DIY: Add a sub to your Bose equipped G35 Coupe
Old May 10, 2010 | 02:33 AM
  #436
or_G's Avatar
how much did everything cost?
Old May 25, 2010 | 03:21 AM
  #437
or_G's Avatar
i bought a sub and amp with 8 gage speaker wires.
is this all i need to install?
Old May 25, 2010 | 08:44 AM
  #438
Wrathernaut's Avatar
Gentle Manne of Leisure
I'm going to assume that's 8 gauge power wire and ground wire, otherwise that's way too thick.
I'll also assume you have a box for the sub.
You'll need regular speaker wire (14 gauge) too.
Does your amp have speaker-level inputs? If not, you'll need a line-output converter.
You also need some wire to run to the remote power signal, unless your amp has signal sensing power turn-on.
Old Jun 19, 2010 | 03:44 PM
  #439
Leb's Avatar
Leb
I have a 500/1 JL audio amp, and 2 12" w3 JL audio subs... I am installing this in the sedan, and everything went well till i turned up the volume. Every time I turn the volume over 10, the subs stop hitting. Is there a solution to this problem? Any information would be helpful. If you need any more information about the installation let me know, I would be more than happy to provide it.
Old Jun 19, 2010 | 10:37 PM
  #440
What else does your system consist of?
Need a lot more details.
Are you talking about the gain, the volume on headunit...?
Old Jul 3, 2010 | 04:17 PM
  #441
OKC2004G35's Avatar
Ok folks, I hope I am in the correct thread for this... I have an 04 G35, in which I audio aspirations for, here is my proposed setup:
Sony XAV60-Head Unit
Sony XM-ZR1252 800 watt amplifier
2 Rockford Fosgate P1S412 600W subs
Custom enclosure, etc.
Now my thing is that from reading various posts and videos, I think I want to keep the Bose- factory amplifier connected to the factory highs and mids, but I'm not sure if allowing the factory sub to remain connected is the best move? I have read that I need to purchase a Nissan/Infiniti Factory Integration Adapter, which I wire to my Sony aftermarket HU. By doing this, will that be all the additional items I need to use the factory amp/speaker connections w/o having to make costly upgrades to the whole system? I just want to make sure that if I do use the Factory Integration adapter for the factory amp, in addition to the built-in amp for the Sony HU, it won't put too much strain on my the factory speakers. I have read threads where the factory amp was bypassed and threads where it was kept in the audio system, I just need to know the best move to make, because this will probably be a DIY project. And also, what is the best move on the factory sub, I have read posts where people said they removed it to have better bass to inside compartment, what are your thoughts?
Old Jul 7, 2010 | 12:06 PM
  #442
dj codeman's Avatar
big ups on writing this!!!! Im doin this install ASAP!
Old Aug 5, 2010 | 09:37 PM
  #443
Chicago_G's Avatar
Great Write up Bro, only question i have is what color is the power on wire on the bose amp? im trying to splice into the power on wire to give power to two amps im running back there....my Set-up is:
2 Alpine Type X10's in Custom Box for the G
2 Alpine Mrd-M1005 both rated at 1035 each
Pac LC-2 Line Out Converter for Amp adjustment on Factory HU
MEMPHIS 17-0GKIT 0 GAUGE 3000 WATT AMPLIFIER INSTALL KIT.
Power Acoutik 5 Farad Cap
BTW i did the Big 3 grounding with 0 guage. (Battery to Alternator, Engine to Chassis, and Battery to Chassis)
ALL i need to know is what is the power on wire...thanks in advance.
Old Aug 6, 2010 | 03:58 AM
  #444
From the third post:
Remote Wire Light Blue/ Silver
Old Aug 14, 2010 | 05:47 AM
  #445
erral's Avatar
great writeup thanks. I want to do this too.
Old Aug 14, 2010 | 06:07 AM
  #446
Where you just put a new HU in, you're best served by just running your own RCAs from the headunit's sub outputs instead of tapping stock wires like this guide shows. It will let you control the sub output much better instead of trying to balance it with the rears solely through the amp gain.
You can still use the factory remote signal wire though.
Old Aug 30, 2010 | 04:51 PM
  #447
Cheeser055's Avatar
Hi, I just installed my pioneer 10" sub (TS-SW2501S2|S4) with pioneer 1200w mono amp (GM-D8400M) with the sub box i purchased from Zenclosures in my 2005 coupe. I'm new to audio stuff so i followed this DIY and the setup worked fine for about three weeks but i noticed while turning/accelerating the sub would kick in very loud and sometimes not with the music. The signal wasn't consistent and didn't sound very well and now I'm not getting anything at all from the sub. I took everything apart and soldered the wires from the bose harness again and made sure all the connections were good along with getting full power to the amp. The amp turns on properly but i'm not sure what else i should check to see why i'm not getting any sound from the sub. I even tried hooking up my old 12' sub to see if i got sound from that but nothing. Thanks guys any help would be appreciated!
Old Aug 30, 2010 | 05:51 PM
  #448
Likely something basic like power wire or ground location, or an audio signal wire is grounding out somewhere.
Old Sep 4, 2010 | 06:22 PM
  #449
mjholla19's Avatar
nice diy
Old Sep 21, 2010 | 01:07 AM
  #450
mindlikeskyy's Avatar
I'm about to do this next for my car
can't waitttt
cept with a 10w3
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
