Bank 1 VTC Cover Removal
Old Jan 1, 2023 | 12:33 PM
  #136
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Never go full Tropic Thunder.
Old Apr 9, 2023 | 07:06 PM
  #137
JHAGAN's Avatar
Change the solenoid, I found the part on carparts.com..$20 had to replace the vtc cover (driver side) since the bolt was welded in from years of heat.. $40 more bucks.. runs just like 07.. reset light with EUC machine...
Old Apr 15, 2023 | 12:25 AM
  #138
Emmanuell's Avatar
Infiniti G37x A/T Auto
Originally Posted by Ragnar Lothbrok
yes, its very tight in there. I did have to bend that shield out of the way a little bit and I moved the PS pump up and out of the way. I used a 1/2" drive with a long extension then the swivel then the socket. I can try and recreate it later this evening and take a pic but that's it in a nutshell. Don't feel alone, I cussed at those two bolts and the design engineers for a couple of hours before I got them off. Your almost there, forge on.
did you have to remove or move that flat metal plate with a wire and plastic piece in it?
856_reilly
Oct 7, 2011 12:46 AM
cliffords
Aug 7, 2009 02:00 PM
04Gwhiz
Oct 30, 2006 07:59 PM
Julian
20
Feb 10, 2006 02:03 PM
BombRush
Sep 16, 2004 01:27 PM
