350Z HR Y-pipe installed on a 2003 G35
Old Dec 17, 2009 | 11:14 AM
  #631
bina12834's Avatar
cool...thanks for the info
now to get a y-pipe...i already have WTB's on both here and my305z.com
Old Dec 17, 2009 | 11:21 AM
  #632
LightsOut's Avatar
SIETESG
try craigslist or ebay as well. dont pay over 100 unless shipping is involved
Old Dec 17, 2009 | 11:25 AM
  #633
bina12834's Avatar
yea i checked ebay and all i saw was aftermarket ones....ill have to give craigslist a shot.
update...craigslist was a crap shoot...guess ill just have to keep my eyes out on my350z
Old Dec 17, 2009 | 12:42 PM
  #634
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by bina12834
ha!....yea, for starters i dont have a inch/lb wrench (i know i know theyre only a few $$ at an auto parts store, but im just too lazy), and i also would like some help on this install since i havent done anything like this before, and its too cold out right now....lol
i figure if im going to get some help with the spacer install, might as well use the help on the y-pipe install too...and maybe the HFC's if i have those before i decide to throw all of this on.
will i need to reset my ECU after the y-pipe and spacer install?
I hear you. You don't have to have a torque wrench though, just use a nut driver and hand tighten. That will put you somewhere around the 90 in-lbs spec. Go back in a week or so and re-tighten. I knew nothing about our motors when I installed my spacer and it took me less than an hour. Really simple but I'd recommend researching at least 1 DIY before you do it. Y-pipe is simple as well. You just need a jack and stands, or wheel ramps. The only problem you might run into there is rusted bolts. Here in Texas that isn't an issue.
One good thing about our cars is they are usually really easy to work on for most things.
Old Dec 17, 2009 | 12:46 PM
  #635
bina12834's Avatar
true that...i figure having an torque wrench laying around cant be a bad thing, so im probably just going to grab one anyways. guess i should get some jack stands or wheel ramps for the same reason....cant hurt to have them lying around.
Old Dec 17, 2009 | 02:27 PM
  #636
Blue Dream's Avatar
You'll get a ton of use out of a jack and stands. Oil changes, belt replacement, brake work, headlight replacement, suspension work, exhaust work just to name a few. Any standard jacks should work, just make sure they're rated high enough to support a 3500 pound car. I bought mine at Sears and paid under $30 per pair.
Old Dec 17, 2009 | 02:30 PM
  #637
bina12834's Avatar
i dont do any of that work myself so i wont get THAT much use out of them, but im looking at this pair of 3ton stands from amazon... $30 shipped
Amazon Amazon
Old Dec 18, 2009 | 08:04 AM
  #638
migueralliart's Avatar
I purchased a 370 y pipe and just measured the pipes. The two inlets are 1 - 3/4" and the outlet is ~2.5" , are these the same measures you guys had with yours. What are the dimensions of the outlet of the OEM catalytic? , I have a 03 6mt coupe btw.
Old Dec 18, 2009 | 08:50 AM
  #639
bina12834's Avatar
if i remember correctly the 2 inlets on the 350z HR y-pipe should be 2"
Old Dec 20, 2009 | 04:40 PM
  #640
tyeayo's Avatar
woo hoo!!! Just scored my hr y-pipe from an 08 350z for 85 bux!!!
Can't wait to put that sucker on.....its a good week for the g...spacers are on the way (should be here tomorrow), new headlights are in, eyelids on here, tailight nightshades tint is here and now this....!!
YIPEEEE!!!
Old Dec 25, 2009 | 01:49 PM
  #641
thescreensavers's Avatar
Mr.202?
Larger pic
What type of HR-Y Pipe is this? It has those Pucks, but it looks thinner and the flex pipes are shorter, and the pucks are on thin pieces of metal...
Any one have an Idea?
Old Dec 26, 2009 | 03:24 PM
  #642
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by officerdbag
Ok so my HR pipe SAGS big time.. I didn't care at the time after the installation but its really pissing me off is it always scrapes on bumps and inclines.. Makes me want to take it off. AHHH
Anyone else have this BS happening to them?
Nope mine sits 99% flush as it did with my DE pipe. I do see a small sag on mine though.
(yes those are scrape marks/dents on body underneath...bad day...long story...)
Is your mid pipe connected to it's support hanger?
Old Dec 26, 2009 | 03:55 PM
  #643
6MT Coupe
Originally Posted by thescreensavers
Larger pic
Going to say yours the VQ37 from what I've read here and looking at mine from a 07 VQ35HR Z (on right) with longer flex lines and heat shield a little different than yours.
Old Dec 26, 2009 | 04:30 PM
  #644
Black Acc's Avatar
Did any of you guys change the gaskets or use your stock ones? Also my bolts are rusted to crapp, any suggestions? I planned on using PB blaster. Did any of you with rusted bolts keep the same bolts or did you put new ones in?
Old Dec 27, 2009 | 03:50 PM
  #645
Tollboothwilley's Avatar
just use PB blaster every 10 mins for 3 or 4 times before you get going. You can even use it the night before. The longer it sits on the rusted nuts the better.
I reused my bolts back when I used the 350Z HR y-pipe.
