Random Little Question Thread
Old Sep 20, 2012 | 05:42 PM
  #7261
dofu's Avatar
20 Year Member
Originally Posted by DVG
That is a very small disc for 2 calipers....especially when cross drilled that much.
Did someone seriously do that?
Yea, those calipers look pretty small at that. But those Evolve big brakes are just like having two big calipers, using 4 brake pads each caliper. So why not opt for two large calipers instead?
Old Sep 21, 2012 | 09:00 PM
  #7262
Max626's Avatar
I have the gauge cluster out to replace the mileage bulb question is how do I get to it? I saw two screws one on the top right the other top left but its still not coming apart where is the hidden lower screw???
EDIT: NVM i found out the hard way that our whole board is leds -_-
Old Sep 22, 2012 | 05:38 PM
  #7263
Max626's Avatar
I think I found out the hard way but can we drive without the gauge cluster installed?
Old Sep 22, 2012 | 06:10 PM
  #7264
AzuMaster's Avatar
I was just thinking about this yesterday. How hard is it to change the color of the cluster gauges in the 06-07 models? Is it the LEDs or is there an orange film on it like the 1st gen models?
Old Sep 22, 2012 | 11:25 PM
  #7265
TunerMax's Avatar
G35
it's LED.
Never drive without it.
I had some INSANE shyt happen on my 2001 Maxima driving with the cluster out, including frying the trigger to the entire audio unit 'somewhere' in the car.
I'll never drive with a cluster out again.
Old Sep 22, 2012 | 11:29 PM
  #7266
thescreensavers's Avatar
Mr.202?
Has anyone installed AUX through the SAT connector? How was the Audio Quality?
Old Sep 22, 2012 | 11:50 PM
  #7267
Max626's Avatar
Originally Posted by TunerMax
it's LED.
well my car cut off I'm on my way back with the cluster wish me luck.....
Old Sep 23, 2012 | 12:33 AM
  #7268
AzuMaster's Avatar
it's LED.
So just for confirmation because I can be slow at times... The 06-07 cluster gauge has ORANGE LEDs in it and not an Orange Film behind the display like the 1st Gen models. If I hope it up I can just swap out the LEDs for whatever color I wanted? Does the same go for all the orange glowing interior lights? I've seen 2 kinda/sorta DIYs in the tech area but they were both on the 1st Gen models.
Old Sep 23, 2012 | 01:41 AM
  #7269
Max626's Avatar
Pretty my all the LEDs are orange expect for open door, check engine ect...
Old Sep 23, 2012 | 09:21 AM
  #7270
terryphyo's Avatar
hi guys, i'm looking for a original BOSE amplifier with socket attach, to use on my 2001 nissan skyline V35 sedan. if any one have it plz let me know. thz
Old Sep 23, 2012 | 05:37 PM
  #7271
TunerMax's Avatar
G35
1. this is the sedan 03-06 section
2. 1st gen sedan was 03-06
3. 1st gen coupe was 03-07
These 3 facts make what you wrote impossible to understand. you're suggesting you have a 2nd gen g35? That would make it at least 2007 (sedan) or 2008 (coupe), either way, NOT a 2006.
In either case it's LED's. I just don't know the 2nd gen setup. And you need to calibrate and remove needles on any G35 to do this customization, then reassemble.
Old Sep 23, 2012 | 05:38 PM
  #7272
TunerMax's Avatar
G35
Ok, I was going to measure this but I've been swamped and I need to order these:
What size are the stock Wheel studs? I want to order 10mm larger Studs, but I don't know the stock size.....
Old Sep 24, 2012 | 03:18 PM
  #7273
g35_white's Avatar
what is the correct wiper blade length for 2005 g35 sedan? is it 24" or 26"? please advise. thank you
Old Sep 24, 2012 | 03:31 PM
  #7274
mcdizzle's Avatar
anyone know where to get center caps for Rays lexion 203 wheels? a couple of mine have broke and no longer stay in the wheel
Old Sep 24, 2012 | 04:12 PM
  #7275
Reedtc's Avatar
Has anyone ever heard of this? I want to put an intake on my 04 g35x But I can't seem to choose one.
Suggestions? http://www.horsepowerfreaks.com/part...RO_DRY_S/19034
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
