350Z HR Y-pipe installed on a 2003 G35
Old Sep 4, 2009 | 12:56 PM
  #586
clarkkent06's Avatar
Sounds good! How does it feel?
Also, one suggestion for future videos...don't put the camera directly in the path of the exhaust. Kind of put it off to the side, the exhaust is creating "wind" noise which the camera can't handle and which makes the video sound bad.
Old Sep 4, 2009 | 01:01 PM
  #587
iamjessele's Avatar
whats in between :19 and :20 sec of the last vid? it looks like a flame?=O
Old Sep 4, 2009 | 01:17 PM
  #588
str3zz's Avatar
I though about that too ... It could be no clue really but then again that was all stock hmm
Old Sep 4, 2009 | 01:19 PM
  #589
str3zz's Avatar
It feels good. Still trying to get used to the muffler sound inside the car kind of loud a little bit since it used to be quiet or just intake sound lol. But i like it so much not sure about power gain but the car feels a little light when took off from 1 and 2 gear
Old Sep 4, 2009 | 01:31 PM
  #590
LightsOut's Avatar
SIETESG
your prob now getting better air flow than HP.
I would of swapped out the resonator for a free flow resonator. it would also reduce in cabin droan.
Old Sep 4, 2009 | 03:51 PM
  #591
str3zz's Avatar
I might doing that thanks. I think I'm happy with the way it is for saunds so i guess i'm not ordering hks muffler after all and save some money
Old Sep 13, 2009 | 02:33 PM
  #592
vstypicals's Avatar
If you guys need an HR Y-pipe, I have one for sale in SOCAL:
https://g35driver.com/forums/exhaust...est-pipes.html
Old Sep 15, 2009 | 03:13 AM
  #593
Tunerz_Store's Avatar
Well I picked up 4 g37 coupe y pipes today. I installed on of them on my car and there is a noticeable difference in better performance. Revs are a lot smoother under load and a bit more low end torque. Now there has been some discussion about the g37 y pipe having smaller piping for the down tubes than the oem pipe or the HR Y pipe, but apparently it doesn't make that much of a difference for us to notice.
Out of the 4 pipes I got, they were all identical except one. Apparently Nissan at some point decided to flare the piping on the down tubes right as it begins and comes off the cats. But it is only flared for about 3-4" then goes back into the 1.75" piping, exiting the collector @ 2.25" which matches the mid pipe.
Shows comparison of oem pipe to the g37 y pipe that had the flared ends.. oem pipe on bottom in pics.
Collector...oem pipe on right.
Comparison of down tube piping compared to oem and as you can see from the first 3 pics is different from the (1) g37 y pipe for whatever reason.
I also took it upon myself to weigh the pipes and the g37 y pipe is 3-4lbs lighter than the oem pipe.
Old Sep 15, 2009 | 03:56 PM
  #594
4mermarine's Avatar
In my head it would make sense that there could be a slight bottleneck in play if the down piping is a tad smaller than the outlet of the cats, but I think the gains due to the design of the pipe negate any bottleneck or theoretical loss in power. That being said, I have the G37 y-pipe on the way, so I'll post back on my thoughts.
Old Sep 15, 2009 | 05:22 PM
  #595
Yeah, I was thinking the smaller piping was to increase back pressure which in theory should increase low end torque, which makes sense. It also seems the longer down tubes help the revs under load.
I started the car up again before I left for work and it surely did sound more like the first gen coupe when you blip he throttle.....
Old Sep 17, 2009 | 03:36 AM
  #596
repin_LB's Avatar
trying to get a hold of a HR y pipe but compared to the stillen/megan/MD/aam/nismo/fuji/whatever else. Performance wise diff between them is very minimal correct and sound wise is there much difference between all of them? MD seems to have the best power gains between everything but any inputs?
Old Sep 17, 2009 | 03:54 AM
  #597
repin_LB's Avatar
so im guessing all models of the g37 HR y pipe will fit the first gen 03-05 g's?
Old Sep 17, 2009 | 05:16 AM
  #598
officerdbag's Avatar
Ok so my HR pipe SAGS big time.. I didn't care at the time after the installation but its really pissing me off is it always scrapes on bumps and inclines.. Makes me want to take it off. AHHH
Anyone else have this BS happening to them?
Old Sep 17, 2009 | 10:14 AM
  #599
Johnnyone's Avatar
^ Pics?
Old Sep 17, 2009 | 11:37 AM
  #600
DaveB's Avatar
My HR y-pipe sits high up in the chassis just like DE Y-pipe. Which HR Y-pipe do you have and what other exhaust mods do you have? My guess is it's related to issues with some sort aftermarket exhaust component you're running.
