shift **** is part# 34922-AC50A
Old May 2, 2012 | 04:00 AM
  #6259
dominate's Avatar
If I get the 19" M45 Sport Package wheels, I plan on getting spacers, but I would also need extended lugs also, correct? And I don't need extended studs? Also do you guys think these no name brand ones should be fine, or would you recommend going with something like Rays? These are only 25% of the price of the Rays...thanks http://www.ebay.com/itm/RED-20-EXTEN...ht_2270wt_1270
Old May 2, 2012 | 07:49 AM
  #6260
NFSP G35's Avatar
? = 2B || !2B
I think Eric has one, but it only fits certain ones
Old May 2, 2012 | 11:14 AM
  #6261
SuperTrooper699's Avatar
I got a question if I got 350z struts and dropped my front like 2.5 and the rear 1.5 would they blow out quick ? I can't really affored a front camber kit and coils so I'm trying to get by with a camber kit and some springs.
Old May 2, 2012 | 12:04 PM
  #6262
TunerMax's Avatar
G35
This is a hard question.
Are you saying you'll be dropping 2.5"//1.5" from STOCK G35 Sedan height?
If so, then you should be ok with the 350Z struts for some time, assuming the struts are new. If they're used it's anyones guess.
It's important to note that spring rates are as important as the drop amount, if not more so.
The damper/spring need to be matched to some extent. If you're running spring rates close to the 350Z rates, and the drop is within 1" of stock 350Z height, then you'll be ok.
It's when you waiver more than 1" and also waiver in spring rate that you're asking for troubles.
Old May 2, 2012 | 01:30 PM
  #6263
Yes I will be dropping that much from stock. I have 350 s techs up front now and z springs in back with my stock sport struts. I wanna drop the front another inch on some springs and get a camber kit if I can get away with not having to buy tokico dampers. Then throw my s techs back on the rear. If I have to then I might as well get coils but I don't have the money to do it. So your saying the lower the spring the more stiff they need to be?
Old May 2, 2012 | 01:42 PM
  #6264
Like how do I rate my drop to spring rates over 1" ? Is there a table or comparison of suspension drop to spring rates of how I can determine what I need? I'm not that worried about ride quality It doesn't have to feel like I'm riding in a caddy. I jist don't wanna struts blowing out too fast or any other issues with the car. Thanks for your help bro
Old May 2, 2012 | 06:01 PM
  #6265
TunerMax's Avatar
G35
No not really, they just need to match the Damper (strut).
Some helpful explainations about spring rate:
"Spring Rate is the amount of weight needed to compress a spring a certain distance."
"Springs are rated in LB/in (in metric system kg/mm)
"This is How many pounds of weight are required to depress the spring by one inch. "
"To convert LB/in to kg/mm international, you must divide divide figure by 56."
EX: Consider you have 2 springs having different spring rates: One with 345 g/mm and the other with 480 g/mm. So what does it mean?
It means the 1st spring will compress 1 mm if you put a load of 345 grams, while the 2nd one will not. The 2nd one will need a 480 g. load to compress 1 mm.
According to this, we can say that the 2nd spring is harder than the 1st one, or we can state that:
"Springs that have a low Spring Rate are soft, while springs that have a high Spring Rate are stiffer."
As for the spring rates, I couldn't find stock rates fast but rest assured, that info is on my350z, of that I have no doubt. This thread is close:
http://my350z.com/forum/brakes-and-s...d-reviews.html
Basically, you'll want to find the stock 350Zspring rate and match it as close as possible.
If you're lowering 2.5" from stock G35 sedan height, that's only 0.5-1.0" off the stock 350Z height. This means, you're putting springs that are 1/2-1" lower than intended for those 350Z dampers (struts).
This is a great set-up, that should ensure you don't roast your struts quickly. However, you are still lowering your car siginifigantly in all other aspects, so you do need a front camber arm, and rear camber arm with some toe bolts.
You'd need these with coils also, so may as well just get them.
Old May 2, 2012 | 07:55 PM
  #6266
dominate's Avatar
Anyone have advice for me? Thanks
Old May 2, 2012 | 08:36 PM
  #6267
TunerMax's Avatar
G35
any spacers require longer STUDS
you can buy spacers that have studs built into them though, if you wish.
Your lug nuts themselves should not change, unless your rim lug nut style is different, ie. aftermarket 'tuner' style, or Shank style, like many new OEM rims are.
Old May 2, 2012 | 11:24 PM
  #6268
Eye Eat Ketchup's Avatar
i have an 06 sedan. how can i tell if i have sport suspension? anyone know where i can buy 350z struts?
Old May 3, 2012 | 09:07 AM
  #6269
mpugeda's Avatar
^ here you go: and uhhh, try the Z marketplace?
Originally Posted by 06G35Coupe94
This might seem like a really stupid question but I need to know. I have an 06 auto Coupe that I bought a few months ago. How do i know if its the sport or base version. Im guessing base since its an auto but I want to know for sure. Again sorry if this was a stupid question...
if you googled your own question you would have gotten the same result I did.
anyways, read this.............................................. .................................................. ......
https://g35driver.com/forums/buying-...t-package.html
Originally Posted by lelg35
The 05 sports sedan sports package does come with 18s. Anything less and it probably not the sports package. They are a split 5-spoke design with an Infiniti center cap. The 17's are a 7 spoke design. Also, the sports package brings a sports suspension. Make sure your shock absorbers are a red in color. Sorry, I don't have any pics right now to post.
Originally Posted by jawjaw
Wheels are the obvious clue but anyone can mount sport wheels on a non sport car. If you are actually able to see the vehicle, I believe the sport has different color shocks - red I believe.
Yes, the sport suspension brings red shocks and struts. Look for the red shocks/struts, 18 inch split 5 spoke wheels, and another clue, it better have the aluminum trim on the inside. The sport package can't be had with wood. I would say almost everyone has the alum. trim, but thought I'd mention that just in case. If you see wood, it surely didn't come from the factory with the sport package.
Old May 3, 2012 | 12:02 PM
  #6270
NFSP G35's Avatar
? = 2B || !2B
That's for an 05. 06s are different
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
