TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Apr 30, 2011 | 08:16 PM
  #1516
srini's Avatar
Started my EOC test at BESHOFF
Just back from Beshoff. My first visit to Infiniti service centre. I was impressed.
Got the engine oil and transmission fluid changed. I was asked to come back after 1000 miles.
Old May 5, 2011 | 03:29 AM
  #1517
vashuba311's Avatar
Im looking to get G. looked at a 05 6mt coupe. In my price range you see high milage like 90-110k. Should i be cautioned? im not tryin too buy a new motor aside from the car
Old May 8, 2011 | 11:40 PM
  #1518
faiz23's Avatar
Make sure you listen to it and it should not sounds like it needs head work. See this thread and make sure you get all service records and especially oil changes. They should be changing oil every 3000 miles or atleast topping it off when it burns it off. Always check it out in person and drive it before you purchase it. Take it to infiniti and the usual things with that mileage is flushing fluids, changing belts, plugs, airfilter, oil change, compression rod bushing, lower control arm busshing, tires, brakes. Do all your research and make sure you get the CD009 tranny which is the last revision with beefed up syncro's to reduce grinding in gears.
https://g35driver.com/forums/g35-sed...ml#post5857127
https://g35driver.com/forums/g35-sed...pics-vids.html
Old May 12, 2011 | 09:48 PM
  #1519
unvmyg's Avatar
I got my engine replace jan 2009. After installation of the new engine the car comsume oil but the service advisor told me it was due to the break in period. So now @ 20K miles the engine is still consuming oil. After the intial service done last month I have put 1k miles on my car. And the oil dip stick from the F mark dropped about 3/16 of an inch which falls in the ok zone of the TSB.
I contacted Infiniti Redwood City and talked to the service advisor Benny to start a new oil consumption test. I spoke with ben and was surprised he told me it takes 50K (yes 50,000) miles for the new engine to break in. I literally laughed at him and told him I never heard of this before. He advise I talk to his foreman in the shop about it if I didnt believe him. To make a long story short Im going to the stealership saturday to start my consumption test. I just want to get something started in their system just in case it starts to consume more than it should as per the TSB. I will keep you all posted.
Old May 13, 2011 | 10:27 AM
  #1520
V35 Skyline GT's Avatar
6MT Coupe
^Glad you laughed in his face about that 50K break-in Mine took ~7K to calm down to it's consistant OC rate of .75-1qt every 5K miles. 35K on my replacement now and still the same OC. Gee can't wait for the 50K mark when my OC will stop w00t w00t LOL!!
Old May 13, 2011 | 10:42 AM
  #1521
Vijay2003G's Avatar
wow you got an 04 6mt and got a new engine? I guess some dealership are better than some.
Old May 25, 2011 | 01:28 AM
  #1522
patrickguu's Avatar
hey i have a 04 6mt and im not under warranty anymore can i still do the OC test? do i have to pay for the oil change and stuff? and i have all the bolt-ons will they give me trouble about it? and i dont have receipt of my past oil changes. Is there a TSB for 03-04 sedans? thanks for the help!
Old May 25, 2011 | 05:06 AM
  #1523
VQdriver's Avatar
The last time I went to the dealer the rep stated to me they had a couple pre '05 models being torn down due to excessive oil consumption. IIRC the rep told me you have to pay for an oil change in order to do an OC test. If you fail convincingly twice they will tear the engine down and inspect it for signs of neglect. They take pics and everything and report it to Nissan whom they say make the final call. If it is deemed your at fault you have to pay the labor for having the teardown and nothing else is to be done. It sounds kind of screwed up if you ask me. I don't believe there's a TSB for the sedans related to OC. You can probably do a refined search to confirm it.
Old May 26, 2011 | 11:31 AM
  #1524
6MT Coupe
No. There's no TSB for any non-revup VQ, only revups.
And you're out of warranty which means Infiniti will not pay a dime. Same with revups in this threads TSB when their power-train warranty expires.
Old May 26, 2011 | 11:46 AM
  #1525
Vijay2003G's Avatar
even if you have an 03-04 with warranty they still dont want to do **** for you lol...
Old May 27, 2011 | 09:49 AM
  #1526
6MT Coupe
^ Haha...yeah it was no picnic getting my replacement under warranty 'with' a TSB. The 'slimy' and 'dishonest' dealer games I dealt with was Effin amazing
Old May 27, 2011 | 11:38 AM
  #1527
88irocvert's Avatar
Hi guys! I've posted here before regarding my issue. The slime ***** at the dealership have been BS'ing me around because it was modified. I really need a straigt answer from someone here who's had their modified engine replaced. Please let me know. Thanks.
Old May 28, 2011 | 10:00 AM
  #1528
6MT Coupe
^All I had was a cat-back exhaust. I took the other stuff off before OC testing just in case.
Many stories here of ppl with their mods. Some same experience as you presently, some got their VQ's replaced easier than me...really depends on the Dealer. This thread is looong, but their stories are in here with their experiences/actions/out-comes. Hope someone chimes in for you never-the-less.
Here's another looong OC thread and years of what they went through: http://www.my350z.com/forum/engine-a...iscussion.html
There's the Magnuson Moss Warranty Act which is a US Federal Law: http://www.bing.com/search?q=magnuso...ox&Form=IE8SRC
G/L
Old May 28, 2011 | 11:27 PM
  #1529
88irocvert's Avatar
G/L
Thanks for your reply. I've read through much of this thread but following specific posters' stories is a little confusing. Anyhow, I already told them about the Magnuson Moss act and they don't seem to care. They're also in violation of various of our state government BBB statutes. They're getting an ultimatum on Tuesday. After that, I'm calling my lawyer.
I hope others respond so I have better data to present. Thanks again.
Old Jun 13, 2011 | 09:03 AM
  #1530
speedgeek's Avatar
v2 & Technosquare
Hi,
Just wanted to throw this question out there, I was wondering...
For all the folks who got a new v2 (me included) and also had mods including Technosquare tune, did you need to get a retune?
Did the dealer touch your ECU? I wish there was a way to confirm I still had my ecu tune (rev to 8k?). I'm debugging the awesome p1273 code for a LONG time
Thanks!
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
