TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Old Oct 14, 2011 | 10:50 PM
  #1636
ozzy87's Avatar
Originally Posted by rhampsterwha2
Itl have to be more than 1 quart per 1000 miles before Infiniti will consider a replacement, reason is because they consider 1qt/1000mi to be "normal" oil use
Thanks guys im glad I ended up getting approved! As far as I know im the first non rev-up to receive a replacement due to OC
it was amazing that I would burn 2quarts in less than 1000miles and only 38K on the motor
I am not sure if you noticed but the numbers I posted were in KM's & L's. If you were to convert the values, I am burning about 0.7Qrt's per ~620 miles. That put's me at about 1Qrt of oil per 887 miles.
According to your statement, this easily puts me within range to have an engine replacement.
Old Oct 20, 2011 | 01:44 PM
  #1637
LegendC32A's Avatar
For people who live in the Bay Area, which dealer do you guys think is more friendly? Pleasanton or Beshoff in San Jose? Or is there another one that gives a greater chance on the consumption swap?
Old Oct 20, 2011 | 08:27 PM
  #1638
V35 Skyline GT's Avatar
6MT Coupe
^Since Brian at Beshoff left, can't say now from the great experiences I've heard back in those days. No experience with Pleasanton. Mine was done at Neillo but that was back in 2008. Neillo did do a stellar job on my swap however, just be wise to normal OC testing games dealers play. Neillo played games back then, now...not a clue.
Old Oct 23, 2011 | 01:04 PM
  #1639
serges's Avatar
so i got a 06 cpe w 45k and it consumes oil like crazy almost 1 quart every 800 miles or so should i bring it in and raise hell i dont mind adding oil every now and then and it runs fine just the flywheel is noisey what should i do guys? how to go about this and should i remove my spacer before briging it in or u think they will void my warrenty if its on? thanx guys
Old Oct 23, 2011 | 01:24 PM
  #1640
wechslerl's Avatar
what exactly is the spacer for?
Old Oct 23, 2011 | 01:40 PM
  #1641
Texasscout's Avatar
With 10 months on this site, you should know what it is by now.
It is a spacer that goes between the upper and lower intake manifold to allow the back two runner to breathe better. Better air flow = more hp.
Old Oct 23, 2011 | 01:41 PM
  #1642
PAIXAO's Avatar
I would remove the spacer and any other engine mods you've done. You don't want them to give you any reason to deny your claim.
Spacer increases air volume in the plenum.
Old Oct 23, 2011 | 02:42 PM
  #1643
serges's Avatar
K i will take it off then thanx guys anything i should look out for at the stealership like if they play dumb what to say or to counter their actions in defense of my issue
Old Oct 26, 2011 | 09:03 PM
  #1644
6MT Coupe
^ Print out the most current TSB and take it with you to Dealer. I did and when I'd heard a line of sheit from their mouths I pull the TSB from my back pocket and say hmm let me see where it says that....
Old Oct 28, 2011 | 09:33 AM
  #1645
ajm216's Avatar
Originally Posted by ajm216
I picked her up today the service manager was extremely apologetic about the situation. It funny be every time I look at this darn car I fall in love with it again (don't judge me LOL). Manager said we took care of the issue and checked for leaks drove it 20 miles and checked again. When I reached home about 30 min later enjoying the fairly open highway while staying under 4k RPM there was no smell except that "new" smell.
I ordered at rear spoiler & USA Spec IPod interface, installing those will be my weekend fun.
I've put about 800 miles on the car since I've gotten it back the 2nd time.
I still smell that burning oil smell inside the car now that its getting cooler out and I've started using the heat in the morning, the burning oil smell is very obvious coming from the vents. Which leads me to leaving my windows cracked while driving to lessen the fumes.
Prior to the short block replacement I had OC but no oil smells.
I checked my oil and its 1/2 down the checkered part of the dipstick.
I'm pretty much disgusted at this point.
I'm starting a paper trail now which will begin with a letter to the service manager at the dealership. Expressing my dissatisfaction with what has been done to this point to the car. I feel like I took 3 steps back trying to get this resolved.
Should I contact Infiniti NA at this point or see if I can get a long block from the dealer?
Old Oct 28, 2011 | 09:53 AM
  #1646
alfhasg35's Avatar
I think u need to jump through hoops and go back to the dealer once again. I think u contact Infiniti customer affairs when they refuse to help..
Keep us posted..!!
Old Nov 1, 2011 | 11:42 AM
  #1647
ajm216's Avatar
Keep us posted..!!
I'm taking the car back to the dealer tomorrow for a OC test #2
Also to have the check out the oil fumes coming into the cabin when using the heat.
What's funny is I always wanted a G/Z I finally go around to getting one and I have to deal with this BS.
I figured since the model has been in production for years all the kinks were worked out NOT!!
I'll keep you guys informed.
Thanks!!
Old Nov 1, 2011 | 11:51 AM
  #1648
LegendC32A's Avatar
When they replace your oil to begin the test are they suppose to use 5w30 or 10w30?
Old Nov 3, 2011 | 01:09 AM
  #1649
6MT Coupe
^ When it involves oil consumption issues, it doesn't really matter which one of those.
Old Nov 3, 2011 | 07:08 AM
  #1650
rhampsterwha2's Avatar
its been a month and 2 weeks..... i want my car back already
how long did you guys, that had replacements, have to wait?
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
