DIY: 2006 Projector Cutoff/Color Mod
Old Jul 6, 2007 | 09:57 PM
  #151
IvoryGT's Avatar
updated with road shot on first page
Old Jul 13, 2007 | 02:38 AM
  #152
redlude97's Avatar
was playing around with the new lenses you sent me, but I can't get color all the way accross the cutoff, were you able to do this? mine tapers off towards the middle, with NO color towards the outer 1/3-1/4 of the cutoff on both sides. I think this might just be the nature of the beast, but maybe you have it figured out.
BTW, I just compared a clear lense modded projector against a stock fresnel lensed headlight and the color, sharpness, and output are worlds better, I forgot how bad the stock projectors were
Old Jul 13, 2007 | 01:28 PM
  #153
IvoryGT's Avatar
did you modify the spacer at all. If you don't they really can't get that much color out. Especially the lenses are actually made for FX. most think FX is same as G35, it's actually different at the shield, the two shields in each projectors have different distances. G35 has two farther shield where FX is closer I think..may have it backwards.
But the optics are slight different. The same lenses on FX doesnt require modifying the spacer at all.
Old Jul 13, 2007 | 01:29 PM
  #154
IvoryGT's Avatar
this is actually the result of the G with the lenses and modified shield height.
Old Jul 13, 2007 | 02:27 PM
  #155
redlude97's Avatar
So what are you doing using these lenses on both the fx's and the g35's.
For the fx, are you just bending the front shield down with the spacer in place? Are you still bending the shield into a semicircular shape or leaving it stock?
For the G35, you are modifying the spacer to allow for more upward movement of the shield, but how else are you modifying the shield?
I got pretty good results using a hybrid fx front half, g35 rear half, since then I don't have to trim the arms off, but I'll try it in a nonmodified fx next. As for shield differences. I didn't notice any, and I swapped them back and forth between the two projectors without a noticeable difference in cutoff. Let me know, these lenses have me somewhat stumped. I can't get any pics because the GF took the camera for the weekend
Old Jul 13, 2007 | 07:06 PM
  #156
IvoryGT's Avatar
something happened to my reply.
but anyway. the FX is just bent down front shield. G35 has modified spacer and shield.
Old Jul 21, 2007 | 03:27 PM
  #157
jdmeg21's Avatar
say you didn't want to play with the shileds. Could you just change the lens and still get a nicer flicker effect and possibly better light output.
Old Jul 22, 2007 | 12:00 AM
  #158
IvoryGT's Avatar
spacing the lenses don't work with the G projector.
Old Jul 22, 2007 | 02:51 AM
  #159
redlude97's Avatar
+1
Depending on the particular lense you use, lense space will produce a slight amount of color and possibly better intensity, but to really get a good cutoff, the shield needs to be modded
Old Jul 22, 2007 | 03:57 PM
  #160
jdmeg21's Avatar
ok just wanted to see how deep I had to get into this.
Old Jul 23, 2007 | 12:20 AM
  #161
redlude97's Avatar
Shield modding is relatively easy, especially if you aren't a perfectionist. You can get some decent color in under an hour of messing around with them, just follow IvoryGT's tips on the shield modding.
Old Jul 24, 2007 | 12:04 PM
  #162
05BLACK6MT's Avatar
Are those stock lens? They look great.
What's the outcome with e30 and g35? what need to be done for color and cutoff with e30?
Old Jul 24, 2007 | 12:30 PM
  #163
redlude97's Avatar
Those are not stock lenses, its a clear lense swap
Old Jul 24, 2007 | 12:33 PM
  #164
05BLACK6MT's Avatar
Thanks, I know clear lens do wonder for g35 but just want to know if it possible to do something with stock lens beside the trash can or signal light.
Old Jul 24, 2007 | 12:41 PM
  #165
redlude97's Avatar
Throw it at someone you don't like? The fresnel lenses are garbage for output, I've tried, but nothing seems to work on those lenses, the ridges are just too large
