All Stillen Supercharger Owners Report Here
Old Dec 17, 2006 | 11:08 AM
  #181
bfan13's Avatar
Originally Posted by ttrank
Are you 100% sure it is that pulley?
yup, i literally put my ear up to it and its really obvious
Old Dec 17, 2006 | 04:24 PM
  #182
ttrank's Avatar
Grocery getter
Sounds like the bearing to me.
Old Mar 4, 2007 | 08:16 AM
  #183
Chrlesmd's Avatar
1. 2004
2. Coupe
3. 5AT
4. Stock 18s
5. 285
6. 252
7. Dynojet
8. Stage II
9. None
10. No 1/4 mile
Love the kit so far, but why is the tq so low???
Old Mar 4, 2007 | 10:32 AM
  #184
Good2Go's Avatar
2. Coupe
3. Auto
4. 20x10
5. HP unknown
6. Torque unknown
7. Dyno - not yet
8. Stage 4
9. Popcharger CAI, custom z-tube, DC headers, borla exhaust
10.Unknown 1/4 mile times and mph. Will find out soon at LACR
11. Installed @ 77897 miles - over 2000 miles now.
Love it! It's totally a different ride now!
Is it a good idea to just change the pistons and rods to minimize a blown engine? I understand that the stock rods being the weakest link - is that correct?
Old Mar 4, 2007 | 12:16 PM
  #185
Chrlesmd's Avatar
I think you're right. But with stage 4, you should be ok. Honestly, there are plenty of guys who are running way more boost and power on the stock block. But, I've also heard of guys who have blown their motors w/ simple bolt ons and stillen kits. Just make sure your a/f is ok when you dyno. Since you have that many miles on your G, you may want to look into a compression test as well.
Old Mar 5, 2007 | 10:58 AM
  #186
ttrank's Avatar
Grocery getter
You can run stage 4 on a stock block no problem. I did it for a while. But yes you are right the rods are one of the first to go. If for any reason you do build your motor stick with the stock compression. If you go down you will loose a lot of power.
Old Mar 5, 2007 | 11:01 AM
  #187
rookie's Avatar
The few blown Sillen motors I've seen have been piston, ring, ringland issues, I've seen holes in the block from a Stillen but that was not the normal set up.
Old Mar 5, 2007 | 12:59 PM
  #188
Chrlesmd's Avatar
One thing I did notice w/ my new stage 2 kit is that when I'm in manumatic mode and I shift at > 4k rpms, the tranny seems to slam into the next grear...a lot harder than it used to. I don't know if it's a problem, but I did notice that today.
Btw, does anyone know the part numbers for replacements belts?
Old Mar 6, 2007 | 10:00 AM
  #189
ttrank's Avatar
Grocery getter
If I remember right they are:
K040220 - Blower
K060288 - Main Drive
K060500 - Crank/Alt/etc
Old Mar 10, 2007 | 06:50 AM
  #190
Chrlesmd's Avatar
Thanks. The new kits have the 6 rib belt which is supposed to be better. I haven't had any issues w/ slippage or tearing yet (keeping fingers crossed).
Old Mar 30, 2007 | 10:20 PM
  #191
Triple8Sol's Avatar
My buddy took a couple vids of my G35c on the dyno last week, and uploaded them to YouTube. Here you go:
Old Apr 30, 2007 | 11:22 PM
  #192
Joshua's Avatar
2006
Coupe
6mt
Stage 2
Z tube, all other parts removed
Stock 245/40/19
Old May 1, 2007 | 12:50 AM
  #193
ttrank's Avatar
Grocery getter
Ahh I remember that sound.
Old May 11, 2007 | 12:07 AM
  #194
Tonys-G's Avatar
in case anyone anyone wanted to know
I just got done weighing the stock Plenum, upper and lower and it came to 20lbs while the Stillen unit with the lower plenum piece weighed in at 38 lbs
so only has 18 more pounds over stock (not including everything else)
Old May 11, 2007 | 01:14 AM
  #195
ttrank's Avatar
Grocery getter
18lbs of unsprung weight is not too bad.
