G35 Compression Rods are Total Crap
Old Apr 16, 2009 | 11:24 AM
  #211
AARONHL's Avatar
Would worn compression rods cause you to feel the road at your feet when driving on the highway? It feels like the front end is loose, noisy, and rougher than usual when cruising on the highway.
Old Apr 16, 2009 | 11:26 AM
  #212
RiCeBrNr's Avatar
Is it the actual compression rods that wear out or the bushings? I'm just wondering whether I should replace the bushings or the entire compression rod
Old Apr 16, 2009 | 11:29 AM
  #213
RiCeBrNr's Avatar
An interesting picture I found showing the suspension
Old Apr 16, 2009 | 11:53 AM
  #214
AARONHL's Avatar
Has anyone replaced just the bushing? I want to review the Technical Service Bulletin when I get home because I think it states to only replace one of the two bushings.
Old Apr 16, 2009 | 12:47 PM
  #215
Jeff92se's Avatar
Red Card Crew
Yes people have replaced just the bushings.
Old Apr 16, 2009 | 02:52 PM
  #216
Mustang5L5's Avatar
Are replacement bushings the new design? Or the existing?
IIRC, the new comp rods are a new design....at least the bushings. Just wondering if the redesigned bushings required a new design to the arm?
My dealer only replaced ONE compression rod. They didn't do the pair. I drove this AM and the other original one creaked very faintly so i know i'll need to get the other one done now.
Oh well, my warranty is up Feb of 2010, so i have time. I'll wait til something else goes and bring it in for the other rod. I like driving the loaner cars
Old Apr 16, 2009 | 03:02 PM
  #217
RiCeBrNr's Avatar
Look in the FSM for removal and the TSB can be found online which shows the bushing installation.
Unfortunately I need colorful pictures and big bold instructions
I've read the service manual but still don't feel comfortable with the instructions specifically removing the compression rod from the steering knuckle with a "ball joint remover".
Old Apr 16, 2009 | 07:33 PM
  #218
Mustang5L5's Avatar
Here are the parts from my recent replacement
Keep in mind this is driver's side and for an AWD G35. I guess the RWD models use AC70F.
Compression Rod: FRO-54469-AC71F
Bolt-stopper: 40038-AQ301
Another thing to note, the new arm is painted black. The original is bare aluminum.
Old Apr 16, 2009 | 10:10 PM
  #219
AARONHL's Avatar
It's basically a tuning fork type of tool that you hammer into the joint causing it come loose. Should be very easy, if it is anything like a tie rod (I've done those before).
The TSB states:
Check the taper part of the ball joint. If the taper part is damaged or scratched, the compression rod assy. will have to be replaced.
I am worried once I remove the compression rod I will notice both bushings are worn so it would be pointless to buy just the single bushing called for in the TSB. Has anyone ever had this issue? I guess when it gets warmer I will remove them and inspect to see if I should replace the whole compression rod assembly.
I am experiencing a lot of road vibration/noise in the front of my G on the highway. Would the compression rods be causing this? Or is it just when going slowly over bumps? Because I do hear creaking, but wonder if I have another problem as well.
Old Apr 17, 2009 | 11:06 AM
  #220
RiCeBrNr's Avatar
I have a similair issue, I don't know whether to buy just the bushings or an entire compression rod.
The TSB states:
Old Apr 17, 2009 | 11:24 AM
  #221
UmassG35's Avatar
I took my car to Nissan last week for some small electrical work and was also hoping to get my driver's side compression rod bushing and/or rod replaced due to the creaking. I gave them the TSB # and they took a look. The tech told me that there was no damage to the bushing and the invoice says "Needs to happen more than once." Oh you mean like, every time I take a right hand turn, go over speed bumps, change direction quickly etc?? Riiiight.
Anyways, the noise is getting worse and I'm going to check out the bushing when I swap my springs this weekend or next. Will I be able to adequately check the bushing for a tear without removing the rod itself? i.e is most/all of the bushing visible while on the car?
Old Apr 17, 2009 | 12:33 PM
  #222
GReddySetGO's Avatar
Anyone have a link to the TSB?
Old May 1, 2009 | 11:31 PM
  #223
6MTGSedan's Avatar
Wow, great post. Now I can finally get that annoying creak taken care of. Nobody mentioned whether an alignment was needed after the install, anyone know? My guess is not.
Old May 5, 2009 | 03:36 PM
  #224
AARONHL's Avatar
After replacing the compression rods, is an alignment necessary?
Will new compression rods give you an overall smoother ride? Or just stop the creaking and popping while entering a driveway? Because it feels like I have some rumbling up front while cruising at speeds.
Old May 5, 2009 | 03:41 PM
  #225
AARONHL's Avatar
Actually, the FSM does not say to remove anything other than the compression rod ends so an alignment should not be necessary. Does that sound right?
