350Z HR Y-pipe installed on a 2003 G35
Old Dec 28, 2009 | 07:19 AM
  #646
Blue Dream's Avatar
I drove ttrank's car solo
I just used the stock gaskets with no problems.
Old Dec 29, 2009 | 04:02 AM
  #647
Tunerz_Store's Avatar
Originally Posted by thescreensavers
Larger pic
What type of HR-Y Pipe is this? It has those Pucks, but it looks thinner and the flex pipes are shorter, and the pucks are on thin pieces of metal...
Any one have an Idea?
It is the g37 Y pipe.
Old Jan 11, 2010 | 06:18 PM
  #648
isaac012's Avatar
Is a 370z y-pipe as good as a 350z hr y-pipe? Or should I hold out for a 350z hr y-pipe?
Old Jan 11, 2010 | 06:35 PM
  #649
BonBG35's Avatar
its good.
Old Jan 11, 2010 | 06:40 PM
  #650
thescreensavers's Avatar
Mr.202?
IMO hold out for an 08/07 350z pipe, they are the correct ones. The G37/370z Y pipes have smaller diameter piping.
Motordyne said that slightly larger piping would yield HP. The Correct HR Y has a larger diameter then the DE Y pipe.
Since most people sell the G37/370z/350z/07+Sedan HR Y Pipes for around the same price, I would just hold out till you found a correct one.
One thing I did to find one was to look at this http://craiglook.com/all.html?q=350z+exhaust and just Email all the 07/08's if they want to part out or what not.
Old Jan 11, 2010 | 07:19 PM
  #651
isaac012's Avatar
So you don't think there's merit to this argument that the smaller diameter gives you better low end while sacrificing some high end? My main goals are sound, better throttle response, and low end. There's a guy locally who is selling his 370z y-pipe for pretty cheap ($60). That's cheap, sure, but if it's not what I want, it's still money down the drain!
Old Jan 12, 2010 | 01:24 PM
  #652
Mr.202?
I noticed better low end when I installed my 350z Pipe as well as high end.
The 370z/G37 Pipe I heard gives better low end because of the smaller piping, so more back pressure. With I guess a highend hit.
Your choice.
Old Jan 14, 2010 | 11:13 AM
  #653
Swivel's Avatar
Moderator
This was my question, too. I wonder if smaller-diameter piping yields better exhaust-gas velocity. What I really wonder is if there's even a detectable difference between the G and Z pipes. I'd prefer more benefit on the low end, so I guess the G unit would be my choice.
Old Jan 17, 2010 | 02:08 PM
  #654
Viscous's Avatar
noisy Y
I picked up a 350 HR-Y a while back and it's been making a minor hissing/rasp sound at WOT since the install. Not sure how many of you guys are familiar with the old 4th gen Maxima's and the y-pipe hissing issues of yore, but I've got a similar 'bees in a can' sound at WOT as I did with an old Cattman pipe. I was hoping that it would go away with time and use; it has to a certain extent, but not 100% gone. Have any of you other guys with HR Ys heard any audible sounds that were less-than-pleasant upon adding the Y?
My headers are probably contributing to some of the issue by changing up the airflow dynamic. Anyone else have a similar setup? DC headers, oe cats, 350HR Y, oe b-pipe, oe muffler.
Old Jan 17, 2010 | 06:33 PM
  #655
AARONHL's Avatar
Yea, I've noticed the hissing at WOT. My Maxima's Y-Pipe back in the day hissed ALL THE TIME...
Old Jan 18, 2010 | 12:04 AM
  #656
Mr.202?
No hissing here
Old Jan 18, 2010 | 10:35 AM
  #657
V35 Skyline GT's Avatar
6MT Coupe
Same here...no hissing or bees in a can here either. Maybe your y-pipe heat shield vibrating.
Old Jan 18, 2010 | 12:55 PM
  #658
DaveB's Avatar
I haven't noticed any "bees in the can" with my HR y-pipe and this is coming from a guy that owned a fairly modified 96 Maxima. I do notice that the HR y-pipe does have a bit more metallic "ringing" when the pipe is cold.
Old Jan 18, 2010 | 03:50 PM
  #659
adamhoud's Avatar
Isn't it just the gasket not sealing properly?
I know I started getting this after replacing my cats and y pipe, I think its because I reused the cat-y pipe gaskets.
Old Jan 18, 2010 | 08:11 PM
  #660
thumper10s's Avatar
Just wondering if there are fitment issues installing hr ypipe on an 2004x? I am looking, but cant find any definitive answers.
thanks
also bidding on the ypipe on ebay
item states 06+ but it looks like the right part-any opinions are appreciated
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMEBIDX%3AIT
