Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Jun 27, 2011 | 06:49 PM
  #2221
Quote: Not sure if this is the right place to ask, but don't see a point in starting a new thread...
I'm looking for some new lug nuts but I don't wanna spend 200$ has anyone tried to ebay ones...
http://cgi.ebay.com/ebaymotors/20PC-...#ht_5771wt_941
http://cgi.ebay.com/ebaymotors/R-MUT...#ht_6028wt_941
How is the quality? I dont want them breaking off while driving
Ebay always relates to.... you get what you pay for. No guarantees with that **** so if you have to ask, you probably shouldn't... Order Blox lugs. They about $85-$100
Quote: Got all 4 fenders rolled today for 100$. Dude was legit, knew his **** really well.
Hooray no more rubbing :]
Good to hear, $100 is the right price. Exactly what I charge for all 4 corners.
Quote: Im -3 rear no probs got a question on fronts will be at +2 on 19x9.5 with a 22535 stretch as soon as my kics 10mil come.. has anyone done this without front fender roll.. as it sits now it looks like it will work?
You won't have an issue. Just make sure you pull out the screw at the top of the fender that holds the fender liner in, because if anything is going to rub it's going to be that.
Reply 1
Jun 28, 2011 | 12:05 AM
  #2222
ok so idk if this is the best place to put this...maybe the random q thread...but i feel this is the best spot since you guys are the best when it comes to wuestions about wheels. my buddy has a B6 audi A4 quattro and he is looking to get new wheels. he is thinking about getting 18x10 all around. do u guys know what offsets he would need and also what tires he would need. he wants to have them as flush as possible. once again idk if this should be asked here but any help would be appreciated. even fowarding me to someone on here that has an A4 and would know.
Thanks
Reply 0
Jun 28, 2011 | 12:11 AM
  #2223
Could send JBF a message or even Green Goblin as they both own Audis as well.
But from my experience with A4s a 10" wide wheel is getting pretty aggressive for them. Roughly a +30 offset on there would be solid (little higher up front) and maybe some 255/35s or something along those lines would be somewhere to start.
Tell him to search up on Canibeat and hellaflush and what not for some specs for B6s and go backwards from there. If he needs a hand converting things point him to this thread or just keep asking in here and I'll help you out as best I can.
Reply 0
Jun 28, 2011 | 10:40 AM
  #2224
Hey guys, I have a 08 sedan that is bone stock. I have OEM 17inch wheels with 225/55 R17 rubber.
I was wondering what the largest width tire I can put on these wheels (no plans to change them yet). I would like to avoid rubbing or having to roll the fenders.
I have used the Kumo Ecsta's on my CTS and like those, but any guidance or suggestions would be great.
Reply 0
Jun 28, 2011 | 10:52 AM
  #2225
Those wheels are only 7.5" wide. I wouldn't recommend putting a fat tire on the thin OEM wheels...
Largest you could do is maybe a 255/40.
Reply 0
Jun 28, 2011 | 11:03 AM
  #2226
Quote: Those wheels are only 7.5" wide. I wouldn't recommend putting a fat tire on the thin OEM wheels...
Thanks for the info.
I didnt realize they were that narrow. A 255/40 may be what I look at for now.
I need to do some more research on this thread. Wondering, if I do go ahead and put some wheels on it, what would be a reccomended setup that would not put me in a tailspin of other mods (suspension, etc). I was thinking 19's.
Reply 0
Jun 28, 2011 | 11:20 AM
  #2227
Since you're keeping the 17" rims and they're 7.5" wide 245/50 is the largest tire you should run and this size will maintain the correct diameter. Over sized tires on narrow rims can be dangerous on the highway. Search "Tire Size Calculator!"
Gary
Reply 1
Jun 28, 2011 | 01:47 PM
  #2228
You guys think it'd be worth it to get Tein H-Techs for the G coupe? $180 seems worth it for a brand new set of springs. Really need to take away from the huge stock gap.
I need an alignment, so if i put the springs in and then went to the dealership to get one done, should I have a problem with too much camber? Don't wanna eat my tires up but also dont wanna spend a ton on a camber kit just yet.
Reply 0
Jun 28, 2011 | 02:31 PM
  #2229
Quote: Since you're keeping the 17" rims and they're 7.5" wide 245/50 is the largest tire you should run and this size will maintain the correct diameter. Over sized tires on narrow rims can be dangerous on the highway. Search "Tire Size Calculator!"
Gary
There's guys on here running 275/40 on 8" wheels. I wouldn't recommend the 50 profile sidewall because then the sidewall will have more give (being much taller than the 255/40) hence why the 255/40 is the biggest you should go, the smaller sidewall will add rigidity opposed to the fat sidewall of the 50 profile.
Quote: You guys think it'd be worth it to get Tein H-Techs for the G coupe? $180 seems worth it for a brand new set of springs. Really need to take away from the huge stock gap.
No you won't have an issue with alignment but you'd be wasting money.
$180 + $100 (Align) + potential install fee.
You're into almost $300 to lower the car like an inch. Save up another couple hundred bucks for coils if that's the route you plan to go.
Reply 0
Jun 28, 2011 | 03:43 PM
  #2230
Well regardless of what I do suspension wise I still need an alignment. Its needed one since I bought the car.
So I shouldn't go for a camber kit later on either? Just go for coilovers?
Reply 0
Jun 28, 2011 | 04:56 PM
  #2231
which way is forward on the hankook Ventus V12 evo K110??
Going left on this pic is forwards? and going right is reverse???
Reply 0
Jun 28, 2011 | 06:02 PM
  #2232
The arrow on the sidewall (bottom edge of the pic) points in the direction of rotation.
So forward to the right.
Reply 0
Jun 28, 2011 | 06:42 PM
  #2233
Quote: Well regardless of what I do suspension wise I still need an alignment. Its needed one since I bought the car.
I'd just go for coils man, you know you're going to want to go lower so just take it all in one swoop and deal with the fender gap for the time being. Keep an eye in the marketplace for some used BCs they pop upp for like $700 on occasion!
Quote: The arrow on the sidewall (bottom edge of the pic) points in the direction of rotation.
No... forward would be to the left. The tread is pointing downwards. Most summer tires the tread points in the direction that the tires are directionally forward.
Look at it like a boat the forward rolling part is the bow (so it CUTS through water) The rear which is flared out and fat is the stern.
Reply 1
Jun 28, 2011 | 10:05 PM
  #2234
Anyone know the wheel offset, width, tire size in order to run a fitment of -6 camber on the rear of this?
Reply 0
Jun 29, 2011 | 02:26 AM
  #2235
WTF did you just ask?
You want to know roughly what specs those wheels would be if that car had say, -6 degrees of camber in the rear?
1. It looks like excessive stretch (not needed)
2. Camber looks less than -6
3. I'd guess a 19x10.5 with a 235/35, -15 offset and maybe -5 degrees of camber tops.
Get me some more photos and I'll try and give you a better opinion.
Reply 0
