Any one replace their lower ball joints?
Old Nov 2, 2014 | 09:16 PM
  #271
blAk mAx's Avatar
probably dried out so replace the balljoint
Old Nov 2, 2014 | 09:34 PM
  #272
InfinitiGeeX's Avatar
Thanks blAk mAx.
What do you guys think of the vollig heavy duty ball joints?
http://www.ebay.com/itm/271199227217...84.m1438.l2649
Old Nov 3, 2014 | 02:22 PM
  #273
gmmills's Avatar
Originally Posted by InfinitiGeeX
Thanks blAk mAx.
It's ebay...
Old Nov 3, 2014 | 03:01 PM
  #274
ScraggleRock's Avatar
Originally Posted by gmmills
It's ebay...
For real..just get the CZP ball joints.
Old Nov 6, 2014 | 08:40 PM
  #275
blAk mAx's Avatar
i got mine from ebay . but at the time there weren't any other options that didn't cost a lot. the rubber caps wont fit so you`d have to get a different set, i think made by white line
Old Dec 3, 2014 | 12:21 PM
  #276
chobble19's Avatar
Has anyone had any luck replacing their lower ball joints on an 05 and up G35?
Old Dec 11, 2014 | 08:31 PM
  #277
digital sol's Avatar
Anyone use something like this to replace them?
Old Dec 11, 2014 | 08:37 PM
  #278
Air isn't strong enough.
Old Dec 11, 2014 | 10:00 PM
  #279
Saying that from actual experience? Just curious. I own a honda as well and have new ball joints for that as well so spending the $ on the tool would be worthwhile if it works.
Old Dec 11, 2014 | 10:45 PM
  #280
Yes. My buddy has a 100gal tank and a pro-shop worth of tools. I tried it when I did mine hoping for extreme ease with the air. Wouldn't even touch it. Those ball joints are in there tight as fug. I used a 4-foot breaker and it still took a decent amount of effort with the autozone kit.
Old Dec 11, 2014 | 10:52 PM
  #281
Damn, yea that's what I was afraid of. Thanks for the info bud!
Old Jan 4, 2015 | 11:52 AM
  #282
dtg35's Avatar
When you used the Autozone balljoint kit, did you require any additional balljoint receivers in order to remove the balljoint? Or did the Autozone kit have everything needed to remove the balljoint? The reason that I ask is because a few pages back, AARONHL stated that the Autozone kit had a receiver that was too small to remove the balljoint.and he recommended the one from Advance Auto. Since there is no Advance Auto in AZ, I'm hoping to find out how the Autozone kit worked for you.
Old Jan 4, 2015 | 12:40 PM
  #283
I used the autozone kit for the whole job. The thing is, you gotta get creative. The closest "receiving" cup is a bit too big, but the "pressing" cup works fine.
What I did was have my friend hold the receiving cup steady and make sure everything was going in straight, while I used a ratchet with a 4' fence pole slipped over the handle for leverage. You just gotta get creative with the placement of everything, and I don't think it would have happened without a helper. It would have been extremely frustrating anyway.
Old Jan 4, 2015 | 02:12 PM
  #284
dtg35's Avatar
Thanks for the info. I'm going to check with Autozone to find out if any of their adapter sets that they also have on the loaner program will have the 2 7/16 ID receiving cups that are needed to get the steering knuckle ball joint pressed out as well.
Old Jan 18, 2015 | 07:02 PM
  #285
dtg35's Avatar
I just completed replacing the drivers side ball joint on my 03 coupe. I bought the ball joint from Concept Z performance and it seems like a quality unit. Also, since i live in AZ and there is no Advanced Auto to rent the ideal ball joint press kit, I rented the ball joint press kit from my local Autozone and also rented the Ball Joint adapter set #27166. They worked perfectly. I've never pressed out anything before and these two kits made it a trouble free job.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
