350Z HR Y-pipe installed on a 2003 G35
Old Sep 1, 2009 | 01:38 AM
  #571
clarkkent06's Avatar
I'm sure the dealer would be able to get them, other than that I'm not sure. I left them on, but read some posts back, I think DaveB was saying something about vibration when cold or something?
Update on mine, I've been driving it around for a bit, definitely feel more low/mid torque. It feels much easier to drive, I love it. It also did add a nicer throatier sound, which is awesome. Definitely a worthwhile mod!! I haven't taken it much over 4.5k, as my clutch is dead and starting to slip a bit (from the previous owner) and I'm trying to baby it until I get my ACT clutch installed.
Old Sep 1, 2009 | 10:50 AM
  #572
rob40wilson03's Avatar
im too lazy to backtrack through the thread to find out..... which version of the HR pipe did you get?
Old Sep 1, 2009 | 11:05 AM
  #573
My post is just 4 posts up. I got the HR pipe from a 2007 350z
Old Sep 1, 2009 | 12:14 PM
  #574
oh ok.... im hoping the one im getting from a g37 gives me similar results
Old Sep 2, 2009 | 11:17 PM
  #575
str3zz's Avatar
Picking it up tomorrow for a whole set of stock 08 350z cat back includes y-pipe and midpie for $50 .... am I lucky or what . Question .... does anyone know if I still need the extension to install the z midpipe to sedan or with this new setup of y-pipe i don't need it anymore???
Old Sep 2, 2009 | 11:21 PM
  #576
Damn great find!!!
I don't fully understand your question...you have a sedan? This Y-pipe is exactly the same length as the stock G y-pipe, so all it does is replace that part, the midpipe is the same, etc.
Are you talking about running the full Z cat back? You'll need an extension as the Z is 8" or so shorter than the G.
Old Sep 2, 2009 | 11:24 PM
  #577
str3zz's Avatar
yep that's what i mean. oh well i got appoitment with muffler shop anyway tomorrow to add extension to the midpipe by molding it with some extra pipe so i guess still have to do that tough i can save some bucks right there hahaha
Old Sep 2, 2009 | 11:25 PM
  #578
You could always use your stock mid-pipe...someone with a sedan would have to chime in, but I wonder if there are performance benefits from using the 350Z HR mid-pipe/muffler over the stock DE mid-pipe/muffler. I have no clue.
The Y-pipe is definitely different (obviously), but not sure about the rest.
Old Sep 2, 2009 | 11:28 PM
  #579
str3zz's Avatar
well i want it sounds and i know for sure if using coupe or z midpipe will give the wot sounds and now since i just found this thread about the y-pipe might as well change it too .... i can't wait to see my car tomorrow after the installation. Oh i'm still keeping my stock muffler though ..... ... no money for HKS yet
Old Sep 3, 2009 | 12:30 AM
  #580
Swivel's Avatar
Moderator
str3zz, do the Z midpipe, too. World of difference in the sound, even with the stock muffler.
Old Sep 3, 2009 | 07:41 AM
  #581
str3zz's Avatar
Yes sir
Old Sep 3, 2009 | 01:22 PM
  #582
str3zz's Avatar
Thumbs up
Finally project for HR y-pipe and Z mid pipe is all done.
Got the 2008 350z Y-pipe, Mid pipe and Muffler for $50 from someone don't know anything about how valuable the stuff is and that make me lucky
So here is couple pictures of the set on my car. I went to muffler shop and have them cut the mid pipe section and add extension to it to make it fit to the stock muffler.
Here is the picture of the stock muffler
Here is the picture of the HR y-pipe and midpipe before they cut it
Notice that gap in there between the muffler and midpipe. Now is where they cut it and add extension to it.
I Love the sounds of it and I haven't test drive it on the highway but i can tell there is a little push on the lower rpm and less lag on it. This is AWSOME MODE I HAVE EVER DONE WITH TOTAL OF $50 + Install $80
Old Sep 3, 2009 | 01:33 PM
  #583
LightsOut's Avatar
SIETESG
looks good
but why does the extention look as if its a larger diameter pipe.
noticed in your sig.. you have 06 coupe seats. does the memory seat function work.
Old Sep 3, 2009 | 01:38 PM
  #584
str3zz's Avatar
I got the coupe seats from Ttrank and this one doesn't have memory seat only power seats that's all. it's pretty confy and hug more.
the pipe is a little bit bigger just to join the two pipe and weld it there. it's pretty clean looking after they done it.
Old Sep 4, 2009 | 12:35 PM
  #585
str3zz's Avatar
Talking
Got the sound from my Iphone ... not the greatest since the Muffler tip also rattle probably because is more power coming to it ... just need to tight it down i guess ...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/0da8PS3QnGk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/0da8PS3QnGk&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Here is another video I took from my Digital Camera ... Not greatest sound either but noticed that the muffler blew the camera away a little bit
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/c_8HogaINFQ&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/c_8HogaINFQ&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Here is the Stock sounds before the installation. Bye Bye Stock Muffler Sounds
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/GpAscyOhRFE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/GpAscyOhRFE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
