Illuminated Kickplates
Old Sep 24, 2008 | 05:11 AM
  #211
mzhu35s's Avatar
Just got mines installed eariler.
Old Sep 24, 2008 | 08:45 AM
  #212
UltimateGee27's Avatar
^^ couple of beans and some techno music would make ur car awesome
Old Sep 24, 2008 | 10:01 AM
  #213
kool_yaar's Avatar
looks really nice, i like how the red light reflects off of the plates!
Old Sep 24, 2008 | 11:27 AM
  #214
IvoryPearl07G's Avatar
Old Oct 17, 2008 | 05:58 PM
  #215
rustyeleio's Avatar
I just got mine from InfinitiPartsUSA.com
http://www.g35parts.com/9083/osc/pro...9829cc3213db9c
They are on sale right now.
The US Infiniti plates don't look nearly as cool as the Skyline ones that others have posted but they are high quality and plug right into the BCM box on the passenger side. You do have to run the wires across the firewall from the driver side so it will probably take at least an hour. They pretty much give you everything you need including zip ties and foam padding to protect the wire from sharp edges and to eliminate vibration noise.
Old Oct 17, 2008 | 07:28 PM
  #216
KulG35's Avatar
looks awesome, just not $200 awesome
Old Oct 18, 2008 | 06:31 PM
  #217
jsmonet's Avatar
I got mine from g35parts.com/everythingG35 as well and I couldn't be happier. good stuff, good price, and it looks quite nice at night.
Old Oct 18, 2008 | 11:50 PM
  #218
cnugs127's Avatar
Do these light up only when your lights are on or whenevr the doors open?
Old Oct 18, 2008 | 11:59 PM
  #219
gymcshoe's Avatar
they light up when the doors are open regardless if the headlights are on or off.
I checked and they turn off with the interior map/courtesy lights when the doors are closed
Old Oct 19, 2008 | 03:42 AM
  #220
markk132's Avatar
ok seriously how hard is this to install? it seems like its going to be an easy installation, but i know that once i get them in my hands and go to my car to install them, i'm going to run into like 20 problems. is it easy to get the existing kickplates off the car? and will all of the wires be completely hidden under the carpeting of the car? i really want to order these but i know i'm going to feel uncomfortable popping panels off of my car and ripping kickplates off of my car to install new ones and running wires under the carpet and stuff..
Old Oct 19, 2008 | 04:21 AM
  #221
gymcshoe's Avatar
hey Markk132, i would consider myself a noob/novice when it comes to customizing cars... for most people this mod takes then less than an hour. for me, it took about 2 hours because I wanted to go slow and I don't have much experience popping off panels either. The instructions that were included are comprehensive and walk you through every step so you don't have to guess. I understand your hesitation and I felt the same way. But after gettiing them and successfully installing them, I felt great and it looked great. I don't think you have anything to worry about.
Old Oct 19, 2008 | 07:48 AM
  #222
AesonVirus's Avatar
Yeah, the install isn't too bad. Just make sure you start the install early enough to insure you have enough light. I installed mine in the dark which just made the install more difficult.
Took about an hour. I then installed my friend's at work in about 45 minutes.
Anyone in the MA area, I'm happy to help.
Don't get hosed at the dealer.... This is not a difficult install.
Old Oct 19, 2008 | 11:13 PM
  #223
jsmonet's Avatar
after doing it once, i bet i can swap these in under 20 minutes without cutting corners.
Old Oct 25, 2008 | 07:55 AM
  #224
B L U E S L A T E's Avatar
Honda Accord
It's almost 5 in the morning and I just installed these. Let's just say I had a helluva nap time earlier... hahahaha
Old Oct 25, 2008 | 07:21 PM
  #225
kala1's Avatar
where can i buy kick plates for 07 coupe
