G35 & G37, Coupes & Sedans
Old Apr 7, 2019 | 01:13 AM
  #9511
Scorpi0's Avatar
Dude Im jealous of your seat.
Old Apr 7, 2019 | 10:46 PM
  #9512
SeedyROM's Avatar
Coupe
Haha, thanks! It just annoyed me so much every time I'd get in the G that it had to be one of the first things I fixed.
Old Apr 7, 2019 | 10:55 PM
  #9513
Albanian122's Avatar
I ordered some new nismo 370 wheels for the g35 in gunmetal
Old Apr 8, 2019 | 08:34 AM
  #9514
joeb1983's Avatar
G35
Took the G to work Friday. When driving I noticed a vibration that I thought was possible flat spots in the tires from sitting too long.
While going through the gate at work, when I rolled the window down to show my ID, I noticed a popping noise coming from the front end that was speed dependent.
Long story short, my passenger side front wheel’s lug nuts where only finger tight.
Have no idea as to why... every other wheel was torqued and I don’t recall doing any work on that side... Weird.
At at least it was a simple fix and while I had the jack out, I figured I change the oil. (The oil change after the oil cooler line failure)
Dreading the worst; I threw a shop rag in a funnel in an attempt to catch anything that shouldn’t be there. Thankfully, there was nothing. Same on the magnetic drain plug as well as the filter.
So, back in went some Rotella and I put her through the paces. Launch control, rolling any-tag, brake boosting and some no lift shifts.
No issues so far; fingers crossed.
Next is a compression test.
Old Apr 9, 2019 | 11:46 AM
  #9515
Urbanengineer's Avatar
Originally Posted by LoSt180
I had to install the shims to get proper adjustment on mine, and I'm only on Z springs.
I'm also on Z springs but didn't have this issue.
Old Apr 9, 2019 | 11:48 AM
  #9516
Took out the winter carpets, did a spring cleaning, and installed new carpets finally! G is looking way better.
Old Apr 9, 2019 | 04:50 PM
  #9517
WoodG35's Avatar
Bone stock G35, got everything but sirius radio. :(
semi-busy day
Installed a new fuel pump and sending unit............and the other sending unit on the drivers side?
Installed a new Curt trailer hitch so I can pull my small trailer when needed.
Spent an hour trying to get the rear seat back into place......what a bitch (or was I doing it wrong?)
Old Apr 9, 2019 | 11:12 PM
  #9518
Scorpi0's Avatar
Got these Ichiba V1 10mm spacers to push my front wheels out a bit. But that 2-piece hubcentric design seems kinda sketchy. I thought it would press into the spacer tightly but it seems like the tolerance isnt as tight as I thought and Im able to wiggle it slightly. That defeats the purpose of it being "hubcentric" in my opinion. What do u guys think? Will it firm up some more when its actually installed?
Old Apr 10, 2019 | 09:33 AM
  #9519
Hall Stevenson's Avatar
I wonder if the taper makes it somewhat self-centering and the clamping action will take care of it. Is this their standard design ?
Edit: Looking at the picture again (the glare and angle tricked me), it looks like that center ring only increases in diameter on the wheel (outside) side to mate up with the wheel properly. I originally thought it should be flipped over or something.
Old Apr 10, 2019 | 10:06 AM
  #9520
Finally someone else with one... very nice.
You have a coupe I assume? This will be my set up this summer.
Attached Thumbnails What did you do to the G today?-photo372.jpg   What did you do to the G today?-photo238.jpg
Old Apr 10, 2019 | 12:39 PM
  #9521
joeb1983's Avatar
G35
I ran these spacers for years, both front and rear. Zero issues whatsoever.
Old Apr 10, 2019 | 02:48 PM
  #9522
saywat?'s Avatar
damn they still sell that old design spacer? considering theres one piece designs theres no reason to use that old design.
Old Apr 11, 2019 | 04:41 AM
  #9523
Scorpi0's Avatar
Thanks!....thats what I needed to hear.
Old Apr 11, 2019 | 04:42 AM
  #9524
Scorpi0's Avatar
Any suggestions on a new design?
Old Apr 11, 2019 | 07:08 AM
  #9525
Blue Dream's Avatar
I drove ttrank's car solo
Joeb be forewarned, Ichiba has a crap reputation on here. All you need to do is search for the multiple fail threads about the brand in Driver to read about the issues. I personally have had 4 different Ichiba products fail in some way or another including the extended bolts and nuts on a spacer set. The threads were extremely soft and stripped on more than 1 bolt and the nuts are very soft and round off way too easily if you put any force on them. If it were me I'd send those back if you haven't installed them yet but YMMV, just be careful.
