Rev-Up airbox on a VQ35DE - special note
Old Aug 11, 2009 | 05:51 PM
  #301
Jeff92se's Avatar
Red Card Crew
I thought it was low to mid 13s?
Old Aug 11, 2009 | 05:53 PM
  #302
OCG35's Avatar
on Dereks track it would be.
By the way – what does your car run Jeff?
Old Aug 11, 2009 | 06:00 PM
  #303
Jeff92se's Avatar
Red Card Crew
It would run the number indicated up above when I passed though the timing lights at the end of the track. Why?
Old Aug 11, 2009 | 06:03 PM
  #304
Jeff92se's Avatar
Red Card Crew
And I dont care whether they listen to me or not... but I'll make sure I continue to correct the wrong info that gets posted by you and others.
Better get in that HR Y pipe thread asap. It begs your attention
Old Aug 11, 2009 | 06:52 PM
  #305
OCG35's Avatar
I'm evoking the DaveO 30 second rule. I've wasted far too much time on this...
Old Aug 11, 2009 | 07:19 PM
  #306
BuckeyeInMI's Avatar
but I will remind you again I stated that Buckeye was inaccurate with his post stating mpg is lower on Stillen and the blanket statement that OEM is a better air box... it inst the case on my car.
Which, of course, isn't what I said, but you seem to like paraphrasing people so you can make your point better instead of quoting them accurately.
Originally Posted by BuckeyeInMI
I think if anything you'll get slightly worse mileage with the Stillen intake because of potential heatsoak issues.
Not exacly "mpg is lower". You haven't shown it to be inaccurate, other than to tell us of the ridiculously short trip you based your "similar mileage" claim on. You know, the one where I pointed out the numerous variables that weren't accounted for? DaveB also pointed out several potential fuel/air/timing changes that can occur because of the Stillen while standing still, all of which can affect gas mileage, and none of which you've countered. And if you'd studied statistics at all you'd know that 100 miles is grossly inadequate to base any claim on.
Here's another paraphrased mis-quote by you (a common theme I've noticed.)
The stock airbox is a very efficient unit, and is as good as or better than any aftermarket intake short of FI or SC.
"As good as or better" is not quite the same as "OEM is a better airbox". Another statement of mine you haven't shown to be inaccurate. Please try and read all the words I write instead making up something "similar" that fits your side of the discussion.
BTW, unless the original questioner had the same setup as you, your experiences with the Stillen aren't really that relevant. The Stillen may work better for you, but that doesn't mean it will work better for him with his near-stock setup. My suggestion to him was to save the money from the Stillen because it would be a waste and better spent elsewhere. That's still true. Or do you think he will benefit from it over the OEM?
I agree on the wasted time. No point in listening to someone blather on and call people stupid when all he's got to fall back on is his butt dyno regarding the intake's effectiveness.
Old Aug 11, 2009 | 08:10 PM
  #307
OCG35's Avatar
Old Aug 12, 2009 | 11:57 AM
  #308
Jeff92se's Avatar
Red Card Crew
His summary seems logical to me?
Old Aug 12, 2009 | 01:32 PM
  #309
OCG35's Avatar
https://g35driver.com/forums/4467589-post306.html
Old Aug 12, 2009 | 02:03 PM
  #310
Jeff92se's Avatar
Red Card Crew
https://g35driver.com/forums/4467646-post307.html
Old Aug 12, 2009 | 02:04 PM
  #311
Jeff92se's Avatar
Red Card Crew
I don't see a problem with this.
Old Aug 12, 2009 | 04:17 PM
  #312
OCG35's Avatar
^^^huh?
Old Aug 12, 2009 | 06:26 PM
  #313
naughty240's Avatar
I run fabric softener sheets taped directly to a pvc pipe. Can I jump in this argument?
Old Oct 20, 2009 | 12:20 PM
  #314
dbroncos's Avatar
How do you install the Rev-up Airbox on a sedan with the stock oem airbox?
Old Oct 20, 2009 | 02:46 PM
  #315
OCG35's Avatar
simply uninstall the current box an remove back half (as if you are changing the filter) and replace back half with the revup version - re-install as normal.
