Easy Ecu Resetting
Old Feb 5, 2009 | 04:49 PM
  #451
djamps's Avatar
Worked the first time for me...thanks for the cool trick.
Side note, it appears the codes are "blinked" to you after the initial 5 presses. Useful if you don't have a code reader!
Old Feb 10, 2009 | 02:20 AM
  #452
Tree_tech's Avatar
I purchased a used 06' G35X not too while ago. The previous owner was probably an old owner.. this car ran like a turtle. However, after the ECU reset. Wow .. just wow. My G is born again...
Old Mar 15, 2009 | 04:51 PM
  #453
Oh Itz Joel's Avatar
Amazing...
After 15 tries and not knowing if this will work, I just reseted the ECU and when I took it around the block it was just amazing.
Old Mar 15, 2009 | 08:54 PM
  #454
dOnkei's Avatar
Wow nice
Took me 2 trys but i did mine different...noticed when i put my key in and turn it to the on position...my car beeps 4 times...and its a 4 second count...
So after the 3rd beep i pressed the gas peddle all the way down 5 times in about 3 seconds...
Then waited 7 seconds...then i pressed the gas peddle down for the 10 second hold...the engine light started blinking on the 4 second of holding...released the peddle
Then went for the 10 second hold again and it stop blinking on the 4th second...released the peddle and started it and it was a nice feeling...
For me the reseting made a difference...and i am the 2nd owner so it probably had a memory build up...
Hope you guys understand what i did and maybe it helps others...
Old Mar 15, 2009 | 09:09 PM
  #455
PTownG's Avatar
don't forget to stand on one foot, hop in a full circle and fart as you pass 12 o'clock. Otherwise it doesn't take.
Old Mar 20, 2009 | 11:20 PM
  #456
daman513's Avatar
Originally Posted by emineo
I got this to work on my first try, definately tickles my pickle. Also going to try the battery method. If that works, it will definately lube my tube.
05 IP coupe / 5AT.
ROFLMFAO
Old Mar 24, 2009 | 01:45 PM
  #457
blkthunder's Avatar
i did it... took 2 trys but it worked pretty easy.
Am i supposed to be getting a CEL when the rpms start falling after accelerating?
Old Apr 6, 2009 | 02:43 AM
  #458
thatsmyG35's Avatar
I have tried over and over and over and never got it to work. if i disconnect the battery for an extended amount of time will it reset my homelink?
Old Apr 6, 2009 | 09:42 PM
  #459
thatsmyG35's Avatar
so I tried the pedal method again today and got it on my first try. I noticed a bit of a difference but not much, it definitely flys into higher rpms though.
Old Apr 10, 2009 | 07:27 PM
  #460
1ceman's Avatar
i did the pedal method and i got it on the 7th try, but now all i got to do is hold the gas pedal down for 10 seconds and the check engine light will start blinking, i didnt have to do the 3 sec or 7 sec wait. Also when i step on the gas pedal when the ignition is turned to on it makes this light tapping noise. Is there something wrong?
Old Apr 11, 2009 | 06:36 PM
  #461
steelo68's Avatar
I just reset ECU, & after 5 tries, got it! Definitely a noticable difference! MUCH more pep, & stiffer shifting..
05' Coupe 5AT, BONE STOCK (for now)
Old Apr 17, 2009 | 07:49 PM
  #462
tegraphile's Avatar
Worked on the third try. Thanks for the DIY.
Old Apr 18, 2009 | 05:20 PM
  #463
notfast's Avatar
Will disconnected neg terminal on battery lose all settings on radio? every car is different it seems
Old May 31, 2009 | 09:02 PM
  #464
kable33's Avatar
Took me about 20 tries in the beginning. Lol. Then I read on here that you should have the windows up. After I rolled em up and tried again, worked after 2 tries.
Old Jun 3, 2009 | 08:32 PM
  #465
BourbonNcigars's Avatar
I have a question (or two)...
What about those people who use the Sprintbooster (or similar product) which, supposedly, decreases shift time between shifts? If the ECU teaches the tranny when to shift, who overides who? Does the Sprintbooster win, or the ECU?
I don't see how they can both control the shift times. In Spock terms, it doesn't seem logical. My guess is there's some BS somewhere in this equation.
Someone please tell me why I'm wrong, since the Sprintbooster is one of the mods I could probably do on my own. Then again, if someone can explain why I'm right, then you've saved me some money.
