Easy Ecu Resetting
Old Oct 22, 2007 | 12:29 AM
  #406
Otacon132's Avatar
your only getting 9.6 on a 1/8 with a utec?... hmmm makes me wonder if its worth it.
anyway's - i dont know if this officially resets the ecu - but it sure did clear a CEL that popped up yesterday, figured id let you guys know that much at least
Old Nov 3, 2007 | 11:00 PM
  #407
Andy_350GT_Sky's Avatar
Does anyone know if this works for 350GT's?
Apparently they have different ECU's... but I have not been able to confirm this. When you turn the ignition to 'on' but not 'start' no lights come on and stay on.
Old Nov 12, 2007 | 10:24 AM
  #408
fordfixer's Avatar
ECU reset
What are you trying to reset by doing this? My 03 G35 Coupe 6MT was idling very high and threw a code for it. I fixed the problem by cleaning the throttle body, and cleared the code with my snap-on scanner, but now the idle speed needs to be reset, which apparently you need the Nissan scan tool for. It now idles at the right speed, but takes a few seconds to drop down when you step on the clutch. Does anyone have a programmer, such as predator, and if so, does it offer the system functional tests?
Old Feb 22, 2008 | 05:51 PM
  #409
elayman's Avatar
i heard that disconnecting the negative side of the battery and press the brake pedal in for like 30 seconds will reset the ecu.. is this true or just incorrect info? lol thanks for the responses.. i just installed my intake and it sounds like it's pulling too much air (making a psss noise) will resetting the ecu take care of this problem?
Old Feb 22, 2008 | 06:09 PM
  #410
elayman's Avatar
is there proof the hard reset (battery disconnect) burns out the ecu? im thinking of doing the easy reset since it's obviously easier/quicker.. but if the hard reset works more efficiently, then I might try that. I just installed my AEM intake yesterday and I need to reset it. It seems to be pulling too much air and making a pss noise when accelerating, will the ecu reset fix this?
(sorry for the multiple posts on different threads if anyone saw.. just trying to get an answer)
Old Feb 22, 2008 | 08:33 PM
  #411
Gilley's Avatar
Aftermarket intakes make more noise as part of their design. Resetting the ECU won't change the sound.
Old Feb 22, 2008 | 11:38 PM
  #412
Skaterbasist's Avatar
Retired SuperMod
xXHotelCrazyXx's thread has been merged with the sticky thread (Easy Ecu Resetting).
Old Feb 23, 2008 | 01:23 PM
  #413
elayman's Avatar
^2 not the noise.. its just a pss noise like air is being pulled in too much.. is that how it will always sound? jw
Old Feb 25, 2008 | 12:04 PM
  #414
ISMSOLUTIONS's Avatar
The point of an intake IS to get more air sucked in...
Perhaps you have a bad connection and could be leaking a little...but if the car is running fine...probably nothing to worry about and a completely normal sound.
Rick
Old Feb 26, 2008 | 12:45 AM
  #415
2K6G35's Avatar
It might be true.
I was working on my car last weekend and I removed the battery's negative plug alot, then this morning I saw "Service Engine Soon". My mileage was still 16,005 miles.
I just tested on my '06 G35 coupe. I unplugged the negative plug and pushed the brake pedal within 30 seconds. The warning light has dissapeared.
Old Mar 3, 2008 | 06:21 AM
  #416
sweettalker's Avatar
Just wanted to chime in. I did this just RIGHT NOW. I took my laptop down to my garage (with my watch with seconds hand) into my car. turned off navi, turned off radio and windows rolled up. My first intention was to turn off the check engine light (i had test pipes, but yesterday i put the stock cats back on). So I went down to turn off the light but when I started the car to warm it up, the light was gone. LOL. but I did this method anyway but the check engine light was blinking 10 times first, 9 times and then 10 times again or the 9 could have been an 8. Anyone know what that means? But on a positive note, it felt like the car picked up some power. Couldn't believe it myself. I was only going to do this method to get rid of my CES light, but hey, kill two birds with one stone. :thumbs up:
Old Mar 9, 2008 | 06:42 PM
  #417
2004neonsrt4's Avatar
just did it my self took about 4 tries. timing is key
Old Mar 18, 2008 | 01:49 AM
  #418
425skyline's Avatar
Ummmm.... 350GT is just a G35 buddy. Same car. Different badging.
Old Mar 18, 2008 | 02:08 AM
  #419
425skyline's Avatar
ya ok.. not going to spend hours sitting in my car flooring my gas pedal while the car is off.. lol... didnt work sorry
Old Mar 22, 2008 | 03:38 PM
  #420
dvsmeth0dz's Avatar
after putting on wheels w/o the tpms my tpms light is on. I tried doing the ecu reset to get rid of it but all it seemed to do was make my gas mileage worse.
