Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Hey Wrathernaut
Do you think it is much more advisable to just replace the radio to one of the following instead of using the GROM USB3?
http://www.customsounds.com/product/...U#.VECBefldXwp
http://www.customsounds.com/product/...T#.VECB1vldXwo
PS. I don't need an lcd screen.
I tried the GROM, but was not satisfied on how its gonna look on the car, returning it now.
So what do you think? Do I sill need to buy a double trim for these would they just fit well? I have no NAV
First link - Kenwood KDC258U
Second link - Alpine CDE-143BT
Also thinking about these:
Kenwood KDCX598
Pioneer DEH-6600BT
Pioneer X6600BS
I am no expert on anything, only had the car for about a month or so.
Will changing the stereo affect its compatibility with the bose system (or whatever its called i sound dumb)?
The bose system is not the best of worlds but I can live with it just looking for a nice way to link phones. The grom or other adapters did not win me over because of the wires. I HATE wires. I like the idea of the usb port on the stereo.
Kenwood KDCX598
Pioneer DEH-6600BT
Pioneer X6600BS
Kenwood KDCX598
Pioneer DEH-6600BT
Pioneer X6600BS
Kenwood KDCX598
Pioneer DEH-6600BT
Pioneer X6600BS
What DD kit do you have?
I dont know if what im saying is the right terminology @@
So those receivers wont work?
Haha I'm just wondering what dash kit you have. JDM or Metra. Its irrelevant, as they both work. Just wondering.
But, yeah, if you wanna use the new stereo with the Bose equipment you need a PAC-ROEM NIS2 interface thingie. Otherwise you can just bypass the amp and use a standard Nissan stereo harness (metra 70-7550) and run the speakers with the stereo itself.
If you bypass the amp its recommended that you switch out the speakers.
Hey Wrathernaut
The ~$120 Pioneer FH-X700BT is about the same price as those ones, but has the bigger buttons and display. (and 4.5 stars with about 900 reviews
If you remove the center armrest console, and unscrew the tray the underside, you can run the wires between the tray and main console trim without making any new holes in it - there's a gap between them large enough for wires, but I don't think you can shove either terminal at the end of the cable through it.
Yeah, I definitely think replacing the radio is preferable. I'd go with a double-din non-touchscreen one if you're going for a budget install.
Hey guys,
I just bought the JDM DD non-navi for my 05 coupe along with a Pioneer AVIC-5000NEX headunit.
I havent attempted to install yet, but just to check the fitment of the the two, it looks like the AVIC -5000NEX is a little less wide and naybe an inch or two less in length, The screen is a 6.1 inch and I'm just assuming the JDM DD space is around 7 inches.
What would be my best option so I have a very clean, flush Headunit. I read about the SCOSHE aftermarket trim but I want to know if anyone has better opinions or suggestions.
Thanks,
Chris
Thanks,
Chris
All aftermarket radios are equally (un)compatible with the bose amp. Just use the same ROEM-NIS2 to keep it working.
Most people report improved sound quality after getting rid of the bose headunit and using the ROEM-NIS2 with an aftermarket radio, a few report the opposite.
Hey guys,
Thanks,
Chris
Thanks,
Chris
Filling the gap (again, direct link: https://g35driver.com/forums/audio-v...ml#post6546537) - there's absolutely nothing special about the scosche trim. The reason I recommend it is that it's cheap, should fit around the complete radio when needed without any internal cutting, and can be cut extremely easily to fill the gap on the top, bottom, or sides. Any textured black plastic can be used to fill the gap. Another option that I've used in the past is black felt. Black felt is extremely cheap, but if more than a thin amount is visible, it usually doesn't look as professional. The good part is that if you have a motorized face, you can kind of drape it behind the moving face parts, or if it's an extremely small gap, you can just wedge it between the two components to prevent squeaking of parts and keep you from seeing through the gap.
This is the main harness of my Metra 70-7550. Did they really forget a ground wire? This was sealed in original packaging and there's no black wire. Am I missing something?
Edit: nvm, I just read the back of the package. "If black wire is not present, ground radio to vehicle chassis". How do I do that? Haha
Just take the black wire from the new radio's harness and attach it (along with the other ground wires listed in my wiring chart) and secure it to a screw that goes into the metal of the chassis. The metal radio bracket works as a chassis ground.
