Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Oct 24, 2011 | 03:20 AM
  #2536
BlownKoop's Avatar
whats the widest wheels/tires can you put on a 04 coupe?
Im looking at these, in 20s, just not sure what width size...
http://www.onlinetires.com/products/...s/xxr/526.html
Old Oct 24, 2011 | 01:35 PM
  #2537
akoustic's Avatar
Hi Guys,
This is what I'm looking to do for my 04 G coupe with 18s.
I want to get a set of 19s without having to roll fenders... I was thinking since 05 and up come with 19 inch Rays anyway I can go with the similar sizing as that. If I'm looking at Rays TE37, what size should I be looking at?
Thanks!
Old Oct 24, 2011 | 03:16 PM
  #2538
BlownKoop's Avatar
Will i have to roll my fenders if i get the xxrs?
Old Oct 24, 2011 | 11:20 PM
  #2539
4DGS's Avatar
Originally Posted by P10 WRC
allright everyone, i need new front tires allready since i waited too long for an allignment. I have 235/35/19's on a 9 inch wheel now and am looking for advice. Once my rears go out i will get new ones back there too. for now, i want a bit more of a stretch then they currently have.
i was thinking about 225/40/19 to keep the diameter close to the 255/35s out back. once the rears go i will go with 245/35 out back. My question is on tire brand. I have found that size anywhere from $150/tire to $275/tire. The KDWs i have don't come in the size i want so i will have to change.
Are generals, hankook, or khumos okay for stretching? here are the choices on tire rack
http://www.tirerack.com/tires/TireSe...40&diameter=19
I want to stay under $200/tire
You made zero mention of what width you're stretching on.
But Generals and hankooks are both trusted to stretch.
The question is too vague to answer, Guy have fit 335s on G35s....
Originally Posted by akoustic
Hi Guys,
Thanks!
IMO roll the fenders, if you don't want to roll them the size you want is 19x9.5 19x10.5 +22 If you roll the fenders you can fit those widths with a +12.
Yes.
Old Oct 24, 2011 | 11:51 PM
  #2540
P10 WRC's Avatar
I did too say how wide the wheel was. check my post, i said a 9 inch wheel in the first post
Old Oct 24, 2011 | 11:55 PM
  #2541
4DGS's Avatar
Is the rear a 9 too?
If so, why are you stretching the front and not the rear?
Old Oct 25, 2011 | 12:49 AM
  #2542
P10 WRC's Avatar
no the rears are 10 inches with 255/35's. i may go with 245/35's in the rear too.
Old Oct 25, 2011 | 06:06 AM
  #2543
chink-ah-saur's Avatar
Ok so time for smaller rubber in the rear, right now I have R: 245/40/19 on a 9.5 +20
And wanna get some + camber goin.
So Q is should I go with 245/35 with a little pull or 235/35 no pull
Old Oct 25, 2011 | 03:41 PM
  #2544
4DGS's Avatar
For that mild of a stretch you can pick anything. You won't have an issue with them.
What's your camber at? about -2.5? What's your goal camber?
I'd do the 235/35 and keep the fenders stock. If you don't plan to go super aggressive then try to keep the fenders clean for as long as possible. Unless you know what you're doing with a roller or know somebody that knows what they're doing.
Old Oct 25, 2011 | 03:58 PM
  #2545
Thanks.
Its in the high 4s I would like to be around 2-low 3s
Old Oct 25, 2011 | 04:12 PM
  #2546
4DGS's Avatar
Hmm, it's flusher than I thought it would be for 4+ I'm -4.7 and running 18x11 +20 lol Pulled and sits the same place.
Regardless, go with the 235/35 but you're still going to need a minor pull, the stretch is only going to gain you about 6mm or so.
Every degree of camber is equal to 5mm in offset. So if you go down to -2.5+ you'll have added about 10mm of poke.
Old Oct 25, 2011 | 04:21 PM
  #2547
Hm yea I feel like I run a lot of camber for my offset..
I think ill go with 235/35 and just shoot for mid 3s
Thanks man
-brandon
Old Oct 26, 2011 | 01:23 PM
  #2548
New Star's Avatar
http://youtu.be/tZGa0CgS_jw
Old Oct 26, 2011 | 02:24 PM
  #2549
P10 WRC's Avatar
Do you think 225/40s up front would be too meaty though? according to the tire size calculator, the sidewall would be 3.5 inches which is the same as the 255s out back.
Old Oct 26, 2011 | 02:43 PM
  #2550
4DGS's Avatar
Na a 225/40 would be fine.
Newstar, what the hell are varsteons?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
