Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jun 23, 2013 | 12:48 PM
  #5806
ErikTaylor's Avatar
Sit Flush?
Sorry guys on the go and not going to be near a computer for a while. Will this set up sit flush? Stock everything.
20x8+35F
20x10.5+38R
Thanks in advance.
Old Jun 23, 2013 | 12:56 PM
  #5807
Xet's Avatar
Xet
Coupe or sedan? For a coupe +35 is nowhere remotely near flush. Coupe flush is closer to +12 to 0 offsets depending on drop, tire size, and camber.
Old Jun 23, 2013 | 01:10 PM
  #5808
ErikTaylor's Avatar
It's for a coupe. Thanks for the friendly informative reply. I thought he was blowing smoke.
Old Jun 23, 2013 | 01:17 PM
  #5809
herrschaft's Avatar
Originally Posted by ZachG35
I have a 2007 G35 with 225/40/19 in the front and 245/40/19 in the rear. I was wondering if I went 245/40/19 all around if that would screw up my handling at all?
No.
Old Jun 23, 2013 | 01:36 PM
  #5810
ItsA..Gthing's Avatar
Not even close in the front...
Old Jun 23, 2013 | 02:11 PM
  #5811
ZachG35's Avatar
Originally Posted by herrschaft
No.
Awesome, thanks for the quick reply
Old Jun 24, 2013 | 05:09 PM
  #5812
shyun1250's Avatar
Uhh... but it'll throw off your VDC if you have it....
Our cars are meant for stagger... if you want, you can adjust the profile of the tire so although you have the save width all round, you'll have the stagger necessary to keep the VDC happy.
Old Jun 24, 2013 | 05:11 PM
  #5813
shyun1250's Avatar
Originally Posted by pat2481
if i drop my car 1.6-2 inches how will my tire wear be effected?
As long as you get front and rear camber gear and a good alignment, you should be fine.
Might need some negative camber to fit a drop like that though.
Old Jun 24, 2013 | 05:12 PM
  #5814
shyun1250's Avatar
Originally Posted by Clim95
I currently have a pearl white 07 g35 coupe with 19s, im looking to buy CV3s that are going to be 20 inches, and i still want to lower it by an inch or inch an a half, what should my tire sizes be?
thanks!
Go to rimtuck.com and have a look at what some other people are running.
It really is up to personal preference so go with whatever you think looks best.
If you really want to lower it, I would stick with a 19" over a 20".
Personally I like the look of 19" much better and you will be able to lower it more.
Old Jun 24, 2013 | 05:16 PM
  #5815
shyun1250's Avatar
Originally Posted by bdubct
Im currently running xxr 521 20x10.5 +30 and 25mm spacer = +5 et all around. 245/35/20 tires. Im looking to buy a set of varrstoen es1's 18x10.5 and run no spacers but still have a little poke and that agressive look (unless you think otherwise...?) let me know what offset i should get. i have a 2003 g35 coupe black 6mt w/ bbk (brembo brakes). i need at a +12 offset or less to clear the front brakes. i would like to not run staggered, i want 10.5 all around (i would do 19x11 but theyre all out). i still plan on running 245/35 tires so i mild stretch.
so my question is what do you recommend for a good look? i want to slam it like it is now.
18x10.5 +0 no spacers
18x10.5 +12 no spacers
18x10.5. +22 with my 25mm spacer = -3 et
If you want to go down... what about 19"?
I would go with the 0 offset.
A general rule I follow is to avoid using spacers whenever possible.
also by doing so you can sell your spacers to make things a little bit better for your wallet.
As for a square set up. Having the same wheels all round is okay. but your tires will still have to be staggered to accommodate for VDC.
Old Jun 24, 2013 | 05:17 PM
  #5816
shyun1250's Avatar
Originally Posted by Crack3r
Can I put a 35 series tire on the front two wheels while having a 40 in the back?
You can but unless your planning on running the same or similar width of tire, you will not be able to achieve the necessary stagger for VDC.
Old Jun 24, 2013 | 09:09 PM
  #5817
herrschaft's Avatar
The coupes can run a square setup. I had 245/35/19 all around for over a year without issues.
Old Jun 25, 2013 | 12:38 AM
  #5818
mkstock33's Avatar
What kind of rims does this dude have on his G35?
I've been looking at these:
http://www.readywheels.com/mrr-desig...5ab19d6d8.html
http://www.readywheels.com/mrr-desig...52484159d.html
But I really like the ones in the picture but don't know what they are any opinions?
2006 Black G35x
Attached Thumbnails Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-4drmadness_vivek1.jpg
Old Jun 25, 2013 | 12:44 AM
  #5819
shyun1250's Avatar
Do you have VDC on or off?
Old Jun 25, 2013 | 12:46 AM
  #5820
TORETTO's Avatar
2006 Black G35x
They are Volk SF Winning
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
