G35/350Z aftermarket coilover, springs and shocks spec's w/updates
Old Mar 5, 2012 | 12:28 PM
  #286
TreyJoh2's Avatar
Originally Posted by DRG35R
this spring when my car comes out of the garage, I am going to be installing the Tokico D-Spec 350Z springs. if all goes as expected, it should be the perfect drop with springs and I will post pics as soon as possible...stay tuned.
Ok thanks alot!!
Old Mar 9, 2012 | 03:12 AM
  #287
VQ35DE-G's Avatar
Not quite sure if this was covered, but how much of a drop is it from stock G sports shocks and springs to Z shocks and springs?
Old Mar 10, 2012 | 06:52 AM
  #288
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
on a G coupe it is supposed to be a drop of .5" Front and Rear and on a G sedan 1" F and R. it is noted in the OP near the top of the post.
but with that being said, much of what I have read on this site from various posts of peoples experience, is that Z springs will drop the front of a G coupe an extra .5", but NOT the rear...not sure about the sedan. have also found many posts that say the same thing about aftermarket Z springs.
my own experience is with Z H-Techs which dropped the F about 1", but maybe only .5" in the R. now I have RSR Ti2000 Z springs and the same thing has happened. the RSR's list a drop of .6 F and R on the Z. that should translate into 1.1" F and R on a G coupe, but not with mine. the F dropped fine, but the R is again only about .5".
have a one finger gap in front and the drop is nice, but the rear still has a full two finger gap and it looks to need the spring mount mod. I wonder if all springs designed for the Z only drop the G coupe by what is advertised for the rear of a Z...hence the reason so many guys do the spring mount mod.
I was able to get a good deal on a set of Tokico D-Spec Z springs. these advertise a drop of 1" F and R on a Z, which should be a drop of 1.5" F and R on a G coupe. we will see. my thoughts are that it will drop my car 1.5" F and 1" R. will post results later this spring after install.
can anyone else with aftermarket Z springs confirm my suspicions?
Old Mar 23, 2012 | 10:15 AM
  #289
jstudrawa's Avatar
How about getting the first post edited with some marking information or part numbers for the OEM stuff?
Not to mention noting that the springs revised vs. unrevised feel different, IF infact the spring rate info is correct...
Old Apr 8, 2012 | 09:04 AM
  #290
Jairen's Avatar
5kg/mm is 280lb/in
6kg/mm is 336lb/in
7kg/mm is 392lb/in
8kg/mm is 448lb/in.
9kg/mm is 504lb/in.
10kg/mm is 560lb/in.
11kg/mm is 616lb/in.
12kg/mm is 672lb/in
13kg/mm is 728lb/in
14kg/mm is 784lb/in
15kg/mm is 840lb/in
16kg/mm is 896lb/in
17kg/mm is 952lb/in
18kg/mm is 1008lb/in
19kg/mm is 1064lb/in
20kg/mm is 1120lb/in
21kg/mm is 1176lb/in
22kg/mm is 1232lb/in
In case some needed some help.
Old Apr 11, 2012 | 02:28 PM
  #291
Techre5's Avatar
Sick guide, first page ive saved on this website!
Old May 2, 2012 | 06:14 PM
  #292
SuperTrooper699's Avatar
I didnt see anything about 350z sprint performance springs? I'm looking into buying a set for the front it will drop 2.75 inch on a sedan. i cant find spring ratings to compare them to my strut ratings which i cant seem to find either.
Old May 8, 2012 | 08:53 PM
  #293
nogoodname's Avatar
Anyone ever installed Racing Logics true coilovers?
Old May 12, 2012 | 04:58 PM
  #294
devlmaycry's Avatar
Anybody have the tokico d spec and spring combo that has any pics they would like to share?
Old Jul 13, 2012 | 12:50 AM
  #295
Eva G's Avatar
so I bought my brother for christmas tein s-techs for his G coupe but I was too late to realized I accidentally ordered him sedan s-techs (I know noob mistake!! >_<). After reading thread and looking at tein's official website. Will his drop be similar to that of a coupes? give or take .! or .2 difference in drop? I noticed on the official website the front spring rates are same as coupes whereas the rear is 274-coupe and 291-sedans.
Old Sep 17, 2012 | 04:55 PM
  #296
Myvqg35's Avatar
Hi I was wondering if anyone knows or has 350z Kw v3s on their g coupe? I'm interested in buying some but the part numbers change on them and I have a local 350z owner selling his set but the whole Part number change keeps me from pulling the trigger, any help/info would be greatly appreciated
Old Oct 16, 2012 | 12:05 PM
  #297
Gsedan35's Avatar
And you never will
1. 2.75" drop on springs and shocks takes way too much bump travel out of the suspension. No aftermarket shock is going to make things work with that much drop. Get a coilover setup.
2. Sprint refuses to say what the spring rates are. Like I can't figure that out with springs in hand
Old Oct 28, 2012 | 09:54 PM
  #298
nbarkins's Avatar
Thumbs up
Originally Posted by Gsedan35
And you never will
Well put sir! much needed info
Old Oct 29, 2012 | 04:53 PM
  #299
nbarkins's Avatar
if i where to get stock 350z springs (front) and put them on my 04coupe (front) will it drop it some? i dont want to have bad camber or rough ride,so if theres anything i can do other than getting a coilover setup,or crappy lowering springs that will make my ride rough, can you guys chime in and let me know?
just want a decent little drop in the front, rear is fine.
btw im on stock 18's with brembos
Old Oct 30, 2012 | 01:13 PM
  #300
LoSt180's Avatar
350Z springs provided me with a 3/4" drop in the front. For the rear I had to modify the rear perch to get any drop. Since I have Sport package, springs rates are the same and ride is pretty much the same. Camber arms are recommended with any drop on these cars, that slight drop still put my camber out of spec.
Before & After shot on OEM 350Z springs
You have already rated this thread Rating: Thread Rating: 21 votes, 5.00 average.
