Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old May 2, 2012 | 03:15 AM
  #871
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by stinkytofu89
what is this double din trim ring kit? what does it look like? thanks!
From the FIRST POST of this thread. Click the "scosche trim ring" link.
From the 2nd or 3rd post of this thread, it covers the gap between the JDM trim and aftermarket radios, when said radios don't include a trim ring, or their included trim ring doesn't fit right.
Old May 2, 2012 | 06:02 AM
  #872
Blue Dream's Avatar
I drove ttrank's car solo
Update: the felt didn't work out so I just have the Scoshe in there. Still looks good.
Old May 2, 2012 | 12:30 PM
  #873
I just attached a little to the top and bottom of my Z110BT, 7" with the motorized face.
Old May 3, 2012 | 03:57 AM
  #874
lij1's Avatar
ive been searchin for the 06 wiring diagram, does it not exist?
Old May 3, 2012 | 04:21 AM
  #875
http://psedog.com/cars/fsm/g35/coupe/2006/av.pdf
Old May 4, 2012 | 04:08 PM
  #876
lij1's Avatar
i might b way out of my head tryin to tackle this bypass, but do i need to just connect all the wires from the input of the amp to the output?
Old May 4, 2012 | 05:53 PM
  #877
Yes, that's it, but if you feel way over your head, you may want to get help from somebody comfortable with it.
Old May 5, 2012 | 12:07 AM
  #878
lij1's Avatar
probably just over thinkin it right now, but once i get started i think ill b fine
Old May 7, 2012 | 11:04 PM
  #879
aptony's Avatar
http://compare.ebay.com/like/290676651533?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
is this required to use other apps through the iphone for the pioneer avh 4400?
Old May 8, 2012 | 03:08 AM
  #880
Originally Posted by aptony
http://compare.ebay.com/like/2906766...Types&var=sbar
Yes, but you're gambling with whether it'll work by purchasing one through eBay.
Old May 8, 2012 | 02:36 PM
  #881
WinnipgG35's Avatar
Yeah i wouldnt by that cable off ebay. I did for mine and its not the true pioneer cable. I emailed the seller once i had it and he said it would not be capable of playing a/v back.. I ended up paying the 60$ at visions, and just returning my look alike cable for theres..
Old May 11, 2012 | 01:15 AM
  #882
TGMcCoy's Avatar
There is not any advice on tucking the wires behind the deck? That ish is cramped back there, I almost thought I wasn't going to be able to put the deck back!!! Makes me never want to take it out again, even though I know I have to soon
Old May 11, 2012 | 01:22 AM
  #883
Top Teke's Avatar
Mmmm there is somewhere, I've read it. I laid my PAC-ROEM down flat below where the HU sits and then stuffed everything else in the slot to the back-left. Works like a charm.
Old May 13, 2012 | 10:42 AM
  #884
colosus19's Avatar
Is it possible to modify your stock AC controls for use in the double-din modification? Just cut off the bottom radio portion, remove the AC controls and use them with the JDM double-din bezel?
Old May 13, 2012 | 08:16 PM
  #885
Trickstyle's Avatar
afaik, no... the circuit board runs power throughout the whole board. so if you were to "cut" off the top you would have to do some serious work on the board. and unless you have schematics and a manual of operation, you wont know how much current and voltage is supposed to be at each semiconductor. just save yourself the $150 and buy a new one... or check the market for a used one. the dual climate control button is easy as hell to solder on too!
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
