New DIY mod: 2007+ Altima "Fat Boy" exhaust tips
Old Nov 15, 2007 | 05:05 PM
  #91
STLTHSDN's Avatar
Originally Posted by GixxerSteve
I'm interested to know how you can base this as fact. When I look on everythingg35.com, they have two seperate parts listed, one for Altima 2.5 and one for Altima 3.5. Also, if your statement were true, that would mean the exhaust pipe for the 3.5 V6 is the same as the 2.5 4cyl; highly unlikely. I'm eager to see what information you have for us.
Neighbour has a 3.5 altima. i ordered the 2.5 ones, when i got them we looked and they were identical. at least thats here in Canada anyway. i cant speak for what the USDM one has. at any rate IMO your better off with the 2.5 tips and cut em like Dave said. mine worked awesome! while you have em off id spray the exhaust "can" with a semi gloss engine enamel in black, MADE A HUGE difference in the look.
Old Nov 16, 2007 | 02:17 PM
  #92
SLOTOY1269's Avatar
I Just Picked My 2.5 Tips The Pn Is 20080-ja000. While I Was Leaving I Looked At New Cars With 2.5 And 3.5. The 3.5 Inner Pipe, The One We Cut, Is Obvioulsy Bigger. I Didnt Measure It, But I Think It Could Be The One We Need.
Old Nov 16, 2007 | 03:19 PM
  #93
SLOTOY1269's Avatar
Nissan Part Numbers
2.5 Tip Is 20080-ja000 The 3.5 Has Two Depending On Build Date 10-06 Till 08-07 Is 20080-ja100 And 08-07 And Up Is 20080-ja10a.
Old Nov 16, 2007 | 03:50 PM
  #94
DaveB's Avatar
I'd just stick with the 2.5 tips because I know for a fact that they work with 5 minutes of simple modification. The 3.5 tips may not give the same tight fit and may require a bit more modification.
Old Nov 22, 2007 | 04:04 AM
  #95
GixxerSteve's Avatar
Just to clear up any confusion that might have been floating around, the tips for the 2.5 and 3.5 are not the same. I received my 3.5 tips today. The outside diameter is the same, but the inlet diameter is definately bigger. See picture below.
Even though the 3.5 inlet is bigger, it still doesn't fit on the muffler outlet without cutting!! I tried to do just a few cuts, but it still didn't fit. So I ended up making all six cuts like the OP. It fit okay, but I added a little JB Weld to make sure it doesn't come off by accident.
Attached Thumbnails New DIY mod:  2007+ Altima "Fat Boy" exhaust tips-img_0020.1.jpg
Old Nov 22, 2007 | 05:20 AM
  #96
perry05G35's Avatar
^that's good info to know I brought a pair and haven't seen if they are the 2.5 or 3.5 looks like the 3.5 would be a better pick though...
Old Apr 7, 2008 | 08:10 PM
  #97
NathanJax's Avatar
..... I WIN .....
So I bought these and did this over the weekend. I did a few things different though. I cut out the ENTIRE inside of the pipe and welding them on. Also, instead of them sitting flush with the muffler, they sit straight out. If they are flush, they will point up a little bit.
Difference...
Before
After
Before
After
Add another mod to the list...
Old Jul 23, 2008 | 10:25 PM
  #98
GF-4D-G35's Avatar
Thank You
Dave,
Thanks for posting up about this option. I recently lowered my car and squashed my old tips backing down a driveway. I ordered these, they were cheap, they fit, and they look nice.
Old Jul 23, 2008 | 11:27 PM
  #99
lerk's Avatar
Anyone willing to buy the tips and fit them so I can just put them directly on? I am willing to pay.
Old Jul 23, 2008 | 11:47 PM
  #100
GF-4D-G35's Avatar
It is way too easy. Order the tips online. Use a dremel to cut out the solid part. Remove your old tips. Slide on new tips. You should be able to stop there. Even if you have to buy a dremel it would still be worth it.
I myself am going to get them situated just right and then use some JB Weld to really fix them in place.
Old Jul 24, 2008 | 05:49 AM
  #101
lerk's Avatar
I might just do that then. Where are you gonna pick up the tips online?
Old Jul 24, 2008 | 08:52 AM
  #102
Skaevod's Avatar
Old Jul 24, 2008 | 02:36 PM
  #103
pickrice's Avatar
what tips are those?
  #104
dmitriylm's Avatar
Originally Posted by Skaevod
That looks terrible.
Old Jul 24, 2008 | 04:20 PM
  #105
jnmunsey's Avatar
Isn't this one of those mods you'd see in the 80s on Sentras?
