350Z HR Y-pipe installed on a 2003 G35
Old Apr 6, 2011 | 10:53 PM
  #826
WhosRich's Avatar
Originally Posted by DrewLe
Is it one of the dampers? I had a vibration and rattle from mine two weeks after I installed it, also occurred during the warmup. I just simply bent it back into place.
Thanks for the reply. Which dampener are you referring to? On the muffler?
Old Apr 6, 2011 | 11:01 PM
  #827
DrewLe's Avatar
There's two somewhat rubber dampers on the HR Y-pipe itself. When I heard my rattle, one of them was bent into the Y-pipe itself, touching it and causing it to rattle. It's not supposed to be touching so I simply bent it back into place to where it wasn't touching the y-pipe.
Old Apr 6, 2011 | 11:04 PM
  #828
WhosRich's Avatar
Oh, is it those 2 hockey puck looking things? I gotta jack my car up and check it out. No wonder I can feel the vibration under my feet.
Old Apr 6, 2011 | 11:23 PM
  #829
DrewLe's Avatar
Yes, those two hockey puck looking things. It took me a couple weeks to isolate the rattle. Check the nuts too since you'd be under there to see if your exhaust leak theory might be true also, I've never heard one either lol.
Old Apr 6, 2011 | 11:24 PM
  #830
WhosRich's Avatar
Got it. Thanks for the tip dude. Hopefully thats the issue.
Old Apr 6, 2011 | 11:26 PM
  #831
DrewLe's Avatar
No problem. Hope that solves your rattle issue.
Old Apr 18, 2011 | 06:52 AM
  #832
mysoda's Avatar
is it hard to in stall the y pipe and the mid pipe? can it be done with only 1 jack with out help of extra hand?
Old Apr 18, 2011 | 01:15 PM
  #833
almost3flips's Avatar
It can be done but it would be easier if you had jack stands on both sides. The hardest part is taking off your oem exhaust because of all the rust, so a breaker bar and pb blaster/ wd40 or something to help loosen the bolts would help significantly
Old Apr 18, 2011 | 05:43 PM
  #834
mysoda's Avatar
this may be a dumb question. do the all 07-08 350z has the same hr y pipe regardless the model of the 350z?
Old Apr 18, 2011 | 05:46 PM
  #835
Swivel's Avatar
Moderator
^^ I think so, because they all have the HR engine. Before that was not HR and after that were 370s..
Old Apr 19, 2011 | 03:16 AM
  #836
mysoda's Avatar
thanks swivelhips
Old Jun 1, 2011 | 12:45 AM
  #837
CandlestickPark's Avatar
ill Sedan
Sticky.
Old Jun 9, 2011 | 08:19 PM
  #838
screwby25's Avatar
question.. i realize that those hockey puck things are for NVH... so what happens if i remove them? car gets louder? will there be rattling?
Old Jun 9, 2011 | 08:38 PM
  #839
Swivel's Avatar
Moderator
^ No but you can score two goals.
Old Jun 20, 2011 | 01:37 AM
  #840
_G35_'s Avatar
I need to find one of these bad, if anybody knows someone that is selling one, PM me pricing on it please
