DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
Ok so that same seller emails me saying they had another diff off of an 09 G37 Coupe S w/18k miles and manual transmission. Attached these pics:
Looks just like the one that went into the Z 2 pages back. Also looks like it has the 4 bolt flange. What do you guys think?
If the details on what it came off of are correct, then it should be a 3.7 VLSD. The 4 bolt flange will bolt directly to your car without having to modify anything. I can't see the pics since they're blocked on this server, but is there a shaft extending past the front of the flange like the previous pics, or is it flush with it? And I don't know if I would trust that seller...
^ The shaft is flush with the flange. The seller is an eBay seller with 30 100% positive reviews. Personally, I've never liked buying stuff on eBay, but so far I've never had a problem with them. Hopefully this time won't be any different. Thanks again.
So it is looks like in 08 both AT and MT came with 3.7 diff
Looking at infinitihelp.com, in a "Viscous Limited-Slip Diff" line..what does the "P" and "S" stand for? (and 05 has "O", what does that stand for)
How do I know if I have an open diff or VLSD ? 05 AT Sport susp.
O - stand alone option
S - standard
P - included in optional package
Since you have the sport suspension I believe you have the VLSD.
S - standard
^I'm assuming your bumpin the thread???
I usd an over the counter fluid thats made specifically for VLSD's, 2 Qrts.
Can't remembr if it had a DOT rating, but if it does get the highest one.
