G35 & G37, Coupes & Sedans
Old Aug 20, 2018 | 10:26 PM
  #8821
Jason Murrish's Avatar
Base model. Cold air intake, Invidia cat back exhaust.
Today she got a spit and shine after traveling to Lake Havasu, AZ for the weekend.
Old Aug 20, 2018 | 10:31 PM
  #8822
onevq35de's Avatar
Neato! Anything for a reasonable price isn't gonna work FWIW. I just prefer blanks or Slots only. If you had brake noise it was your pad choice or high frequency vibration from lack of lubrication/shims typically, IME.
Thanks for your reply about the info, I learned something today.
Nope. No pad ever made a difference. If you search around enough you'll find that many many z's. g's and fx's had this issue. Perhaps some had an easier time with this issue and pads dd the trick. I came across some guys that replaced the rotors as I wrote above with success, I followed and haven't looked back.
Old Aug 21, 2018 | 06:51 AM
  #8823
Blue Dream's Avatar
I drove ttrank's car solo
LS and a sport bumper/model to boot=super sexy
She looks great!
Old Aug 21, 2018 | 06:55 AM
  #8824
Scorpi0's Avatar
Got some Tein Street Basis coilovers. Gonna go pick em up in the next few days.
Old Aug 21, 2018 | 11:58 AM
  #8825
MooseLucifer's Avatar
5 Year Member
blk
EDIT: Turns out Hall S already said this above in post #8822 c:
FYI - Rotors that come 'drilled' from the factory (IE Porsche) are not drilled, the holes are actually included in the casting molds. Drilling any cast iron after it cools will introduce stress risers due to the crystal structure (Face Center Cubic) of the metal at lower temperatures. This is fine on most applications, but as you put the iron through extreme heat cycles, the thermal expansion will cause micro-cracks to form, which are propagated when they reach these stress risers.
Introducing the cavities/holes in the casting process ensures the iron will flow (again due to crystal structure, but BodyCC this time) around the cavities and cool into that shape without any anomalies in the crystal structures.
Source: i make brakes
Old Aug 21, 2018 | 12:07 PM
  #8826
Albanian122's Avatar
Guys question any feedback on a used turbonetics kit for g35 anyone running this a member is selling one
Old Aug 21, 2018 | 12:25 PM
  #8827
onevq35de's Avatar
Good info Looks like urban's crossed drilled holes might not be chamfered? Mine are Powerstop and are drilled after the fact (just called out of curiosity). While not as high quality as a 100K + performance car, the chamfering of the holes has a similar effect and will help prevent these stress cracks.
Old Aug 21, 2018 | 12:57 PM
  #8828
Urbanengineer's Avatar
Interesting idea, and makes sense. But unfortunately unless the seller specifically specifies it is added in the casting stage (they usually don't) it's hard for the casual buyer to know the difference.
Old Aug 21, 2018 | 01:00 PM
  #8829
I see the stop tech ones have the chamfered and casting holes, so those are the ones to buy on a budget in a hurry.
Thanks for teaching me something today! I now know what to look for more.
What's interesting is no motorcycle ones have ever had a "leading edge" like you guys mention here and they work just fine. Example in below picture. It is a two piece rotor held by bobbins though.
Old Aug 21, 2018 | 02:11 PM
  #8830
Hall Stevenson's Avatar
A couple ways to possibly identify if the holes were cast in or machined (drilled) later... Look at the inside walls of the holes. If they're 'rough' (use the vanes on the inside of the rotors (of front rotors) for comparison), they're cast. If they're smooth or shiny, they've been machined. Then again, some may cast in holes and then drill them out larger although that seems pretty silly and unnecessary. The precision of the size of these holes isn't that critical.
You can't use the 'edge' of the holes as a sure sign either. If you look at onevq35de's last example, notice how the curved section blends into the horizontal and vertical edges (tangency) ? Depending on the pattern (mold), it could look like that at first but the rotor face gets machined so you'll lose part of that blend. You'd be back to a sharp edge ! Now I'm wondering, even with cast-in holes, do they at least spot-face them during machining ?#s3gt_translate_tooltip_mini { display: none !important; }
Old Aug 21, 2018 | 03:42 PM
  #8831
onevq35de's Avatar
[QUOTE=Urbanengineer;7147557]I see the stop tech ones have the chamfered and casting holes, so those are the ones to buy on a budget in a hurry.
Nope. Stop Tech drills'em too. Just called. I sense that most aftermarket rotors are going to be drilled. Perhaps even some of the higher end oem's as well.
Old Aug 21, 2018 | 03:44 PM
  #8832
onevq35de's Avatar
Interestingly enough, the slots never seem to be chamfered and I've read that they specifically leave a sharp edge which helps "clean the pad off" or some **** like that.
Old Aug 21, 2018 | 04:38 PM
  #8833
We all know that's crap, pad cleaning lol.
Neat to know even centric drills them.
I'm heading to the zone for a $100 set of rear blanks in a few mins.
Old Aug 21, 2018 | 05:17 PM
  #8834
LoSt180's Avatar
Driver's seat is making a creaking sound, lower left side, not rocking just kinda squeaking. What areas should I hit with lithium grease? Or should I part out?
Old Aug 21, 2018 | 06:01 PM
  #8835
5 Year Member
blk
As far as I know, Zimmerman is the only company that includes the holes in the casting. The SOLE purpose of the holes is to reduce the weight of the rotor - pads use to need holes/slots for off-gassing, but pad binding materials have come a long way since the days of asbestos, and no longer off-gas in large enough quantities for the pads to need any relief.
The benefit of slotting the face of the rotors is that the sharp edge of the slots will artificially increase the initial torque of the pads, which aids in pedal feel, especially on the street. This will also help inexperienced track drivers in terms of pedal feel, but experienced track rats are already mashing the pedal deep into the brake zone on high torque race pads, so it doesn't make much difference there. Where the slots will make a difference regardless of skill level is in the release characteristics of the pad. The orientation of the slots will help separate the pad from the disc, which aids in pedal modulation once you're already on the brakes and reduces pad drag. This is where directional rotors come into play (along with cooling vanes, but not so much on OE rotors), if your rotors are slotted but don't have a 'left' and 'right' such that the slots are facing the same direction on both sides of the car, then they are probably just for show.
On a slightly related side note, when people complain about pad rollback, its typically a problem with worn suspension components or wheel bearings (usually found on older cars), not a problem with the brakes. Installing rollback springs in your calipers is a band-aid for unrelated suspension issues.
